Question about Sanyo STW0923H2 Air Conditioner Heat Pump
My Sanyo PTAC heather stop working. ac working, fan working .
  • Sanyo Master
  • 43,501 Answers
It could be the relay or the strip heat....
To figure out what is wrong you will need to check if power is getting to the strip heat or not...should have 220-240 V across the two legs going to the heat strip...when the heat should be on.
heatman101
Posted on May 25, 2011
What does it mean when it indicates stop?
Wow, a talking AC?
How to Reset an Amana PTAC - YouTube
? 0:55
www.youtube.com/watch?v=D4SQfFChiKY
Mar 28, 2014 - Uploaded by Total Home Supply If you ever need to reset your Amana PTAC this simple guide will ... HVAC AC Blower not working, troubleshooting Fan Control board, Fan not ...
Aug 21, 2015 | Amana Heating & Cooling
PTAC stops running after a short time
Sounds like a voltage or amp draw issue. So how about if you only try to run the blower??
Jun 05, 2017 | Heating & Cooling
McQuay PTAC stops working after short time
Sounds like you need a new control board with thermistors. you probably have a relay that is getting hot and quitting.
Sep 19, 2014 | Heating & Cooling
Problem with GE PTAC-Model# AZ28E09DABM2 - Why won't condenser kick on when switching to AC from Fan. AC was working fine until today...Fan is still working...Pulled the unit out and could feel the h
Hummm. A bit difficult to solve this problem. Seems like the condenser outside is not working, I mean the fan of the condenser. Looks like you have a wall A/C and a wall A/C always have condensers outside the house and near the A/C. Have you checked if the fan is spinning? I don't think the compressor is at fault but check it anyway. You should be able to hear the compressor running either in the wall unit or in the outside condenser housing. The only heat you should feel is from the condenser itself. If you blows warm air, that means the fan is working, if not that means the fan is not working. But don't be confused with the fan not working because in winter time sometimes the fan is not working and some times it does. As I said, it's a difficult problem to solve but at least start with checking the situation with the fan in the condenser.
Jun 16, 2014 | GE Zoneline Deluxe Series Cooling &...
Sanyo PTAC model STB0823H1 elec. heating element
Try 1st link for Support Request, 2nd link enter zip code
http://shop.panasonic.com/hvac/how-to-buy/distributor-locator.dot
Dec 12, 2013 | GE Zoneline Deluxe Series Cooling &...
Will not switch to cool mode. heat and fan work fine
hi,
regarding on switch mode theres a common line between heating and cooling although fan is always connect on them.,also with the thermostat,the sequence on this when you switch to cooling and your connection is on heater,the contactor will shift to compressor source,so if there is no cooling, the contactor supplying the compressor is not functioning when you switch on cool mode.try to tighten screw on compressor relay maybe only loose.on control panel,or check continuity of compressor if the compressor still good,check also the freon charge using clamp ammeter,this should be done by ac technician.have a nice day
rate me up,thank's
Apr 26, 2009 | Heating & Cooling
Filters needed for Old GE Zoneline 2100
My name is brian pfeiffer . I run a ptac business in griffin ga. I have many parts and filters for most all types of ptac units. Please feel free to contact me at brian@dreamgreenservices.com. Nobody can beat my prices!!!! Or call me at 770-233-9987
Sep 03, 2008 | GE Zoneline AZ38H12DAD Split System Air...
Sanyo STW0923H2 Air Conditioner Heat Pump Logo
184 people viewed this question
Top Sanyo Heating & Cooling Experts
Donni Steen
Dennis Boxerman
Tim Whalen
Are you a Sanyo Heating and Cooling Expert? Answer questions, earn points and help others
