Question about Philips 50PL9126D/37B 50" DLP TV
Philips TV dim... could this be a bulb? - Philips 50PL9126D/37B 50" DLP TV
  • Philips Master
  • 8,457 Answers
The tv projection lamp been inside the tv like 1 1/2 or 2 years already?Yes,than the tv projection lamp it is the problems and require the tv projection lamp replacement.
Posted on May 25, 2011
  • siouxzq_24 May 25, 2011
    Actually, it;s been like 5 years! Any good ideas on where to get a replacement?
  • Chi Chu May 25, 2011
    Ok let make sure ur tv does used a tv projection lamp,the front of the tv bazel frame beside LED lights like Standby, Power,does ur tv have a LED light that said "LAMP" too and it is lit up?Yes,than 100% ur tv used a tv projection Lamp and it life it is ending.Tries websites like Partstore.com,Ebay.com to buy a new tv projection lamp.
My Samsung tv is dim; has sound and we can see the tv its just very dim. Its not a setting; we already chevjed that.
If the TV unit that you have is a DLP than a bulb in the rear is the likely culprit and is burning out. The bulbs lasts for thousands of hours but over that period the light output reduces.
The procedure for replacing is relatively simple. Use good safety procedures including disconnecting the power cord. My suggestion is you purchase a very good quality replacement bulb installed into the module. You want the brightest bulb to get the best results,
Nov 25, 2015 | Samsung Televison & Video
Where is the service menu for the bulb in the Samsung HL-S5087W DLP
if picture dim it is most likely the lamp and resetting the lamp timer will not help that.
Oct 14, 2012 | Samsung HL-S5087W DLP TV
Ok dumb question but here it goes. Have a Philips 42inch flat panel HDTV. Today I noticed the blue power on indicator light, was no longer blue it is white. TV appears to be working ok, but what is it?
The LED light (the light bulb that isn't actually a bulb), has probably either burnt out or dimmed so that the colour has been changed. Nothing to worry about
Steven Cumming
stevencumming@hotmail.com
Please leave feedback :-)
Jun 05, 2011 | Televison & Video
If the legrand dimmer 400w - pro21 can function with led dimmable light "philips master led spot "
The answer is NO. You need a Trailing Edge dimmer to control LEDs.
The Phillips master LED spot manual says
Lighting controls: bulbs are dimmable 20-100% with ""select"" Trailing Edge RC devices
http://www.prismaecat.lighting.philips.com/FredhopperPDFWebServiceInter/docts/1d8ea75f-e889-424d-92dc-450fbeb85f6a/Smart_LED_Spot_da.pdf
The Legrand pro21 manual does not say anything about being a Trailing edge dimmer.
http://www.legrand.com.gr/gr/gr/liblocal/internet_greece/PDFS/NOTICES/IOBL/ROOSTATES/775637EN.pdf
Legrand diagrams show what appears to be incandescent bulbs, and say nothing about LEDs
LEDs cannot be dimmed as ordinary incandescent (tungsten) bulb.
More reading:
Wikipedia article on dimmers includes technical stuff on Trailing edge dimmers
http://en.wikipedia.org/wiki/Dimmer
2 sites show LEDs bulbs that dim:: both seem new ...
http://news.thomasnet.com/fullstory/LED-Bulbs-feature-smooth-dimming-range-566574
http://www.earthled.com/lumiselect-dimmable-led-light-bulbs.html
Oct 11, 2010 | Legrand On-Q/ ALC 600W Dimmer Switch,...
Replacement Lamps/Bulbs for Philips 50P8341 Rear Projection TV
These are both CRT type TV's(3 picture tubes drive the image) with different screen sizes and the CRT's are not interchangeable
Oct 24, 2009 | Philips 50P8341 50" Rear Projection...
Replacement lamp/bulb for a Philips 51PW9303
Call Encompass electronics 1-800-638-3328 also part # is on Tube you have a RED/GREEN/Blue each tube has part number on it.UNless you have DLP TV then it would be a Lamp.
Sep 19, 2009 | Philips 51PW9303 51" Rear Projection...
I have a 60" Philips 9P6044 C104 rear projection tv. The color seems to be getting weak and the colors seem to blend together. We think we may need new bulbs, but we dont know how to change them out. Is it...
its actually the collant in the CRts that makes the picture appear dim with colors being faded and hard to focus. You can get the CRT coolant kit at the following link which contains the coolant for all three CRTs and the CD with instructions on how to replace the coolant.
http://servicemanuals.vstore.ca/product_info.php/pName/phillips-crt-coolant-replacement-kit/cName/repair-kits
Jun 15, 2009 | Philips Magnavox 51MP392H Rear Projection...
Kolin PT-501
you used a spherical bulb, this TV needs a bulb with a parabolic reflector.
Jun 03, 2009 | Olevia Kolin DLT2711M 27 in. LCD...
How to Change the headlight bulbs for my 1992 Buick Regal
A torque bit screw driver are a philips screw driver should be all you need. JUST MAKE SURE NOT THE TOUCH THE BULB (new bulb) WITH YOUR FINGERS. Your body oil will make the bulb burn out quick!!!! Wear rubber gloves when installing the new bulb. f one is dim, you better change both sides. are the other side will also be dim.
Feb 06, 2009 | 1992 Buick Regal
Projection TV is Dimming...Getting darker with every hour its on
hi rouge. my name is mike wilson. i have a panasonic 50 in that has the same problem as you had on your tv. the screen got halfway dark today. did you ever get yours fixed, if so, would you mind telling me what the problem was? my problem is listed (by mistake as a 53 in) on 04/04/07. thanks in advance
Dec 03, 2006 | Panasonic PT-56HX40 56" Rear Projection...
Philips 50PL9126D/37B 50" DLP TV Logo
214 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
