Question about Whirlpool GR478LXPS Electric Kitchen Range
How do I lift the cook top to replace the LF element?
2 Suggested Answers
jsrock516
  • 5911 Answers
SOURCE: how do i replace the surface element for a glass
The cook top on this model range will lift up, exposing the surface burners and wiring harness. The screws are located along the bottom of the front edge of the cooktop. You will need to open the oven door to see them. Then, just follow these steps:
Before you begin:
1. UNPLUG the range before servicing. There is dangerous voltage still present even with burners turned off.
2. There are a few screws located under the front edge of the cook top. You will need to open the oven door to see them. Remove these screws and the top should lift up. If the range is not equipped with any kind of hinge supports, the top will have to be propped up.
On some ranges, there is a disconnect plug for the surface element wiring harness. If you have this feature, Follow these steps:
a. Unplug the cook top and leave the elements in place.
b. Place the whole cook top assembly face-down on a soft surface (like some old towels, or a blanket).
c. Remove the bad surface element by removing only the bracket pair that the affected element is attached to. Leave the rest of the elements wired together. Write down the wire color codes so you can be sure the new element is installed correctly. HINT: A digital camera can save you some time.
d. When installing the new surface element, make sure you use the same alignment marks (the numbered positions around the perimeter) as the old element. Avoid touching the burner surface and handle with care. Try to handle from the underside of the element only. Oil from your hands can cause damage to the element and/or premature failure. The elements are fragile.
If the wiring harness does NOT unplug, prop the cook top in place and install the surface element from underneath. A helpful hint: Use some duct tape to hold the assembly until you have screwed it back into place. Don't forget to remove the duct tape when completed.
If you have any questions about this repair, please let me know. You can reference searspartdirect.com for some helpful exploded view diagrams of you range for assistance if you need it. I hope you find this information helpful.
Posted on Nov 17, 2009
How to do you remove an electric cook top element from a chef supreme
sorry don't know your product but seem to remember most elements are simply plugged in..so to remove ...lift the element and wiggle/pull from the socket....
May 27, 2012 | Cars & Trucks
Tip
Surface Burner Replacement on Electric Smooth Top Range
Steps necessary to replace one of the surface elements on a smooth top electric range.
Before you begin:
on Apr 05, 2010 | Kitchen Ranges
Tip
Replacing a Glass Cook Top
This advice is for Electric Ranges equipped with glass smooth tops. If it becomes necessary to replace the cook top due to wear or damage, here's some helpful tips on how to complete the repairs yourself. NOTE: Cook tops are NOT cheap. Prices vary between models, but most are in the $200 to $300 range. With added labor charges, this repair can cost over $600 from an appliance repair company.
WARRANTIES: Most warranties DO NOT cover cosmetics. That is, if your cooktop paint starts to wear off, most manufacturers will not replace it. Warranties also DO NOT cover accidents such as dropping something on the top and breaking it. Warranties DO cover blistering, warping and heat related breakage (if you are using the recommended cookware). This is why it is important to follow all the manufacturer's use and care instructions that come with your range. I know this does not include ALL manufacturers, but this is true with most.
This is a recommended two-person repair job. Please read through the instructions carefully before starting the repairs, and follow any safety recommendations.
1. UNPLUG the range before servicing. There are dangerous voltages still present even with burners turned off.
2. If the old cook top is broken, you will need to get rid of a much of the glass shards as you can and thoroughly vacuum the area around the oven box. Use extreme care when handling broken glass. Wear safety glasses and gloves.
3. There are a few screws located under the front edge of the cook top. You will need to open the oven door to see them. Remove these screws and the top should lift up. If the range is not equipped with any kind of hinge supports, the top will have to be propped up.
4.On some ranges, there is a disconnect plug for the surface element wiring harness. If you have this feature, Follow these steps:
  1. Unplug the cook top and leave the elements in place.
  2. Place the whole cook top assembly face-down on a soft surface (like some old towels, or a blanket).
  3. Remove the surface element assembly leaving all the elements wired together.
  4. Place the new cook top face down in the same manner and lay the surface element with wiring harness directly on to it and screw in place.
  5. Install the new cook top back on the range and you are DONE.
5. If the wiring harness does NOT unplug, follow these steps:
  1. There are a series of screws holding the element assemblies in place. Leave these assemblies wired together for ease of replacing. It is recommended that a second person holds the assemblies in place to support the wires until all the screws have been removed.
  2. Lay the intact element assembly, with wires still connected, on top of the oven box. Handle the surface elements with care. They are very fragile. Care also must be taken not to handle the element coils or ceramic material. Try to handle from the underside of the element only. Oil from your hands can cause damage to the element and/or premature failure.
  3. If you have to remove the elements, individually, make sure you write down how the wires were connected to ensure you reconnect them in the right order. Make sure you also take note of the numbering scheme on the element and make sure you place the mounting brackets in the same holes that they came out of. Use care when screwing into the new cook top. CAUTION: The screw holes are usually painted and a little force may be required to thread the screws. Do not apply too much pressure on the glass, or you can damage it.
  4. Prop the new cook top in place and install the surface element assembly from underneath. A helpful hint: Use some duct tape to hold the assembly until you have screwed it back into place. Don't forget to remove the duct tape when completed.
  5. Lower the new cook top into place and secure with screws.
    Good luck and I hope this helps.
on Mar 02, 2010 | Kitchen Ranges
No heat
Good Morning; Thank You for your question. If you have an ohm meter, it would come in handy. The parts you will probably will need;
279838 Heater element $54.60
3387134 Control thermostat $21.26
3392519 thermal fuse $14.58
UNPLUG UNIT BEFORE WORKING ON IT, THANKS
To get to the parts, top is lifted by releasing 2 clips at the lf & rf by pressing in and lifting top. Lay back and prop. Now there are 2 screws at the top left and right of the front panel. Remove. Lift front panel off. Remove wires to door switch noting their position. Remove belt noting its position. Lift drum out. You will see the heat element. Use ohm meter after removing wires for continuity. Replace if necessary. The control thermost. is on blower housing. Replace. Thermal fuse is on heater housing, check for continuity. Whether you fix this dryer or install another one. Go behind dryer. The vent coming off of the dryer to the wall outlet must be as straight as possible. No kinks or bad bends. Go outside check wall vent for lint buildup and clean. Hope this helps
Jan 29, 2011 | Roper REX4634KQ Electric Dryer
Jenn Air ElectrCook top One of the cook top heater is not working
well it can only be a few things on a cooktop... u either have a bad element or a bad switch.......usually on most to replace either u must lift top up and out and remove the screws all the way round to open unit up...hope this helps let me know how it goes
Feb 26, 2010 | Cooktops
Tip
This advice explains the steps necessary to replace one of the surface elements on a smooth top electric range.
The cook top will lift up, exposing the surface burners and wiring harness. The screws are located along the bottom of the front edge of the cooktop. You will need to open the oven door to see them. Then, just follow these steps:
Before you begin:
on Dec 22, 2009 | Kitchen Ranges
Tip
on Feb 11, 2008 | GE Spectra JBP78 Electric Kitchen Range
How do i replace the surface element for a glass top cook top range
Before you begin:
Nov 17, 2009 | Whirlpool RF364 Electric Kitchen Range
Opening the cook top in a Whirlpool electric range
The cooktop on this model range will lift up, exposing the surface burners and wiring harness. The screws are located along the bottom of the frotn edge of the cooktop. You will need to open the oven door to see them. Just follow these steps:
Before you begin:
Nov 12, 2009 | Whirlpool RF378 Electric Kitchen Range
Shattered glass top for Hotpoint range/ how to replace
The cook top on your range should come off by removing 2 to 3 screws under the front edge of the cook top. You will need to open the oven door to see them. Once you have them removed the top should lift up. Please ensure you have the range unplugged and/or the circuit breaker turned off before attempting any repairs to the heating elements. Live voltages are still present with the unit turned off. Now...depending on the type and model of your range, the wiring harness may have a quick disconnect type of plug. If yours is so equipped, replacing the top will be a cinch, because you can remove it from the range to work on it. Take the old top and new top and place them next to each other upside down on a padded surface. Placing some towels on a kitchen table or counter top works best. Now all you have to do is carefully transfer the entire harness and burner elements to the new cook top. You should be able to move the entire assembly with all the burners still connected. A second set of hands will make the process go much easier. If your range does not have the quick disconnect type of wiring harness have someone hold the cook top up or prop it up with something. Carefully remove the element mounting brackets from the cook top (with all the elements still attached). Carefully support all the wires as you do so, and lay the entire assembly (elements and wires) on top of the oven cavity insulation. Once you have everything disconnected from the cook top, discard the old one and position the new one in place. Carefully reinstall the elements while supporting the wires. Additional care should noted not to handle the ceramic material of the elements and/or the heat coils themselves. They are very fragile and the oil from your hands can potentially damage the elements and shorten the life of them. Let me know if this helpful to you. If you get stuck along the way, or have any questions, please respond to this posting by adding additional comments.
Sep 07, 2007 | Kitchen Ranges
Whirlpool GR478LXPS Electric Kitchen Range Logo
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
