Question about GE Heating & Cooling
What is the ton rating of a 1979 GE heat pump model BWR942A100A1 ?
  • GE Master
  • 3,361 Answers
3 and 1/2 tons.
Posted on May 25, 2011
CPJ18-1B Goodman heat pump. has a slow leak. I need to know what Ton or BTU to replace it with.
you have a 1.5 ton. 12000 btu's per ton. your model number has an 18 in it. tells you 18000 btu's
Apr 13, 2017 | Goodman Heating & Cooling
Where are the heat strips on a rheem classic 10 seer heat pump
3 Ton Heat Pump Split System ' eBay
www.ebay.com/bhp/3-ton-heat-pump-split-system
eBayGoodman 3 Ton 14 SEER Heat Pump Split System GSZ140361 with Installation Kit.10k Heat Strip,Thermostat,Wiring, Disconnect Box,Pad. $1,912.00; Buy It ...
Jul 28, 2015 | Heating & Cooling
Heat pump manual
it is a 5 ton 10seer unit. the new standard is at least 14 seer so there are better options out there
Feb 05, 2014 | Weather King Heating & Cooling
WHAT SIZE IS HEAT PUMP Q3RA-036K
Hello, this is a 3 ton unit. There are 12,000 btu per ton. The number 36 in the model number represents rhe tonnage of the heat pump, so 12,000 x 3 = 36,000 which is 3 tons.
May 09, 2012 | Heating & Cooling
I have a GE model No. BTN 748A100A1 (central air outside unit). Serial number 40564128. When was it made? What is its efficiency? It now handles #1950 sq. ft. Cab it handle 2950 sq ft when I remodel?
GE stopped making AC units probably 20 years ago. The same unit will not handle an additional 1000 sq. ft. I believe it is a four ton unit and about a 6 SEER rating which is way down on the efficency scale. You will need a 5 ton system to handle 2950 sq. ft. The average SEER rating now is 13.5.
Oct 07, 2009 | GE Heating & Cooling
Till what outside temp is the 8Kw heating output
Are you referring a to an electric furnace providing the heat, the heat pump providing the heat, a heat pump providing heat usually with an auxillary/emergency electric heating unit, or an air conditioner with an electric furnace attached? If your system normally uses a heat pump for the heat normally, there is an eletric auxilliary heater. You'll probably need to turn it on at the thermostat manually when the outside temp gets below 40 degrees. If you have it nice system, it might do it automatically. If you're referring to the electric heater being rated 8 kw, it'll run using 8kw when you turn it on. It doesn't have the ability to change what heat rating it is. If you're refurring to the heat pump system being rated 8kw, you're probably mistaken. A heat pump might possibly consume 8kw to run the system but that can't be a measure of the system's capacity. Heat pump measurement units are rated in tons, but the system will always run at the same ton capacity whenever it's on, provided it doesn't need any maintenance. Some commercial air conditioning and heating systems have to ability to modify their power output based on the outside temperature, but I doubt you're dealing with that kind of thing.
Sep 17, 2009 | Heating & Cooling
Tonage or BTU/hour rating from Ruud name plate
See this link
http://www.epinions.com/specs/pr-GE_Zoneline_AZ55H07D_Air_Conditioner
Its say 7100 BTU/hr
Jun 05, 2009 | GE Zoneline AZ55H07D Air Conditioner
Need to know unit size
ckl60 5 ton about a 2003 model on most ac heat pumps the model number reflects the ton sized by 12000 btus per ton also as for the indoor unit cfm rating 400 cfm per ton
May 14, 2009 | Goodman CKL60AR60 Air Conditioner
Model #uacc 030jas - BTU/H and SEER
that is a three ton unit and most likely a 10 seer rated seer rating are posted 6 months in cool and 6 months in heat to get the number on the unit if you are more interested in heating rating of heat pumps the aher or annual heating efficiency rating is of the most importance in this category the unit posted very well
Nov 14, 2008 | Ruud UBHC Air Conditioner
Heating & Cooling Logo
55 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Lawrence Oravetz
richie46
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
