Question about Kitchen Ranges
F2 button flashing and beeping in green oven is on and light to oven wont go off no buttons working.
  • Kitchen Ranges Master
  • 3,051 Answers
Hello there and thank you for choosing fixya
This is a very common problem with ovens
The F2 Error code means the oven has detected an excess temperature condition. Most often this is due to a bad temperature sensor which only costs about 60 to 80 dollars depending on the oven
How to remove and replace the temperature sensor. In most GE or well known brand ovens, when you open the door, you'll see the rod-shaped temperature sensor sticking out of the back wall at the upper left. It's about six inches long and a bit more than 1/8" in diameter, held in place with two screws.
Turn off the circuit breaker (built-in ovens) or unplug the range before attempting the replacement.
The replacement sensor will come with instructions, but basically it's a matter of removing the sensor, pulling out the wires to where they are connected and disconnecting them. You may have to snip. The replacement sensor will come with high-temp wire nuts to hold the new connection. Polarity doesn't matter; it's a straight resistance thermocouple. Hook it up, be sure you poke the connections back far enough so that they're on the other side of the thermal insulation and not resting against the back of the oven.
If you continue getting the F2 error after replacing the sensor, then the problem is likely in the control module - this is the circuit board behind the keypad and clock.
Posted on May 25, 2011
When I bake, my oven will start beeping and flash F2, what is that and how do I stop it?
Which manufacturer built your oven? The F2 error usually means that the oven temperature sensor is claiming the oven is too hot (or got too hot in the past). This usually requires replacing the temperature sensor. Sometimes, the control unit (clock) needs to be replaced.
I hope this helps. Please add a comment with the make and model of your oven for additional support.
Mar 18, 2013 | Ovens
My ps3 won't load the discs...
Hi, if it wont load your icons and freezes before your xmb, put it into safemode and try restoring the filing system. to get it into safemode...
hold down the power button while the console is in standby. the light will go from red to green.it will beep once flash green beep again, and then beep a third time. after the third beep the light will turn red.
once the light is red, take your finger off the power button and place it back on the power button. the light will go from red to green, beep once flash and then beep twice quickly. after it does the double beep, take your finge roff. the light will stay green and you'll get a screen asking you to connect the controller.
after connecting the controller, try option 3, or whichever option is restore filing system. this can possibly correct media loading and will 95% of the time fix the console when it freezes before loading up your icons(the xmb)
Thanks and take
Apr 19, 2010 | Sony Playstation 3 (PS3) Console
Flashing F2 warning
GE
Range/Stove/Oven Fault Codes Failure
Code
Condition Check/Repair F0 and F1 Failed Thermistor Control Replace Electronic Range Control (ERC) F2 Oven temp exceeds 590 w/ unlocked door High resistance or interference in oven temperature sensor. Replace oven temperature sensor F3 Open oven temperature sensor circuit Replace oven temperature sensor F4 Shorted wire (Oven temperature sensor) Locate and correct F7 A = Function pad button stuck or
B = Bad clock Unstick button or
Replace Electronic Range Control (ERC) F8 Component Failure Replace Electronic Range Control (ERC) F9 Program w/ door circuit Check wiring
Aug 18, 2009 | Ovens
Ps3 problem
May 03, 2009 | Sony Playstation 3 (PS3) Console
Ps3
insetad of restoring the filing system, restore the default settings ore restart the system
Mar 31, 2009 | Sony Playstation 3 (PS3) Console
Flashing F2 and beeping
Replace the oven temperature sensor.
Mar 28, 2009 | Hotpoint RGB745 Gas Kitchen Range
My ps3 doesnt work
Mar 19, 2009 | Sony Playstation 3 (PS3) Console
Kitchenaid YKGRT607HS6
F2:E0 is shorted keypad, and F2:E1 is no keypad connection, you need to replace the keypad.
You can find schematics and find replacements by entering model number here.
Dec 14, 2008 | KitchenAid KGRA806PSS Gas Kitchen Range
Oven
I used the self cleaning mode for 2 hours and the error f2 keeps flashing and beeping, I did try to power off with the breaker and left it off for about a half hour and it still continues to beep and flash f2, what should I do?
Aug 07, 2008 | Ovens
Kitchen Ranges Logo
120 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
