Question about MSI Wind U120-020US Netbook
NO ARRANCA EL SISTEMA OPERATIVO, SOLO QUED EN EL SIMBOLO MSI Y DE AHI SOLO SALEN UNAS LINEAS EN LA PARTE INFERIOR
5 Suggested Answers
SOURCE: SER? LA BIOS O EL HHDD MUY GRANDE??
NO NECESITAS ACTUALISAR EL BIOS,ESTE TABLERO MADRE PUEDE LEER EL DISCO DURO.
LO QUE NECESITAS HACER ES CREAR UNA PARTICION DE 137GB O MENOS AL PRINCIPIO DE INSTALAR WINDOWS.
LUEGO PODRAS CREAR OTRA PARTICION DESPUES DE INSTALAR WINDOWS.
CLICK DERECHO EN "MY COMPUTER ICON"/MANAGE/DISK MANAGEMENT,Y SIGUE LAS INSTRUCCIONES.BUENA SUERTE
Posted on Jun 19, 2008
Luisjhernand
  • 84 Answers
SOURCE: mi pc no arranca
Si no intiendes este respuesta translarlo con babelfish.com. Puedo entender espanol pero tengo un tiempo dificil hablando technico en espanol.
Makes sure to check that the CPU Fan Power Switch has not come lose from the motherboard. If it is lose, plug it in. If that's not the issue then you will probably have to get a new fan. a new fan should do the trick...Try newegg.com or tigerdirect.com. buena suerte~
Posted on Dec 21, 2009
  • 116 Answers
SOURCE: no arranca windows por el
Hi! Welcome to www.fixya.com.
You need to get an Windows Operating system XP
Option 1:
Boot from your CD and follow the directions to start Recovery Console. Then:
Attrib -H -R -S C:\Boot.ini DEL C:\Boot.ini BootCfg /Rebuild Fixboot
Option 2:
Boot from your CD and follow the directions below to start Recovery Console.
Insert the Setup compact disc (CD) and restart the computer. If prompted, select any options required to boot from the CD. When the text-based part of Setup begins, follow the prompts; choose the repair or recover option by pressing R.
If you have a dual-boot or multiple-boot system, choose the installation that you need to access from the Recovery Console. When prompted, type the Administrator password. (if you didn't create one try pressing enter).
At the system prompt, type Recovery Console commands; type help for a list of commands, or help commandname for help on a specific command.
Most likely you will need to expand the file from the CD. The command would be expand d:\i386\hal.dl_ c:\windows\system32\hal.dll. Substitute d: for the drive letter of your CD. Once you have expanded the file type "exit" to exit the Recovery Console and restart the computer.
TIP: Recovering Windows XP using the Recovery Console
Hope this resolution fix the problem on your computer. Thanks for contacting Fixya. Bye for now.
Posted on Jul 20, 2011
MrMojoRisin1
  • 412 Answers
SOURCE: no encuento el jumper de mi mini labtop msi u130
Down the hard drive....
Posted on Sep 04, 2011
Recientemente conecte la Pc a internet y al realizar las actualizaciones, en el reinicio en el momento de configurar las este win no arranca se apaga y prende en un ciclo que no acaba. no dispongo de disco...
Usted puede tratar de arrancar en modo seguro pulsando F8 durante el boods m?quina. Una vez en modo seguro se puede tratar de hacer una restauraci?n del sistema de la, en Inicio, Todos los programas, accessores Herramientas del sistema • Restaurar sistema. Si esto no funciona, entonces usted tiene que hacer una restauraci?n completa del sistema o la recuperaci?n del sistema en funci?n de su computadora. La mayor?a de los nuevos equipos le permitir? hacer una recuperaci?n del sistema pulsando una de las claves durante el arranque. Usted va a perder todos los programas y todo lo que est? en el equipo. Usted puede ser capaz de hacer esto sin tener que formatear el disco duro.
Apr 04, 2011 | HP Compaq Presario SR2180NX (RK548AA#ABA)...
La maquiina me pide el archivo windows/system32/rundll32.exe para poder acceder a quitar o agregar programas
Ir a la http://www.dll-files.com/dllindex/dll-files.shtml?run32 para descargar lo necesario.dll
Descomprima este archivo y el lugar en C: / / windows/system32 /
Mar 02, 2011 | Computers & Internet
Como encender wirless
algunas tienen el boton enfrente de la compu o a los costados otras tienes que precionar fn esta en la parte inferior de el tecleado solo esta asi fn sin soltarlo preciona la tecla que tiene una como antena ointada esta en la linea de los botones de arriba empesando con fi el que tenga el dibujo de la antena si tienes mas dudad tony30_2_1@yahoo.com
Mar 26, 2010 | Gateway 4026GZ Notebook
Como activo el bluetooth en mi laptop acer aspire 31000
Hola, solo para estar seguros de que funciona correctamente, bajate el ultimo controlador de tu bluetooth: http://www.acer.com.mx/acer/service.do?LanguageISOCtxParam=es&miu10einu24.current.attN2B2F2EEF=3754&sp=page15e&ctx2.c2att1=30&miu10ekcond13.attN2B2F2EEF=3754&CountryISOCtxParam=MX&ctx1.att21k=1&CRC=1038638458
Escoje el model y el sistema operativo y listo. Para windows vista y 7, el bluetooth esta siempre en la barra de programas. Dale click derecho si lo ves y vete a opciones, en seguida te debe aparecer la opcion de si quieres que tu dispositivo pueda ser encontrado. Si solo quieres añadir un dispositivo, le das click derecho en la barra de programas y le pones en añadir dispositivo, buscara todos los que esten cercanos a tu equipo y despues ahi mismo te guiara para que se emparejen correctamente.
Espero te ayude
Nov 03, 2009 | Computers & Internet
Noel perello
You'll need a spanish version of WIndows and a Spanish layout keyboard to run the system in spanish.
http://free.grisoft.com if a good source for free antivirus
Office products have spanish language packs
Jul 10, 2008 | Computers & Internet
MSI Wind U120-020US Netbook Logo
44 people viewed this question
Top MSI Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Terry Hair
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
