Question about Whirlpool Washing Machines
Auger not working during washing - Whirlpool Washing Machines
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 239 Answers
You likely need a new set of agitator dogs. The video below will show how to replace them and the part is available at the link below.
Agitator Dogs $1.39
Repair Video
Kelly
Posted on May 25, 2011
Ice machine not getting water
Change the dual water control valve if not getting water during cycles.
Sea Breeze
Jun 08, 2012 | Kenmore Refrigerators
Maytag LAT2301AAE Washer: The auger separates from the agitator. The auger then "floats" and does don't agitate back and forth. It appears the "teeth" inside the auger are worn out. ...
You will need to type into your search engine/web browser '(make) washer spares' and you should be presented with a number of sources from which you can order. During the process you will be asked for the actual model number.
Alternately you could try telephone directories for spares suppliers but I would think the former would be more successful.
Good luck,
John C
Mar 17, 2011 | Washing Machines
Aggetator not moving during wash cycle, why
Does the agitator have an auger at the top, if so you will need to replace the agitator dogs in the auger section. Part #80040 If no auger is present you probably have a broken motor coupler.Part #285753A
May 18, 2010 | Roper RAS8244LQ Washer
The agitator is no longer attached
There is a small set screw located lower on the agitator. Locate the set screw and tighten. This should solve the problem.
Jan 05, 2010 | Maytag Washing Machines
Whirlpool Quiet Wash II center pole doesn't spin.
No. This is commonly caused by worn agitator dogs. The upper portion of the agitator (called the auger) has a cam assembly with small agitator dogs that act as a clutching mechanism to drive the auger during the wash cycle. They wear out over time and need to periodically be replaced. The following link explains what they are and how to replace them:
http://www.fixya.com/support/r823955-replacing_agitator_dogs
The part number is included in the link I provided. You can purchase replacements at appliancepartspros.com for about $5. For a little more you can purchase the entire cam replacement kit which includes the dogs, cam, seals and washers.
If you have any questions, please let me know. I hope this helps you.
Oct 04, 2009 | Washing Machines
I have a whirlpool washer and the upper agitator (the one that is supposed to move the clothes down) is not working. What shall I do?
You need to replace the agitator dogs. Yes, there is such a thing. This is a very simple repair that should take 30 minutes or less. The following link explains:
The dogs are located under the Auger (thats the top portion of the agitator). They are plastic teeth that act as a clutching mechanism for driving the auger during the wash cycle. Over time they simply wear out. The part number is included in the link I provided. You can purchase replacements at appliancepartspros.com for about $5.
If you have any questions about this repair, or need additional assistance, please let me know. I hope you find this information helpful.
Sep 10, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
What is the purpose of the washer and where does it go on the Oster kitchen Center food grinder or pasta maker? I keep them both in the same box and I'm not sure which one the washers go to. Thanks
The purpose of this washer is to reduce the friction between the auger and the body of the grinder head. During the grinding process the auger is pushing food/meat forward to the disc and respectively reacting itsef backward. So, the washer goes over the back shaft of the auger as a surface of the contact with the body. You have to put it over this shaft before assembing the auger with the head body. The pasta maker attachment and the grinder both have identical augers.
Apr 10, 2009 | Rival 2275WP Food Processor
Washing machine repair
you have a bad motor coupling( this machines equivelen to a belt) part number 285753. you can search you tube for a videio on hoe to acess the motor coulpling, easy enough repair so long as you have basic mech. skills and tools need onlya phillips, regular slotted screw driver a,d perhaps a 1/4in nutdriver/socket
Oct 30, 2008 | Kenmore Washing Machines
AGITATOR
You are missing the coupling that holds the agitator to the shaft.
Aug 24, 2008 | Amana NAV5800A Top Load Washer
My whirlpool top loader won't agitate.
Ok, sorry it took so long to write.  You listed the washer as a Calypso, but it didnt look righ, so did some investigative work for you.  What your describing I believe, is that the agitator top half (or the auger as well them) is sitting still and the bottom half if moving.  During the wash cycle, the top half is just sitting still.  If this is wrong, please let me know.  If this is right, you have a sort of simple fix.  Remove the top cap of the auger, pry gently between the cap and the agitator, the plastic cap will come off.  When you remove the cap, you will see another cap (sometimes you do, sometimes you dont) it will be white or dirty clear in color if its there.  You can put your finger on the lips and lift it straight off.  Then you will see a cap with a bolt in the center.  Remove this bolt (7/16" with long extension).  the agitator dogs (Sears part #387091) 387091.jpg.  You should see these under that last cap tha had the bolt in it.  Remove the auger (just slide it up and off), remove the dog holding cap.  Remove the dogs, but be sure you remember the way they go back in.  Next is the tricky part.  Take the cap upside-down, and place it back in the auger.  Quickly turn it back over, making sure the ag dogs dont fall out of position (you will be hating me the first couple time, just keep at it), then, with a long pair of needle nose, place the bolt you removed back in the hole.  Take your extension with socket, hold the bolt firmly, and slide the auger back on to the top of the agitator.  Make sure the locks and stuff fit right between the two.  Tighten the bolt (just snug, DO NOT OVERTIGHTEN, you will split the cap).  If all goes well and right, you should be able to roll the auger one way and not the other.  If you need any further help, or need someone to yell at when the dogs keep falling out, give me a shout, and we'll help you along.  Good Luck!!!!!     Jim
Oct 12, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Washing Machines Logo
21 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
