Question about LG Televison & Video
Can I replace a 2200uf 10v with a 470uf 50v capacitor for my tv
  • 731 Answers
Not if you want it to work
Posted on May 25, 2011
Will not power up
Look on Power Supply board for Bad Capacitors they will be vented or puffed up on Top , 1000uf 16v 2200uf 10v 330uf 10v or replace the power supply board Encompass Parts Distribution 1-800-638-3328. Look on website at Shopjimmy.com
Dec 15, 2010 | Emerson LC320EM8 32 in. LCD TV
Why does mt tv click before it turns on?
Hi:
There are some capacitors that needs replacing on the power supply. Usually there a two to four of them. They will be buldging or puffy on their tops, replace with same value listed on the cap but raise the voltage rating to 16 volts.. Example a capacitor with A value on it like 2200uf 10v, change to 2200uf 16Volts.
Nov 10, 2010 | Samsung LN-R408D 40 in. LCD HDTV
Monitor comes on then goes black
I've got a couple of these monitors that have the same problem. All the caps in the P/S except the large inverter filter (110uf/400v) are bulged. I;ve ordered all the caps - INCLUDING the one that doesn't look bad since all have been subjected to the same high heat (or are bad caps in the first place {Non standard?} so am attempting to prevent a recurring problem. Since all of them cost around $6 TOTAL (plus s/h) there's absolutely NO reason not to replace all of them. The ones in my monitors are: 1-22uf/50v, 1-100uf/400v, 1-470uf/10v,2-1000uf/10v and 3- 470uf/25v. I opted for the slightly higher voltages available when I ordered since that also helps and there's plenty of room. the 10v caps will be replaced by 16v ones, the 25v by 35v while the 50v & 400v will be the same voltage. Hope this helps somebody. Good luck and solder quick to keep the heat down.
Apr 18, 2010 | Princeton Digital VL2018W Monitor
I have a westinghouse sk19h210s will not turn on. replaced 2200uf 10v capacitor with a 2200uf 50v was told the volts wouldnt matter but it still does not work.any input would b helpfull
their right volt rate will not matter as long as it is higher do you have any other indecation of the unit getting power? if not check you fuses if so you mainboard could be your problem check carfully for more bad caps
Nov 19, 2009 | Televison & Video
Power on problem
replace +5vdc out capacitor two 2200uF 10v and 47uF50v with top quality capacitor. u save $400. other than this samsung is OK
Jun 27, 2009 | Samsung LN-T5271F 52 in. LCD Television
Power supply fail DVE DSO-142L
The output + 5.1v/2.4 Amps and -5v/0.5Amps DC
Input is AC 100/240 VAC 50/60 Hz
Jun 05, 2009 | HP 336044-B21 8-port KVM Switch
Need to replace capacitor on dvd player
Hi, you should use a capacitor with same capacitance of 1000uF, but you don't have to stick to the original voltage spec. 1000uF 10V means it can withstand 10V load. 1000uF 50V means it can hold 50V for the same capacitance. Today I fixed my friend's and for that I used 1000uF 35V from RadioShack. It perfectly works - and it's better. But you shouldn't use 1000uF 5V - by now you already know that :)
May 03, 2009 | Philips DVP642 DVD Player
ILO LCT32HA36 will not power on
same thing happened to my ilo. There are four capacitors that are bad on the power board. You can usually tell its bad because at the top it bulges out. Here is what you need to do. Unplug the tv, open up your ilo find the power board ( the power cord plugs into it). Then find the capacitors that are bad (they are the around things usually in blue color) and remove them by soldering the other side. On mine there where three 1000uf 16v and one 470uf 35v. Those are the ones that need replacing. I replaced them with a higher voltage rating 1000uf 35v and 470uf 50v. All you need to do is solder them back on but make sure you solder them back the right way (plus goes to plus on the board or you will be in trouble). I found the capacitors at radio shack for about 1.50 a peice. If you dont know how to solder look it up on youtube. If that does not work there might be couple more bad capacitors that need replaceing just need to find them and you can tell by a small bulging top.
Aug 24, 2008 | iLO LCT32HA36 Television
Can changing 3 capacitors on motherboard solve my problem?
We had a power surge and my VL2018W LCD monitor stopped working... blank screen and flashing blue light.
I carefully opened up the back and found the power board (the one the AC plug goes into). There were about 5 electrolytic capacitors that were bulging (but not ruptured). There were 3 with the values listed by the original poster (470uF @ 25V) and 2 with 1000uF @ 10V.
I scrounged a couple of 2200uF@10V caps for the last two and bought 3 470uF @ 35V caps from Radio Shack (P/N 272-1030).
Luckily, the monitor came right back up and seems to be OK. It was out of warranty, so there wasn't a big risk.
Just increasing the working voltage won't do that much for you. If any caps are bad, just replacing them with the same value is good enough, but a higher working voltage won't hurt (usually means a bigger cap).
Good luck.
Rich
May 04, 2008 | Princeton Digital VL2018W Monitor
Televison & Video Logo
90 people viewed this question
Computer Repairing
Computer Repairing
