Question about Jl Audio 500/1 Car Audio Amplifier
Why does my green power light blink and my amp not work
  • 1,940 Answers
There are three status indicator lights on the top of the amplifier. These are as follows:
1) "Power" (Green): lights to indicate that the amplifier is turned on and operating normally.
2) "Thermal" (Red): lights to indicate that the amplifier has exceeded its safe operating temperature, putting the amplifier into a self-protection mode, which reduces the power output of the amplifier. The red light will shut off and the amplifier will return to normal, full-power operating mode if the heat sink temperature drops back to a safe level.
3) "Low ω" (Amber): lights to indicate that the impedance of the speaker load connected to the amplifier is lower than the optimum impedance load range for the amplifier. When this light is on, a protection circuit engages and reduces the power output of the amplifier. The amber indicator will also light when a short-circuit is detected in the speaker wiring (this can be a short between the positive and negative speaker wires or between either speaker wire and the vehicle chassis).
There is only one condition that will shut down an undamaged 500/1v2 completely... If battery voltage drops below 10 volts, the entire amplifier will shut itself off. The green "Power" indicator on the top of the amplifier will turn off when this occurs. The amplifier will turn back on when voltage climbs back above 10 volts. This may happen in a rapid cycle when bass-heavy program material causes a weak charging system to dip below 10 volts momentarily. If this is happening in your system, have your charging system inspected to make sure it is working properly.
If your amplifier is blinking Green, and no output is coming out of the speaker, you may have internal damage to your 500/1 Amp.
"My amplifier turns on, but there is no output"
  • Check the input signal using an AC voltmeter to measure the voltage from the source unit while an appropriate test tone is played through the source unit (disconnect the input cables from the amplifier prior to this test). The frequency used should be in the range that is to be amplified by the amplifier (example: 50 Hz for a sub bass application or 1 kHz for a full range / high-pass application). A steady, sufficient voltage (between 200mV and 8.0-volts) should be present at the output of the signal cables.
  • Check the output of the amplifier. Using the procedure explained in the previous check item (after plugging the input cables back into the amplifier) test for output at the speaker outputs of the amplifier. Unless you enjoy test tones at high levels, it is a good idea to remove the speaker wires from the amplifier while doing this. Turn the volume up approximately half way. 5V or more should be measured at the speaker outputs. This output level can vary greatly between amplifiers but it should not be in the millivolt range with the source unit at half volume. If you are reading sufficient voltage, check your speaker connections as explained below.
  • Check to ensure that the speaker wires are making a good connection with the metal inside the terminal block. The speaker wire connectors are designed to accept up to 8 AWG wire. Make sure to strip the wire to allow for a sufficient connection with the metal inside the terminal block.
For immediate assistance please call our Technical Support Department at 954-443-1100.
Otherwise, check this site out for Technical Assistance with your Amp:
http://mobile.jlaudio.com/support_pages.php?page_id=130
Here is your Manual:
http://mobile.jlaudio.com/pdfs/13320.pdf
Posted on May 25, 2011
I turn it on and set it to 375. Why does it just keep blinking?
blinking green red light Electric Kettles Questions & Answers ...
www.fixya.com > Forum > Tags > blinking green red light
Electric Kettles blinking green red light questions and answers. Ask your blinking ...the kettle lights up but won't heat up, just bought it, the on switch shows red, but it isnot working...what to do? ... Chef's Choice 677 Cordless Electric Kettle.
red icon blinking Electric Kettles Questions & Answers - Fixya
www.fixya.com > Forum > Tags > red icon blinking
Electric Kettles red icon blinking questions and answers. Ask your red icon ... Light will not stop flashing Even after descaling and cleaning thoroughly the red lightflashes. Any ideas? ... "On" switch blinks, kettle won't heat Our 4-week old kettle juststopped working. When we ... Chef's Choice 677 Cordless Electric Kettle.
Dec 12, 2015 | Chef's Choice Kitchen Appliances - Others
Epson tx121 two red light and green light blinking
HOW TO SOLVE THE GREEN & BLUE LIGHT STILL BLINKING
Mar 06, 2011 | Computers & Internet
Error code 5100 check printer
This is probably a Canon printer and code. If so, it is the "ink waste pad is full" warning. There are work arounds to keep from having to clean the pad. Here are two methods to eliminate the message. The only other ways are to take it to a repair shop or dismantle the printer and clean the pad yourself. Not advised, This is messy.
This works on many different printers.
Waste ink full reset
These are the instructions which worked for me on my Canon pixma mp470:
1) Close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button. (Do not release the buttons. The LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (Do not release the Power button.)
3) While holding the Power button, press the Resume/Cancel button three times, and then release the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.) During initialization, the LED blinks in green.
4) When the LED stops blinking and lights in green, press the Resume/Cancel button the 4 times. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
5) Press the Power button. The LED lights in green, and the
selected function is performed. (When the operation completes, the printer returns to the menu selection mode automatically.)
6) Power off then back on and test.
mp150 and simular printers:
printer powered off but connected on power source , you must:
1. Press & hold stop/reset button, and then press & hold [ON/OFF] button.
2. When Green power lit, leave stop/reset button & press twice stop/reset (see orange indicator).
3. Leave On/Off button. Printer in actually service mode.
4. Press stop/reset 4 times (see orange indicator) if not blink restart above process from top.
5. After press stop/reset 4 times successful press On/Off button 3 times. printer will off.
6. Press On/Off button.
Jan 22, 2011 | Office Equipment & Supplies
I have a road pro rppi converter light links
It blinks because your computer is drawing too much current. Most of these give an exaggerated wattage range, and never give details about the true amperage available. the average laptop uses 3.0 to 4.X amps and is too much for these mini inverters. But they work fine on cell phone chargers.
Mar 24, 2010 | RoadPro AC/DC Power Inverter 80/100w
Rapid green blinking green light on monitor and power & no video
try to acces the menu and to reset the display settings.
try another monitor on your computer to be sure that your video board is working, and if it is change the resolution in 1024X768 and try again your dell display
Oct 27, 2009 | Dell UltraSharp 2001FP 20.1" LCD Monitor
I have the same green light blinking issue. the tv won't power up
ouch, it cost them $300 to have the chassis rebuilt, if they want that kind of money kick it to the curb.
Aug 17, 2009 | Mitsubishi WD-62725 62" Rear Projection...
Blingking light on my motherboard, no power.
Chances are your power supply and computer is fine! From other forums on this problem (which I also had), I've learned the following:
1. If you unplug the computer for a half hour or so (the blinking green light will gradually slow down and quit) and plug it back in, the situation will correct itself and the green light will be steady; however if this does not work,
2. a reset that works for a lot of people with the blinking light problem involves leaving the power supply plugged in and unplugging the power supply connection at the motherboard (it usually also has a blinking green LED) and plugging it back in. To read up on how to do this, Google "blinking green light on computer power supply" and read through some of the forums and you'll come on more specific instructions. Usually, you have to wade through everybody telling you to replace the power supply or your motherboard is fried. It's worth a try for a quick fix, just in case those situations don't apply!
May 30, 2009 | Sony VAIO VGC-RB42G PC Desktop
SONY KDF-E55A20 5 red blinking lights on power button
Symptom shows Lamp is weak in result and causing restart of TV again and again. Your TV requires new lamp as per following part number...
A1085447A* LAMP BLOCK ASSY XL-2200U
It is available in Sony Accessories Store for $200 and replacement procedure is written in instruction manual of TV.
Always buy Sony original lamp for TV and avoid aftermarket / cheap lamp for TV safety.
May 18, 2009 | Sony KV-36FV26 TV
Green light blinks slowly on my JL Audio 300/4 amp
Check your fuse at the battery. While AGU glass fuses "look" good, when you read the voltage AFTER the fuse, you can only be getting 5 volts or so. I can't tell you how many times I have seen this.
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Jan 27, 2009 | Jl Audio 300/4 Car Audio Amplifier
Jl Audio 500/1 Car Audio Amplifier Logo
445 people viewed this question
Top Jl Audio Car Audio & Video Experts
Mark Skinner
Tygh Duval
Tygh Duval
hoyzee1
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
