Question about La Crosse Technology Ltd WT3126B 12" Atomic Analog Wall Clock
I have a jastek clock with a lcd screen for the date and temp. hoe do I set this? It only has a 'set' , 'up', and 'down' button and nothing seems to be working?
Set time of day
Clock then the up/ down temp buttons
Jul 15, 2016 | Kenmore Kitchen Ranges
Tip
Change time and date
Hold down the time or month/date buttons, then press either of the '<< or >>' (by CD controls) to move the time, or month/date. To change the year hold down both time and month/date buttons together to adjusting the year using the '<< or >>' buttons.
on Sep 04, 2013 | Brookstone CKD5810A Clock Radio Smart Set...
Tip
How to adjust the LCD's time and date on Logitech MX 3200
To adjust the LCD's time and date:
  1. Make sure that the time and date are shown on the LCD. If necessary, press (FN + F9) until the time and date are shown on LCD.
  2. Press (FN + F10). You are now in 'Set mode' (you can exit this at any time by pressing the Esckey).
  3. Set the correct hour by either typing the numbers on the numeric pad or using the cursor up and down keys, followed by Tab or Enter.
  4. Set the correct minutes by either typing the numbers or using the cursor up and down keys, followed by Tab or Enter.
  5. Choose either 12-hour clock or 24-hour clock by pressing the cursor up or down keys to switch between the options. Then press Tab or Enter.
  6. Set the correct month either by typing the numbers or using the cursor up and down keys, followed by Tab or Enter.
  7. Set the correct day either by typing the numbers or using the cursor up and down keys, followed by Tab or Enter.
The time and date on the LCD should now be displayed properly.
on Nov 10, 2008 | Logitech Cordless Desktop MX3200 Laser...
Am I missing something simple? Read the manual and can't set the time or date on KDC MP628.
Step 1:
In standby mode:
Enter Menu mode:
Press the [MENU] button for at least 1 second.
"Menu" is displayed.
Step 2:
Select Clock Adjustment mode:
Push the Control knob to [FM] or [AM].
Select the "Clock Adjust" display.
Step 3:
Enter Clock Adjust mode:
Press the Control knob for at least 1 second.
The clock display blinks
Step 4:
Adjust the hours:
Adjust the minutes:
Push the Control knob to [Back Search] or [Forward Search].
Step 5:
Exit Clock adjustment mode
Press the [MENU] button.
Step 6:
Date Adjustment...
Select Date Adjust mode
Push the knob to [FM] or [AM].
Select the "Date Adjust" display
Step 7:
Enter Date Adjust mode
The date display blinks.
Step 8:
Selecting the item (day, month, or year) to
adjust
The items that are blinking are items that can be
adjusted.
Step 9:
Adjust each item
Step 10:
Repeat step 8 and 9 operation and adjust the
date
Step 11:
Exit Date adjustment mode
Step 12:
Setting the date format.
Select Date Mode
Select the "Date Mode" display.
Step 13:
Select the date format
Step 14:
Exit Menu mode
Hope this helps.
Cheers,
Scott
Jan 14, 2013 | Kenwood KDC-MP628 CD Player
Have a new ULTRonic Global clock. Came in a box, well packed but apparently no setup instructions. Have been able to set the clock after much guess work. Temperature, Humidity and trend seem to work....
This is for Ultronic LCD clock/weather gadget.
keywords (from display)
Ultronic forecast week day humidity temperature trend comfort level
- DOWN = toggles F/C temp
- UP = toggles alarm
- MODE = selects date/time display
- hold down MODE to enter "set" mode for data currently displayed
- use momentary MODE to choose target item
- use UP/DOWN to change item
Nov 01, 2011 | Watches
I just purschased an Lg 26LV2500 and I can't get the military time off the screen when it is first turned on. I've set the clock manually with the month, date, and year and I've set the hour...
When you click on the clock icon the clock setting menu comes up scroll down to the bottom of the list if it is available it is two lines below the options on screen and change it to am\pm press return go back up the list and click option to set clock set clock press back /return then exit
May 14, 2017 | LG Televison & Video
I want to set the clock on my keyboard and I do not know what button to push
Apr 15, 2011 | Logitech MX5500 Keyboard/Mouse
Curtis and Co. Big Time 3 zone watch w/ temp gauge. What does the stem positioned at aprox 10 O'clock control? It is near the temp guage but does not seem to control anything.
Crown(stem) at 10 O'clock has air inlet for temperature, does not move. Crown at 8 O'clock is for setting 3rd time zone next to it. The two buttons on the right of the case, above and below, set 2nd time zone which is at the 6 O'clock position of the large dial. To set #2 push top button till min. hand moves 1 min., then push bottom button to move 1 min each time or hold for rapid movement. Large crown sets date and large dial. Unscrew it (counterclockwise) then pull out to first click, then set date turning crown clockwise, continue to pull out till 3rd click which is where you set the time on the large dial.
Dec 29, 2010 | Bulova Watch
Want to change keyboard clock
Sep 11, 2009 | Logitech Cordless Desktop MX3200 Laser...
Setting clock and date on logitech mx3200 wireless keyboard - need instructions
Aug 18, 2009 | Logitech Computers & Internet
La Crosse Technology Ltd WT3126B 12" Atomic Analog Wall Clock Logo
56 people viewed this question
Top La Crosse Measuring Tools & Sensors Experts
john milligan
Are you a La Crosse Measuring Tool and Sensor Expert? Answer questions, earn points and help others
