Question about Cameras
I have a pbt303 to pair to my iphone - Cameras
How do I pair my iPad as the second device
Make sure that the headset is not paired with the iPhone (turn off Bluetooth on your iPhone temporarily). Follow the same procedure you used to pair the iPhone, but this time with your iPad.
Dec 26, 2014 | Radio Communications
Can't pair iPhone on 2005 BMW x5
did you mean via bluetooth? if yes please remove saved car kit devices from you phone and then try again with correct pass-codes
Sep 09, 2014 | Apple iPhone Smartphone
Why won't my new iphone 5s pair with my Cardo scala G9x? My iphone 4 pairs very easily.
believe that it is because the 5s is digital and the 4 is analog--we install blue tooth systems in cars and had to replace most of them because of the release of the 5s--older blue tooth system are analog so are not compatible with the 5s--as probably is what is your problem
Jul 27, 2014 | Apple iPhone Smartphone
Paring iphone 2013 huyndai elantra
I had no problem pairing my IPhone 5S. I was even able to pair my old IPhone 4. I tried the old IPhone 4 after seeing this post. what kind of problems are you having pairing the IPhone and what version is it? All I did was turn my Bluetooth on on my IPhone then i pushed the black hone button then hit the settings button on the phone screen then pressed the pairing button then pressed the add to button, once the phone is found it should show on IPhone as Elantra on the IPhone and put in the passkey that it shows on the Elantra screen ( factory default is 0000 ) then the screen in the Elantra will show pairing. then it's paired. then you can go through all the setting after the phone is connected. Just make sure before you get into the car your BLUETOOTH is turned on on your IPHONE or it won't connect till it is turned on and the phone won't connect while your foot is on the brake if you have push start.
Apr 21, 2013 | Hyundai 2013 Elantra Limited
H681 wont' pair with iphone
Select YES to pair. Enter the passkey 0000 and select OK.
if you have any OTHER devices paired remove them.
1 reset network settings on iphone
2 power off blue tooth device
3 power cycle iPhone
4 attempt to re-pair
Jan 09, 2011 | Motorola Mobility H681 Bluetooth Headset
Bluetooth connection issues between paired iPhone 3GS and Mac.
i depends on your service plan pre paid or contract pre paid phones are not allowed pairing
Mar 25, 2010 | Apple iPhone 3G
Pairing a Parrot CK3100 to Iphone 3GS
My iPhone 3G is now connected. Did 3 things:
1. Deleted every existing paired device on the Parrot CK3100.
2. Pressed all 3 buttons at once. Parrot CK3100 screen lit up and buttons lit up after about 5 secs. Turned car engine off. Parrot switched off. Turned car on again.
3. Went to settings, advanced settings, pair device (and also switched on iPhone bluetooth) and tapped Parrot CK3100 on the iPhone screen (which had now appeared) - phone connected.
After about a minute sync iPhone phonebook appeared on Parrot.
Hope this is helpful.
Jun 27, 2009 | Apple Cell Phones
BlueAnt pairing with iphone...help
Just got off the phone with Apple and Blue Ant tech support.
If everything is workon g on both devices you probably need a memory dump on your headset.
1. Power off both devises
2. Power on iphone
3. Power on blue Ant - not in pairing mode - you should see 1 blue blinking light on MFB
4. Make sure iphone bluetooth is on and searching for devices
5. On Blue Ant, hold both volume buttons and MFB at the same time until you get a fast blinking blue light.
6. Check iphone it should now recognize device.
7. When Blue Ant shows up on phone press it so it completes the pairing priocess
Jun 24, 2009 | Blueant Z9 Wireless Headset
Cameras Logo
60 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
