Question about Cell Phones
I have an 87 suzuki quadrunner 300. Every time you go to start the 4 wheeler you hear a click click what is that going wrong? I Replacing capacitors that comes off the battery.
  • 51 Answers
Sounds like a burnt out starter.
Also, you posted this in the wrong section :)
Posted on May 25, 2011
1995 suzuki 250 quadrunner starter wouldn't work yesterday but today I jump started then took it for a spin turned it off then tryed to electric start it and it started why does it do this.?
There can be a few reasons,,,
1. Bad battery.. Have the COLD CRANKING AMPS checked
2. Bad battery connections.. clean and tighten both battery terminal cannections
3. Bad/going bad solenoid
4. Bad/going bad starter
Suzuki atv manuals
Jul 08, 2017 | Suzuki Cars & Trucks
Is a 2000 Suzuki LTF250 quad runner Ina 4 stroke or 2 stroke
Joe, 2000 Suzuki LTF 250 is 4 stroke. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
2001 ltf250 oil change
Suzuki LTF250 Quadrunner 4x4 Oil Filter Replacement Oil Filters
2000 Suzuki Quadrunner F250 ATVs
Jul 10, 2016 | Suzuki Motorcycles
I have a 99 Suzuki Quadrunner 500 with an electrical problem. New rectifier still gets warm and shuts bike down after 3-4 min.14 volts going to battery with lights on. Old rectifier was overcharging.
Hi, Robert converting AC to DC creates heat that's why rectifiers have cooling fins and 14 Volts going back into the battery is normal you may have other issues like the fuel tank not venting properly if you still believe your rectifier is causing the problem make sure it has a clean solid ground connection or you can try relocating it to a more cool air friendly environment for more information about your question and valuable free downloads that you will need please visit the websites below. Good luck and have a nice day.
ATVUtah Forum King Quad Problem
1997 quadrunner LT250 4wd
2001 Suzuki Quadrunner high idle backfire when shut down
ATV Connection
https://www.tradebit.com/filedetail.php/263724527-suzuki-quadrunner-500-service-manual-repair-1998-2002
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Mar 03, 2016 | Suzuki Motorcycles
2000 SUZUKI KING QUAD 300 LOSES POWER WHEN EXCELLERATE
Hi, Norman for more information about your question and valuable free downloads that you will need please visit the websites below. Good luck and have a nice day.
02 Quadrunner Carb or Ignition Issue
ATV Connection
95 king quad 300 loads up and dies Utility ATV
https://www.tradebit.com/filedetail.php/166275851-suzuki-king-quad-300-lt-f300-ltf300
Feb 21, 2016 | Suzuki Motorcycles
Why does my 1989 suzuki 250cc quadrunner have no compression?
i would adj valves 1st and go from there. rings maybe stuck if it has sat a while w/o being started. run a compression test on it should have something at least. no compression doesnt sound right to me. if so rings stuck can be freed if so ,sometimes fixes it ,sometimes breaks it
May 06, 2014 | RTO Quads 125cc Full Size Adult 4 Wheelers...
I have an 05 Suzuki Vinson 500 quadrunner 4X4 that has 265 miles that has a hard time starting and it will not stay running when I throttle up. It has a published stick substance inside and on the...
The sticky stuff is normal. On a lot of dirt bikes and 4 wheelers they have air filters that you are to wash either with a filter cleaner or gas and then you spray them down with a light oil and then wring them out until they have no extra oil in them and the oil helps filter the dirt out of the air heading into the engine. It does look in your picture like it is needing a cleaning.
Oct 17, 2017 | Suzuki 2005 Vinson Automatic 500 4X4
1999 suzuki quadrunner does not run properly
Sounds like its floodling check the carb for dirt and clean well, check the float is still floating, check for wear on the float valve, seat and seal.replace if nessary.
Jan 27, 2012 | Motorcycles
Have 2007 suzuki vinson quadrunner 500 4x4,only runs at idle with choke on ,has been sitting for year,new gas in it now.
Mine did the same thing. I took the air filter off and there was about a half inch of gas sitting in the bottom, so I just soked that up started the wheeler and covered the air hole w my hand and hit the gas. After that it started working. It died when I did that and then it started right up.
Oct 11, 2010 | Suzuki GT 500 Motorcycles
Cell Phones Logo
133 people viewed this question
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
