Question about Franklin Industries FR1355A Blender
I need new blades for my bcf 1350 blender. - Franklin Industries FR1355A Blender
My ninja blender motor starts but the blades don't turn
As stated earlier it could be the shaft needs lubing, remove the bottom part of the blender blade... the rubber thing that engages on the motor. I started with WD-40 and worked some lithium grease into it. Spins like new now.
Jun 18, 2012 | Blenders
Grease build up around blade and where it attaches to base
Grease can only creep into the blender vase if the oil seal has worn out, or the blenders blade shaft is worn and wobbling. Try cleaning all parts in alcohol to soften the seals. Rebuild kits and replacement blades can be found here (http://www.brevilleusa.com/breville-parts/blending.html)
Mar 09, 2010 | Breville BBL600XL. 5-Speed Blender
The lights are on but the blades inside the blender are not mving.
the blender only hums and the blades do not move. I cannot get the blade to rotate even while empty. Need new assembly???
Jan 29, 2010 | Cuisinart CB-600 Blender
A blade on my immersion blender was bent slightly. The motor still works and the blades spin, but they no longer emulsify. Can I buy just a new blade attachment?
If you have a model with the detachable blades. Otherwise, you'd need to purchase the blending rod from www.wpcookware.com.
Jan 16, 2010 | Wolfgang Puck Immersion Blender
My kenmore blender stopped blending!!!
There is a gear underneath the blender blade. This connects the blade to the motor found on the base of the blender. This gear usually get worn out specially if the load that we are giving to the blender is beyond its limit. I hope you could by a spare on one of the electric shop near or might as well consider buying a new set.
Oct 06, 2009 | Kenmore Blender Single-Speed Blender
My Blender knives don't cut good anymore, what should i do?Can they be changed?or should I buy a new one?
Do you mean blender blades?
Either way, your blender blades/knives need to be sharpened.
This is the key to making your blender last a long time.
You may need to reach into the unit to sharpen them if the blade part doesn't twist off.
Good luck :)
Nov 11, 2008 | GSI Technologies 73365 Vortex Work Top...
VILLA WARE 5767
my blender jar is broken. I need to replace it
Aug 05, 2007 | VillaWare 5787 Double Smoothee Work Top...
Franklin Industries FR1355A Blender Logo
60 people viewed this question
Top Franklin Industries Blenders Experts
eyecam
Are you a Franklin Industries Blender Expert? Answer questions, earn points and help others
