What is the size of this air conidotioner model number ESA3109-L
  • 5,159 Answers
Do you mean the amount of energy that it uses? It is a 10,200 BTU air conditioner and is recommended for a space of 475 sq. ft.
If you mean the dimensions of the window unit itself when installed, then the space between the window casings must be between 24 1/2" and 38" wide. The height is 14 9/16" and the depth is 20 5/32". The AC unit itself is 14 3/8" x 19" x 20 5/32". See page 15 of the manual (16 of the pdf) for the entire set of dimensions.
Retrevo has the manual avaiable here: http://www.retrevo.com/support/Haier-ESA3109-L-Air-Conditioners-manual/id/23148bh150/t/2/ . You will need to enter a code to download the PDF.
I hope this helps.
Posted on May 25, 2011
My ac is directly under a second floor ac, and water drips down constantly, now when I plug in the ac it shows E 1 on the display
The "E1" code indicates a compressor sensor failure. Did the dripping water from above cause the problem? Possibly , but there's no way to prove it. If you'd like to order the part and replace it yourself, call 800-313-8495. Have your Model Number & Serial Number handy when you call. If the unit is still under warranty and you have your dated Proof of Purchase call 1-877-337-3639.
Hope this helped you and tanks for choosing FixYa.
Aug 08, 2011 | Haier ESA3109 WallWindow Air Conditioner
I HAVE STYROFOAM INSIDE THE AIR CONDITION DO I NEED TO REMOVE IT
Is it packing or is it insulation? If packing, as in you just bought this unit and have never used it, remove it.
Aug 05, 2011 | Haier ESA3109 WallWindow Air Conditioner
Hello, I have a Haier ESA3109 10000 BTU ThruWallWindow Air Conditioner, and some how in moving, a hole was punctured thru one of the coils. We fixed that problem but all the ac freon has leaked out. How...
Its not that simple You need to vacume the system down before you can chagre it again. You will need a tech to do that for you . sorry but thats the way its done
Jul 23, 2011 | Haier ESA3109 WallWindow Air Conditioner
The AC is on. Set at 61 deg. Keeps going back up to 81 deg. Blows cold for only 3 min. Any ideas?
You can try unpluging it to reset it .. this is a tough one as i not to certain.. But try that wait for about a munite nbefore you plug it back in.
Jul 19, 2011 | Haier ESA3109 WallWindow Air Conditioner
The top and bottom coils ice up and there is no cold air. i'm not sure of the model #. what causes that and how to fix it?
Hello, the coil will freeze either due to low airflow or a low refrigerant charge. Many times a dirty air filter or dirty evaporator coil will cause ice to form and cleaning both will fix the problem, however if the unit appears clean then a low refrigerant charge is the problem and the unit will need to be recharged.
Jul 07, 2011 | Haier ESA3109 WallWindow Air Conditioner
Error code E1. Please tell me what E1 refers to.
Unfortunately. Haier does not have an online manual for your model AC. However, if you contact their Customer Support Dept 1-877-337-363, they can tell you what the code means and supply you with an Owner's Manual for future reference.
Hope this helped you.
Jun 28, 2011 | Haier ESA3109 WallWindow Air Conditioner
When I turn the air conditioner off or on it makes a noise sounding like it is coming from the fan. It sounds like the fan might be loose but I'm not sure. What is the problem and what should I do?
Hello, you would need to take the top cover off the AC and check the fan, usually the hub of the fan breaks and becomes loose or sometimes just the clamp comes loose and the fan hits the housing. If the fan is cracked then you would need to replace just the fan on the unit. Here is a link or parts to your ac http://www.partstore.com/Model/HAIER+AMERICA+TRADING/Haier/ESA3109.aspx.
Jun 13, 2011 | Haier ESA3109 WallWindow Air Conditioner
DOESN'T SEEM TO BE COOLING VERY WELL
start by checking the air filter and clean if dirty, also I would recommnd spraying a coil cleaner on the evaporator coil and clean it. If the unit appears clean then most likely the unit has a leak and will need to be recharged with refrigerant.
Jun 07, 2011 | Haier ESA3109 WallWindow Air Conditioner
10,200 BTU a/c blows air but not cool air
They can freeze up if the outside air is too cool. It needs to be over 65 degrees outside and inside. Another possibility is if the unit is a little low on refrigerant. They will run too cold if slightly under charged or if the condensor is very dirty and the heat can not be exhuasted.
Aug 27, 2009 | Heating & Cooling
Heating & Cooling Logo
163 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
