Question about Pyle PLCD15MR CD Player
Where can i get a replacement wiring harness for my Pyle brand marine cd player, model # PLCD15MR? I believe I need to replace it because radio shuts on and off every time boat moves due to red wire that comes out of the back of the harness being loosely connected inside the harness. I think this red wire that affects the power on/off is a ground if that makes any difference. So, how can I fix if possible, or where to get replacement besides PYLE? they dont have any..
3 Suggested Answers
blueextc3221
  • 15935 Answers
SOURCE: Having trouble installing my Pyle PLDBT30U
your part number is Metra 70-5520
It is a standard Ford plug, but is used on your car as well.
Only 1 plug is necessary
See link - http://cgi.ebay.com/FORD-2003-2007-HARNESS-METRA-70-5520_W0QQitemZ170248469364QQcmdZViewItemQQptZCar_Electronics_Installation?_trksid=p3286.m20.l1116
i dont think this model has a premium sound upgrade.... could it be a changer cable?
Posted on Dec 28, 2008
RaidX
  • 632 Answers
SOURCE: My Pyle PLMRXT33WT marine radio keeps turning itself off.
This could be due to a short in one of the speaker connections or a bad/blown speaker which is shorting out.
Posted on Jul 31, 2010
PYLE PLCD15MR radio/CD/etc/ Power problems is that there's no power. Connected directly to fully charged (12.3v) car battery. Can't get it to turn on. Double checked everything. Fuse is good. Control...
hello there ,firstly to rectify the power source remove front panel using a multimetre connect (red) positive to pin 1 this is the top pin as you look at the front panel connect (black) negative probe to the 3rd pin and see is there power registering ,if no power is found place front panel back on radio ,remove power block from back of stereo look for the power source wires red/black you will see the pins for these in block test with metre ,make sure while your testing for power the ignition is turned on at all times ,if you are not getting power here there is a faulty wire or the main fuse for radio,has blown this can be located either on the driverside neath the steering column or passenger side check all these fuses aswell ,another thing you could try if all fails try another radio that you know is working this will aliminate power problems ,hope you get it working let me goodluck
Mar 21, 2011 | Pyle PLCD15MR CD Player
Jul 31, 2010 | Pyle AMFM CD DET MARINE RADIO R/C
Broken wire in wire harness clip
i'm not sure what part is broken from your description but i will try to help...
you can purchase something called a reverse harness that looks identical to your vehicle's OEM harness that plugs into the factory radio. the only difference will be the wiring color on the new harness will be standard aftermarket wiring (ie 12volt yellow, ign red, ground black, etc.) and if you cut each wire from the OEM harness and solder it to the reverse harness location for location then the new harness will be good to go. i would personally do this as a single wire at a time so you are not staring at 16 cut wires going to the new harness. check at Best Buy and see if they carry the 71-1770 Metra wiring harness and that will be the one you need as the reverse harness and if you are installing an aftermarket radio get the 70-1770 also. if you aren't comfortable with all this your local installers should be able to do this job for you pretty reasonably.
Aug 18, 2009 | Pyle PLTDN71 Car Video Player
Replacement wiring harness for pyle pld5mu
1-888-318-PYLE Ask for tech support they will sell you one.
Mar 10, 2009 | Pyle PLD5MU Car DVD Player
Wireing a Pyle CD player to a honda civic 94
Please reply with a model # and I can help you out.
Usually pink is reserved for Parking Brake Bypass wire.
Is this a DVD player? or Standalone CD?
Solid Blue is amplifier turn-on wire.
(sometimes power antenna wire on cheaper 1-wire brands)
But again, reply with the radio model # and I can help further.
Jan 20, 2009 | Pioneer DEH-P350 CD Player
Replacing tape player with cd player
you will need the replacement harness for your model year which is available at pep boys auto or advance auto
Nov 28, 2008 | 1999 Honda Accord
Pyle PLCD15MR CD Player Logo
23 people viewed this question
Top Pyle Car Audio & Video Experts
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pyle Car Audio and Video Expert? Answer questions, earn points and help others
