Master
- Posted on May 25, 2011
Re: My Sirius feed works in my car but not on my...
- Are you using batteries? If so then change them as this can be a problem that causes this.
- If you are using an AC power feed then the problem is more likely related to the antenna placement. Satellite receives work horribly inside unless you place the antenna outside (facing the South. This is where the satellite gives it's signals from.)
- Also the antenna wire may be cracked, so check that good as well.
- The radio is not outdated, it will work fine. Check the power feed and the antenna placement. One or the other should remedy this.
Regards,
Tony
Thanks Tony. I'll try your suggestion.
Best,
Dennis
