Question about Refrigerators
Have replaced broken hinge but am stuck getting both fridge and freezer door back on. can do one or the other but not both. westinghouse freestyle fridge/freezer
    Sergeant:
    Champion:
  • 338 Answers
Srack from bottom up- bottom hinge - bottom door- tape door with duck tape- middle hinge- top door- tape top door- top hinge- remove tape- done
Posted on May 25, 2011
Freezer drawer on Kitichen aid french door stuck shut. Been of for 24 hours still won't budge.
tough question
by the look of the picture it should not have that problem
something jammed or fallen on both openings
that stop doors from opening
call a fridge repairer first
those doors cost a lot to replace
maybe the fridge guy can you undo the top hinge of the french doors
if the freezer draw handle is broken you might need his help with that anyway
Sep 26, 2016 | Refrigerators
Freezer icing up on roof and door corner.
yes, sealing problem. take a hair dryer and see if can smooth out corners. do not hold stationary on gasket. move slowly back and forth. make sure not gaps around gasket. warm air is the problem
Mar 04, 2010 | Refrigerators
My westinghouse freestyle frost free 650 litre is
The fridge need to be devrosted open up freezer door take back of and look if all ice gone from freezing rods restart if same prob it looks like fan not going or heating element not workingon
Nov 08, 2009 | Westinghouse Refrigerators
Fridge freezer not cooling
(bad news) Repair man came today and said the compressor has died ;- (
(good news) Westinghouse will replace compressors less than 5 years old with a new one, just ring them with your serial number (inside front door) or supply a receipt and you only have to pay for the labour ;-)
Apr 12, 2009 | Westinghouse Refrigerators
Top half fridge not cold freezer department fine
I had the same problem; the top fridge compartment was warming up to 14C while the freezer compartment was starting to defrost (frozen stuff was starting to become soft. I took the rear wall off the freezer compartment and found it all iced up. I defrosted it with a blower heater then powered it back up. It all worked fine for a month when the same thing happened. I figured that the defrost cycle wasn't working. I located the defrost timer on the rear right-side of the fridge. I rotated it several times and found that the fridge was turning on and off. I rotated it until the fridge turned off. I waited 5 minutes then stuck my head into the freezer compartment and felt the rear wall at the bottom where he drain is; it felt warm so I guessed the defrost heater element was ok. I ordered a defrost timer and installed it. I haven't had a problem since.
Nov 09, 2008 | Westinghouse Refrigerators
The top hinge of my Neff integrated fridge freezer has broken so the door won't open and shut properly. Neff are sending replacement hinges but as a temporary repair I intend to swop the hinges around...
The top hinge of my Neff integrated fridge freezer has broken so the door won't open and shut properly. As a temporary repair I intend to swop the hinges around -replacing the top hinge with the middle one but can't see how to remove the hinges. Can anyone help?
May 02, 2008 | Refrigerators
Ice maker broken
check to make sure the arm or what ever controls the cubes isn't stuck closed or the inlet to the maker isnt' got some restriction
Dec 08, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer Icing Up
Try contacting the hotline again and ask them if the freezer has a frost sensor on it. If it does, the sensor is not kicking the thermostat to allow for the unit to defrost.
Oct 21, 2007 | Zanussi ZEBF250W Bottom Freezer...
Refrigerators Logo
269 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
