Question about Hayward Viper Pool Cleaner
I have a Hayward Viper (Model 5500 bought in early 2004). Last year I had a problem where it would keep spinning in circles (stuck in "turnout" mode). I found the check valve was cracked so I replaced it; problem solved. This year, after running normally for awhile, it will get stuck in "turnout" mode, just spinning in circles like it did last year. I took a look at the check valve, but I can't see anything wrong with it. I opened up the manifold and cleaned it out thinking perhaps that it was getting stuck in the "turnout" position, but that didn't seem to help. I checked the cam gearbox, no problem there (the cam is turning normally). I thought I might just go ahead and replace the manifold (part #AX5500MA) and check valve ( part #AX5000CVA), but I've discovered that Hayward changed the manifold design in mid 2004, and according to at least one website, the new manifold (part #AX5500MA3V) won't work in my earlier Viper model. Any ideas what might be causing the problem? Any help/guidance is greatly appreciated.
SOURCE: Hayward Viper 5500 is spinning in circles
We found the problem to be a faulty check valve. the check valve cost about 25.00. I ordered it from poolcenter.com. The check valve is located by the cam. It's an easy fix. The check valve comes with the hose attachment, but since our hose was ok we just used a tie strap to connect the new check valve to the hose...sliped back into place... and it works like a charm once again. The part number is below. go to www.poolcenter.com
HAYWARD VIPER CHECK VALVE W/ HOSE & TIES - AX5000CVA
Posted on May 12, 2009
john224
  • 1378 Answers
SOURCE: Control Valve handle wont stay in position
The valve should be about $100. We sell it for 90 something. You can rebuild them with gaskets and the spring. There should be a model number on yours, care to post it? Something like SP711, SP714, etc.
www.arrowmotor.net
Posted on Jun 14, 2009
john224
  • 1378 Answers
SOURCE: 2 yr old inground pool Hayward pump louder than
If there is air in the pump it cavitates and can make it run louder, otherwise it is the bearings in the motor.
Posted on Jul 10, 2009
SOURCE: Hayward Viper will no longer turn around once stuck.
The spin-out Cam,you should have got 3 with your viper, are located on the top from front rignt side.You have to remove the top and then you see a small red flywheel thing. There is a white ball in the back where the pressure comes in. I ran a garden hose in and cleaned pressing gently on the ball. Worked for me good luck wuwei
Posted on Jul 12, 2009
SOURCE: the viper is going in circles
I had a similiar problem. I took the sweep motor apart and used a scotch brite pad and smooted the inside of the piston that operates the spinout. I also lubed the o-ring seals with some vaseline before putting it back together. I also used the scotch brite pad on the little plastic part and its mating surface the piston operates.
Posted on Sep 14, 2009
Viper moving very slowly and wont turn
check water flow to unit if ok take apart check hoses and belts
Sep 11, 2012 | Hayward Viper Pool Cleaner
My viper just started spinning in a continuous circle wrapping the hose completely around the cleaner and the bag. It's not a hose problem. It was working OK one day and started this the next.
That sounds wild. I would call the Hayward technical service number at 908-355-7995 and maybe they can figure this out. I hope this helps.
Please vote for this answer. Thank you.
Aug 22, 2011 | Hayward Viper Pool Cleaner
VIPER 5500 SPINS AROUND IN CIRCLES CAUSING HOSE TO GET TANGLED. ANY SUGGESTIONS WHY?
There are a couple of things that you should try if this pool cleaners hose is frequently becoming tangled. Make sure that your floats are evenly and correctly spaced. One float should be 18" inches from each end and a third float located in the middle, 5 feet from either end. You should also make sure that the hose length is not too long for your pool size. Your spin out might be too high. Try moving it to a lower setting and then running the cleaner again.
May 10, 2011 | Hayward Viper Pool Cleaner
Cleaner just spins
If the cleaner is spinning in circles, it a probably a problem with the hoses of these pool cleaners. It was was a common problem with early models, and they have just redesigned it. Lay the hose out in the sun, stretched out, and let it sit for several hours to straighten out the hose. Make sure that you are not storing the hose in a coiled position since they are prone to bend and break.
Sep 01, 2010 | Hayward Phantom Pool Cleaner Complete with...
My pool cleaner is going in a circle in the same direction. I think something is clogged?
I thnk you have hair wrapped around one of the wheels. Check it out and let me know.
Oct 13, 2009 | Hayward Viper Pool Cleaner
Mar 23, 2009 | Hayward Viper Pool Cleaner
Mar 11, 2009 | Hayward Viper with Booster Pump
Viper 791 XV Automatic Start Not Working
Viper Working installed in my 2000 Honda Civic. It's the 791 XV model I nite diagram
Nov 05, 2008 | Viper Security and Remote Start System...
Hayward Viper Pool Cleaner Logo
74 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
