Question about Everex NM3500 Laptop
Where is the RAM located? Back panel? Under the
Where is the RAM located? Back panel? Under the keyboard? Thanks.
  • justim May 25, 2011
    Thank you. I knew the basics as you have described them. I am wondering about the specifics of this PC. I opened a small (3"x4") panel on the back and it exposed a foil cover. Would the RAM be under that?
    Thanks.
    Novelist:
  • 123 Answers
Good day, to locate your ram follow these steps:
- Laptops often have their RAM located on the underside of the system. Some systems place the RAM right under the keyboard.
- Locate the memory bay. It is usually a sliding panel.
- If you open the bay to the hard driver instead, look for the other sliding panel.
- You may need a small philips screwdriver to unscrew the panel, or, as below, you may need to simply need a flathead to lever the panel upwards for removal.
Hope this information help you a bit. Have a great day.
Posted on May 25, 2011
  • david signo May 25, 2011
    yes that's it. ^_^ that's the ram module. The module is typically held in place by small spring-loaded latches
How to install ram? under keyboard where??
Most laptops there will be a access panel on the back of the laptop. A small percentage will have their second slot under the keyboard. If you open the panel on the back and there is only 1 slot, the second will be under the keyboard.
Sep 17, 2011 | Computers & Internet
I can only find one DDR ram slot!! there is only one slot behind the panel on the bottom. where is the other slot located. I have the tecra m2v-s330. should i just take it apart to look for it...i have...
The 1st RAM slot is under the keyboard. This slot has a RAM module installed when you purchase the laptop. The 2nd RAM slot is on the bottom of the laptop.
For removal of keyboard and keyboard replacement check out this WEB site.
http://www.batterycentury.com/toshiba-tecra-m2v-s330-keyboard-p-79168.html
Apr 14, 2011 | Toshiba Tecra M2V-S330 Notebook
I want to trade the 1gb ram for 2gb ram. where is the ram located on this netbook?
Your ram is either located under the keyboard or under a door on the bottom of the netbook. If its on the bottom of the laptop you will need to remove the small doors using a philips screwdriver some have the memory card symbol on the door. If not it will be under the keyboard check by looking at the bottom of the laptop for screws for the keyboard if not if you look at your keyboard carefully and you will notice little tabs either along the top or bottom which you can push back using a flat head screwdriver and then gently lifting the keyboard up. Please be careful as its got a cable connecting it to the mainboard. Then you should be able to see your memory which is held in place by two clips which you can just move back with your fingers and it should pop up just slide it out and slide the new memory in make sure it goes fully in and locks in place otherwise your netbook will not post or load into windows/linux.
Hope this helps if not just ask me any questions and ill try to explain for you.
Feb 22, 2011 | Computers & Internet
Adding RAM memory
Usually they are both in the same spot: inside a removable panel on the bottom of the laptop. One is just above the other. If you only find one slot on the bottom of the laptop, then the other one is usually just under the keyboard. Some keyboards are easier to remove than others. Sometimes there are screws going thru the bottom of the laptop casing that hold the keyboard in, as well as some small screws going along the top of the keyboard; which are usually covered up by the molding with the power button on it. There could be several screws that you have to remove in order to get the molding and keyboard removed. Be delicate with the ribbon cables. They can be expensive to replace, and be sure to remember exactly where all your screws go back into.
Apr 24, 2010 | Compaq Presario R3000 Notebook
I want to find the location of the ram ports on
Turn the laptop off. Remove the battery and the AC power supply.
Turn the laptop upside down and look for a panel with one or two screws (there maybe more than one panel). Unscrew the panels to access the RAM compartment, it will look something similar to this >>>>>>
Regards.
Sep 15, 2009 | Computers & Internet
Is there another memory slot under the keyboard?
how to check the Ram slot location
1) most laptop have two slots at back, so no other slot under the keyboard
2) some laptop has onboard Ram(on the surface of motherboard) ,if you see one slot at back so no any slot under the keyboard
3) if the laptop no any slot at back it should be one or two slot under the keyboard
your laptop no ram slot under the keyboard
hope it help you to improve your idea
May 09, 2009 | Computers & Internet
Cannot locate ram on compaq EVO N620c
The RAM is located under a panel on the LHS of the touchpad.
You need a thin blade/knife to slip under this panel to lift it up and out. It is clipped in with plastic catches on the panel.
Dec 17, 2008 | Compaq Evo N620c Notebook
Toshiba Satellite A45-S250 PC - where is the ram located?
The memory is under the keyboard on these models. Remove the plastic piece with the power button, and you will see the screws for the keyboard. Don't forget to rate me (fixya). thanks
Jul 31, 2008 | Toshiba Satellite A45-S250 Notebook
Ram
You can try this link for diagrams.
http://repair4laptop.org/notebook.html
If you're looking for the ram, it will be under a panel on the bottom of the machine. If there is only one slot under the panel, the other slot will be located under the keyboard.
Jun 27, 2008 | Dell Inspiron 630M Notebook
Medion MD41060 Memory Installation
Hey, as far as my knowledge is concerned, the battery compartment is on the backside of laptop and there is a symbol on that compartment. you just need a screw driver to open two screws and reach the RAM compartment.
Try that you will fixup your problem.
Feb 13, 2008 | Computers & Internet
Everex NM3500 Laptop Logo
88 people viewed this question
Top Everex Computers & Internet Experts
Jerry Umali
k24674
Are you an Everex Computer and Internet Expert? Answer questions, earn points and help others
