Question about Dell 926 All-In-One InkJet Printer
After receiving many "fix carrier
    Problem Solver:
  • 14 Answers
That's most likely a stripper for your fuser. If you can locate the fusing unit, you may see many of these paper strippers. The fuser can run with a few strippers, so if you lose one, just take it off and be done with it. However, if your paper is jamming in the fuser, it might be time for a replacement, as the Teflon is probably worn off your heating roller.
Posted on May 25, 2011
Paper jam 2, check inside
You should troubleshoot jamming error message by removing toner cartrige, check if the little plastic sensors on the paper path are not stuck somehow, reinsert toner,close door, open back door check if the fuser sensor is ok ( and not broken), clean the papertray roller, restart printer and it should work. If that doesnt fix your problem it can be a faulty sensor or some tiny paper left somewhere you can't see and sensor detects .. Hope it helps.
Apr 07, 2014 | Samsung SCX 4521F All-In-One Laser Printer
Having problems with metallic thread breaking constantly. I have adjusted tension up and down. I am using the net over the thread as directed in them manual. The bobbin thread continues to show on
I'm not exactly familiar with your machine but... a few things you should know. 1. You need a metallic thread Needle. or at least one with a larger hole. 2. Check your bobbin carrier, if anything catches or jams between between the spring and the case it can loosen the bobbin tension and make the top show too much bobbin color. 3. If your bobbin spring becomes grooved from the wear of the thread... same thing. 4. If your spring and everything is ok and clean... tighten the tiny screws to tighten the bobbin tension some.
Dec 23, 2012 | Sewing Machines
Error message is " paper
Check for a tiny piece of paper or some toner that may be covering a sensor.
Jan 07, 2011 | HP LaserJet P2055d Printer
I have a carrier jam on my dell 944 printer
Printers have small paper flags (plastic levers) that tell the printer where the paper is, also if the motor that drives the inks up and down the metal bar inside cannot turn (due to an obstruction) you will get carriage jam. Open the lid and check the ink carriage moves up and down freely (maybe the ink cartridge has popped out slightly).
Also see if you cand see these little flags and make sure they move up and down ok. Sometimes they work on a tiny spring that pops out.
If there is no obstruction and you can move the carriage by hand (with the power off of course) and it still says carriage jam then i always have a lot of luck by lubricating the carriage bar (shiny steel bar) with some WD40 or other oil.
Hope this help.
Cheers!!!!!
Jul 23, 2009 | Dell 924 All-in-One InkJet Printer
Front paper jam
Always try to remove a paper jam without tearing the paper.
If torn, make sure no scraps of it are missing.
Lokk for any tiny scraps, esp stuck on paper path sensor.
Apr 17, 2009 | Xante Accel-a-Writer 3N Laser Printer
Optra 2450 error 241
24X Paper Jam message displays, Paper jammed over the Pass
Thru Sensor. (The printer displays the value of X for the paper tray
where the error occurs. Example: 241 is a Paper Jam Tray 1)
That is a quote directly from the service manual. You have a paper jam, or some tiny bits of paper stuck over the pass thru sensor. Remove debris and clean out to fix your problem.
Thanks and please take a moment to rate as fixya.
Nov 10, 2008 | Lexmark Optra S 2450 Laser Printer
Carrier jam on dell 924 printer??
I was able to fix this issue on my all-in-one 944 printer. What happened was that one of the ink cartridge lids had popped open. The hard part was that the carrier was stuck on the far left side, and I wasn't able to pull it over for easer access. However, I was able to fit a finger in and push the cartridge back down. Then when I turned the printer back on the error went away.
Hope this helps
Dec 13, 2007 | Dell 924 All-in-One InkJet Printer
Dell 944 All-in-One Printer - printhead carrier jam
I just found that one of the little feeder rollers (??) on the roller bar has jumped out and is sitting (still attached by its spring) on top of the roller bar. I reckon that's curtains for the printer. Am I right or is it repairable?
Nov 25, 2007 | Dell 924 All-in-One InkJet Printer
Dell 926 All-In-One InkJet Printer Logo
52 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
