Question about Acer Aspire One PC Notebook
I tried to use my Aspire one recovery disk but on bootable usb and i get to the Recovery screen, then the system just sit there with caps lock blinking.....? Can someone help me with this issue??? THanks Marc
    Scholar:
  • 81 Answers
Go into system setup at boot, and make sure you have on boot priority the usb drive enabled. it has to be the 1st boot device.
Posted on May 25, 2011
How do i bypass my password for my acer aspire 5532
Bypass Acer windows password?
Now, we'd commend you a professional Windows password recovery software- Windows Password Reset as your reference.
Time: 5 Minute!
Recommend: +++++
As an easy method to reset Windows password , there are only four steps as follow:
Step1: Download Windows Password Reset Deluxe ( http://www.windowspasswordreset.net ) and install it.
Step2: Burn the ISO image file onto a USB flash drive.
Step3: Boot up your Windows PC by the bootable burned USB in minutes.
Step4: Remove the forgot Windows password on the operation interface and logon PC without password.
Jul 19, 2012 | Acer Aspire 5532 15.6" Laptop Original...
I have an hp pavilion dv3 with Windows 7 Premium as my Operating System. I accidentally deleted the Recovery Partition even before I create a Recovery Disk. Right now, I can't use my laptop because it...
If you have a windows installation dvd you should use it. If you don' have you should call hp customer care and ask them to send you the dvd for operating system recovery
Mar 13, 2011 | HP Pavilion Dv3-1075us Notebook
When i turn on my Acer Aspire One D255 it says: "check cable connection! PXE-M0F: Exiting Intel PXE ROM. No bootable device -- insert boot disk and press any key"
The PXE ROM is part of your system's network interface controller. It is being entered on your system's startup to look for a bootable image on a physical network connection and if found, to boot from that image. If there is no network cable connection to your system or if there is but no bootable device is found on that connection, the result is the error message that you got. As to why your system is entering the PXE ROM can be explained by looking at your system's Setup Utility,,,
Press F2 while powering up to enter the Setup Utility and use the cursor control keys to go to the Boot tab which then shows the Boot priority order. The default order is as follows...
1. IDE0
2. IDE1
3. USB FDD
4. USB HDD
5. Network Boot : LEGACY PCI DEVICE
6. USB CDROM
Your system's internal hard disk drive should be listed beside IDE0 and it will be accessed first to look for a boot record. If the drive fails to boot, the next devices in the list will be accessed accordingly until either a bootable device is found or the last item which is USB CDROM. If a USB CDROM is plugged in on one of the system's USB ports, it will be checked for a bootable record and if not found or no CDROM is plugged in, then the system displays the last part of the message -- insert boot disk and press any key.
Press F12 while powering up enters the Boot Menu which has the Boot Option Menu. This menu should show by default the following...
1. IDE 0: (the name/type information for your system's internal hard disk drive
2. Network Boot: LEGACY PCI DEVICE
If there is no hard disk drive information shown beside IDE 0, then the possibilities are that
1. there is no internal hard drive present
2. there is a hard drive but it has failed
If there is hard disk drive information and pressing enter to select it does not result in an operating system startup, then the drive's startup partition has been wiped and so it has no bootable image.
If there seems to be an internal hard drive present but it has no bootable image, you may attempt recovery from the installation images in the hidden partition. The recovery allows restoration of...
1. operating system to factory defaults
2. applications (selectable)
3. drivers (selectable)
Press Alt and F10 keys together while powering up and the Acer logo is showing to enter Acer's eRecovery Management. Follow the instructions to do the recovery.
Feb 09, 2011 | Acer Aspire One Netbook 8.9" Notebook
My kids changed my password and now i have no idea how to get in it now
You may crack the password and login your computer again.
Windows Password Recovery is right what you need in your case. The password recovery tool is designed to reset Windows login password once you accidentally forgot it or have no access to your system including Windows 7, Vista, XP etc. By burning a bootable CD, you can enter almost any computer with Windows administrator login password protected within a few seconds. Here are the step by step tutorial, pretty easy, I am sure you can handle it!
Step 1: Download Windows Password Recovery and install it on another computer.
Step 2: Prepare a blank CD/USB and run the software and use it to burn the ISO file to it.
Step 3: Put it into the CD-ROm and restart your locked computer. Change the BIOS setting of your locked computer to make it boot from the CD-ROM or USB drive. Note: start computer and press F2 or Delete to enter BISO setup
Step 4: Boot your locked computer from the created disk and remove your forgotten password. GOOD LUCK!
Jan 14, 2011 | Toshiba Satellite A135-S4527 Notebook
I have forgotten my windows password for my acer aspire 5315 laptop and cannot log on,is there any way i can restart my laptop or get onto it?
Yes, you get the way. By relying on this password recovery software, you can reset Windows Administrator login password easily. Fully compatible with Windows 7, Vista and XP etc operation system, supporting both 32-bit and 64-bit.
Jan 02, 2011 | Acer Aspire 5315 Notebook
Forgot password to the aspire one notebook
The only option is to do a complete system recovery.
Follow the steps to do recovery.
Power on the netbook and keep tapping Alt+F10.
That will take u in to the recovery mode.
Select complete system recovery.
This process will take around 30 to 45 min and make sure u plug in the AC adapter.
Also note that u will lose all your datas.
Dec 26, 2010 | Acer Aspire 5100 Notebook
How do i reinstall operating system from recovery
SCD=system disk, boot off that. It will start the recovery process.
RCD=recovery disk, will prompt you when to install those. This is the system image to be restored.
Remember, whatever's on there now will be wiped!
Jan 18, 2010 | Acer Aspire 3610 Notebook
Recovery Disk
you can make you flash drive bootable.. the problem is that it might not necessary copy over the recovery cd files properly. Here is a link that can help you: http://www.bootdisk.com/pendrive.htm
Jul 24, 2009 | Computers & Internet
Cant get into the network center on my acer aspire 1 ,
If this is an aspire One with linpus lite linux,
The network center disappearing is an issue with the linux update server that seems to corrupt the OS.
The solution unfortunately is to reload the OS from the recovery disk.
The aspire ONE does not come with an ODD so you will need to use the disk on a unit that has an ODD to make the recovery USB flash drive.
You will need a USB flash drive that has at least 2GB of storage, a computer with an ODD, and the linpus recovery disk that came ywith your unit.
1. Boot to the linpus disk, one of the options should be to make a recovery USB drive, make sure that no important data is on this USB drive as it WILL be formatted and erased.
2. Follow the on-screen instructions and then insert the recovery flash drive in to the USB slot of the Aspire ONE.
3. Re-start the Aspire ONE and press F2 to go in to setup.
4. Change the boot order to boot from "USB HDD" and press F10 to save and exit.
5. Unit will reboot and recovery will start.
Jun 26, 2009 | Acer Aspire One PC Notebook
Acer Aspire One  PC Notebook Logo
60 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
