There is no lint trap on this washer. There is a filter in the hose that goes from the tub to the pump that occasionally will get plugged with lint, but it is not designed to be regularly cleaned. During normal usage, the lint is designed to be pumped out with the water.
Kelly
Testimonial: "wasnt any help as I still was not told where to find filter in hose"
You have to remove the bottom panel or the rear cover, depending on which model you have. Then, you must disconnect the hose from the tub. It is not easy to access and more difficult to remove from the hose. Be sure to put it back in the exact position in the hose from which you remove it! This is critical, so be sure to mark the groove it is placed in before you remove it.
Kelly
There is only one hose that leads from the tub to the drain pump! The filter is in that hose! You must remove the rear panel for lower front panel, if so equipped, to access this hose. I cannot make this any more clear to help you find this large, black hose!
Hello gen0313 - From what you are describing it sounds like the unit could possibly have a broken shock/bearing or damaged tub. A certified technician will need to accurately diagnosis the bearing and pulling system behind the drum for repairs.
Hello zabbster - Typically the DR or DO error code indicates that the door switch is not closed. Make sure that the door lock is completely closed. If the door is closed, make sure the door latch is not broken. If the latch is broken, you may possibly need to replace the door lock switch.
how do we get to this filter in the hose.???
