Question about Gateway DX4720-03 PC Desktop
The power button on my Gateway DX4720-03 is slowly flashing blue
Integrated video card on Mother board heated up. Will need to replace all motherboard. $90 bucks to replace if you find it.
Posted on Mar 12, 2013
5 Suggested Answers
  • 2692 Answers
SOURCE: I bought a gateway DX4720-03
Here is your support page to download the manual from.
http://support.gateway.com/s/PC/DX/DX4720/DX4720ul.shtml
Posted on Dec 25, 2008
joecoolvette
  • 5660 Answers
SOURCE: I need a motherboard for this model. Gateway
The Gateway DX4720-03 Desktop PC, uses an MSI ms-7399 motherboard, made specifically by MSI for Gateway.
I just did a quick search and saw this mobo available for $75 US on Ebay. (Gateway DX4720, ms-7399)
This is not an advertisement for Ebay, nor the seller.
Posted on Feb 04, 2010
z89s
  • 225 Answers
SOURCE: Gateway DX4720-03 desktop the HDMI stopped working
Make your hdmi port a separate monitor in your display settings. If that didn't help leave a comment and ill try to help you again.
Posted on Jul 02, 2010
BearWeb
  • 357 Answers
SOURCE: I have a dx4720-03 and it will not boot up. The
The motherboard could be the problem. However, you should first check that the master HDD to check if it is corrupted. You can check by either taking the HDD out of the computer and putting it in another computer as a slave HDD (it must be set as a slave drive because the HDD would not work as a master in another computer because the operating system has been configured to run on that one specific computer), you would need to change the drive from a master to a slave by changing the jumper pin found on the one side of the HDD, there should be a diagram on the top of the HDD which will show you how to change the drive from a master to a slave. Then just check that all of the data is on the drive. If it is then you know that the motherboard or the cpu is faulty.
The other thing you could do is if you have another HDD you can swap it out and test if it is working.
Hope this was helpful. Thank you for using FixYa! Have a nice day and please remember to rate this solution.
Regards,
BearWeb
Posted on Aug 11, 2010
Testimonial: "The second post was right on the money"
I want to know how I can re-set my 3Com 3crwe955275 wireless access point to its default factory settings. Can anyone help?
1 Remove power from the Gateway. 2 Disconnect all your computers and the cable/DSL modem from the Gateway router. 3 Using a straight through Ethernet cable, connect the Ethernet Cable/DSL port on the rear of the Gateway to any one of the LAN ports. 4 Re-apply power to the Gateway. The Alert LED will flash as the Gateway starts up, and after approximately 30 seconds will start to flash more slowly (typically 2 seconds on, 2 seconds off). Once the Alert LED has started to flash slowly, remove power from the Gateway. 5 Remove the cable connecting the Cable/DSL port to the LAN port, and reconnect one of your computers to one of the Gateway LAN ports. 6 Re-apply power to the Gateway, and when the start-up sequence has completed, browse to: http://192.168.1.1 and run the configuration wizard. You may need to restart your computer before you attempt this. 7 When the configuration wizard has completed, you may reconnect your network as it was before
Here on page 85 of the manual
3Com 3CRWE53172 User Manual Forgotten Password And Reset To Factory...
Feb 18, 2015 | 3Com Computers & Internet
Gateway computer power light flashes before booting up.
Hmm. I wouldn't have thought it had anything to do with pressing the button. It sounds more like a failing power supply or lack of current for startup. Did you make sure you plugged the power into the video card power connector (if it has one)? I know it worked ok at first but a heavier load can cause older or under-rated power supplies to fail soon after. Just a thought.
Dec 16, 2013 | Gateway GT5662 Desktop PC
Gateway Laptop(MODEL M-6750): The power button keeps flashing blue and so does the wireless signal. I've tried removing the battery, holding the power button nothing changes.
Does it do this when it is plugged in? Try to power it up with no battery, and see if it acts differently, it may be a battery issue unsure. Is the computer working normally except for this problem?
Jun 10, 2011 | Gateway M-6750 PC Notebook
My gateway laptop will not come on. The battery says it's fully charged and the blue light on the front flashes when I press the power button. What's wrong with it?
Hello thanks for using fixya,
that looks a motherboard problem, try to do this :
1 take the bat. and the charger out
2 press for 10sec. the power button
3 connect only the charger and power button
if works fine if not your motherboard needs to be repaired
let me know if you need more help.
Thanks
Nov 20, 2010 | Gateway MT6840 Notebook
My monitor does not turn on and the power button light keeps blinking ... <my Gateway monitor light blinks blue slowly but the screen is blank
This is usually a sign that there is no signal going to your monitor, check all your cables and then reboot.
Jun 28, 2010 | Gateway FPD2275W LCD Monitor
Slow flashing blue power lite. Monitor shows no
First when you power up the computer press F8 key then enter in enable vga mode.
If you are able to enter then go to start menu->control panel->display property ->settings.
Change screen resolution to 1024*768 then apply and ok.
But if you are not able to see safe mode and other menu.
Then open cpu cabinet .
Refix RAM memory.
Pull cmos cell from motherboard for 10 minutes.
Reattach all connection harddrive.
Open processor fan and processor remove dust from all parts.
Make sure motherboard is not ground with cabinet.
Remove PCI cards if any.
After all above still same then change RAM then try.
Let me know if you need further assistance.
Thanks for using FixYa.
Dec 19, 2009 | Gateway DX4640-UBC01A PC Desktop
Blue led power light blinks even after shutdown
What operating system are you using? When the power led continues to slowly blink, that means that the laptop is in standby mode and not fully shut down. In Vista, if you hit the power button on the laptop or the power button under the start button, it is configured to go to standby and not shut down. Make sure to hit the arrow all the way to the right and select shutdown from the list of dropdown options.
Aug 28, 2009 | Gateway Computers & Internet
Orange Power light flashing
Most likely a power supply failure. It apears that the power supply is not putting out all necessary voltages.
Replace the power supply
Sep 02, 2008 | Gateway 556GE Intel Pentium 4 630 3GHz(HT)...
Want to disable power management flashing blue light on GT5220 PC
I don't think that's practically possible until you have to do it through the hardware inside..
However you may do some manipulation to the power plan of the computer system..
Aug 21, 2008 | Gateway GT5220 PC Desktop
Power supply for Gateway FPD1975W 19 inch LCD
try replacing the crystal on the power supply 8 out of 10 times it is the problem
Apr 02, 2008 | Gateway FPD1975W 19" LCD Monitor
Gateway DX4720-03 PC Desktop Logo
212 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
