Question about Kenmore 74832 Gas Dryer
I have a kenmore gas dryer the igniter glows flame kicks on and burns for 3-5 min. and turns off, after that the igniter will glow but no flame. What should I check besides the igniter?
  • Kenmore Master
  • 2,605 Answers
Hello, welcome to FixYa.
I'll start by saying your post indicates it is obviously a Kenmore gas dryer, however if you could post the complete model number I can speak directly about possible remedies instead of generalizing.
At the risk of doing so, you mentioned you do get heat intermittently, and the drum does turn correct ?
If this is a symptom where the unit at first begins to heat but the flame drops out in a matter of seconds or minutes I would be looking at the burner coils. This is what you'll be looking for...
Once you've gain access to the coils you'll need to remove the wire harness and check the continuity.
Here's the tricky part though...many times they will ohm out ok when cool (not operating) yet as soon as there is current passing through the coil it "opens". The wire inside the coils is so fine that often it only takes a small current to "open" the circuit.
Most times it will only be one coil that fails but it is good practice to replace them both, many places used to sell them in a kit so double check with your supplier. I've attached a link here, though it may be different than your model the principles to changing the coils are the same.
As far as what part you may need and how to get it. There are a couple of places I prefer, on-line at "searspartsdirect.com" or "repairclinic.com".
Kit contains both the two wire and three wire solenoids. One solenoid is the primary and one is the safety. Both have to operate for the gas valve to open. Usually, one of them burns out as I said but you should always replace them as a set.
**unplug the appliance and turn off the gas supply before attempting any service...safety first**
The most common for Kenmore is part number 3479 at "repairclinic" as this link should provide you.
http://www.repairclinic.com/PartDetail/Gas-Valve-Solenoid-Set/3479
Let me know how you make out or if you require further assistance and I'll do whatever I can. Thank you for your patience while I was away for a while. Good luck.
Regards,
Macmarkus :)
Posted on May 25, 2011
Igniter starts to glow for 3-5 sec while making noise every minute or so
Check the thermocouple it is going bad or already has and that is why the gas valve is not staying open.
Jul 08, 2017 | Whirlpool GGW9200L Gas Dryer
I have a 7yo Kenmore Elite gas dryer w/no heat. I tested all the possible culprits with my ohmmeter. I found the ignitor was not glowing so I replaced it. Now it glows but I still have no heat
The glowing if the ignitor indicates that the circuitry is good but the flame/radiant sensor is bad and/or one or both of the gas valve solenoid coils are not working. The flame/radiant sensor bypasses one the solenoid coils then when power is applied to the ignition circuit, the first coil opens the first valve, the ignitor glows and the flame/radiant sensor gets heated. It's contacts then opens when heated enough to unbypass the second coil and allow the gas to flow and be ignited.
Make sure the flame/radiant sensor is properly in place and aligned with the ignitor to allow proper heat sensing. You may check the continuity between the sensor's contact terminals as the ignitor glows. At first, the terminals should read close (zero resistance) and then open (infinite resistance) after about 30 seconds or so. If this is not the case, the sensor is not working and must be replaced.
The solenoid coils, one with 2 prongs and the other has 3, sitting on top of the gas valves must be both replaced if the flame/radiant sensor turns out good. But before doing so, make sure to run a test with the dryer completely assembled because sometimes the gas do not ignite when the dryer's cabinet is open. This is to prevent unnecessary replacement of the coils.
Feel free to update us about the result and if you need further advice.
Jun 17, 2011 | Kenmore Dryers
I have an Amana Dryer Model # LGD20AW and when the dryer is first turned on the glow plug will heat up and ignite the gas but as the dry cycle continues the glow plug will heat up but no flame will ignite...
The glow coil or glow bar heats up and a sensor on the side reacts to the heat and then sends a signal to a gas valve.(solenoid valve) When the gas doesn't ignite when the coil is glowing... here are some reasons. 1. The sensor on the side of the burner assembly isn't working or sending power to the valve. 2. The valve is getting power but not opening. 3. The ignitor is not glowing hot enough to activate the flame sensor. Usually it is the sensor or the igniter not the valve.
Tom
Aug 10, 2010 | Amana Dryers
Series 80 gas dryer. Turn on and flame only lasts few mins.
Intermittent contact inside one of the gas valve coils. Replace. Part number 279834.
You can order them at AP Wagner. Use coupon "New10" for 10% off
Oct 16, 2009 | Kenmore 75944 Gas Dryer
Gas dryer heat is intermediate
does the igniter glow white or orange? if it is orange you need to replace it. has to be white hot to ignite. if the igniter is white it could be the coils not opening the gas valve all the time - an intermittent problem.
Oct 04, 2009 | Kenmore 73952 Gas Dryer
Kenmore Gas Dryer Model 75731 Dryer Won't Heat
The orange glow is the ignitor. If the ignitor is glowing but the gas does not light then the flame sensor may have to be replaced. If the gas ignites but does not stay on either the flame sensor or the coils are at fault.
See also: http://home.howstuffworks.com/how-to-repair-a-dryer.htm
Sep 21, 2009 | Kenmore 63942 Dryer
My kenmore dryer does heat up all the time.
After the glow plug starts glowing a sensor detects this bright glow and turns on the gas which will be ignited by the glow plug and you have flames.
So, it could be this sensor or in the gas valve solenoids. You will need an OHM meter to check this.
Dec 21, 2008 | Kenmore Elite HE4 Electric Dryer
Gas dryer runs for 3 mins and then no more hot air
mjm_III1,I have the same problem and did what you did (replacing the gas valve solenoid coil). My problem is history.
Cheers!
Jun 28, 2008 | Whirlpool GGQ8831L Gas Dryer
Kenmore 74832 Gas Dryer Logo
153 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
