Question about Refrigerators
Kitchenaid SxS fridge Mod# KSRP25FNBT00 unit never cycles off, freezing food on fridge side
  • Jerry Kerns May 25, 2011
    Would this keep the fan running contiously and never shutting off?
    Thank you!
  • 11,800 Answers
This fridge uses 2 separate compressors with 2 separate cooling circuits. If the compressor for fridge section is constantly on then its commanded like that by the control board and the fault is in it: either the thermostat is faulty, the power relay has failed and it's stuck on activate or - worst case - the control processor has failed and the entire board will have to be replaced.
To find out which you must access the board and check the thermostat and the relay. If you need to replace the relay you can buy a separate one and solder it on the control board. If it's indeed the processor the one that failed you can get a new one from here
http://www.partselect.com/ModelFrames.aspx?ModelID=659249&ModelNum=KSRP25FNBT00&ManufactureID=3&Selected=T8HMKLKV&Position=2&mfg=Whirlpool&Type=Appliance&Mark=2
Posted on May 25, 2011
  • Azrael SRL May 25, 2011
    Sorry, the address got chopped
    http://bit.ly/kqj692
    Brigadier General:
  • 3,917 Answers
Try adjusting the temperature of your unit. Keep it within 37 and 42 degrees. Actually the fridge gets its cold air from the freezer through a vent (damper) between the freezer and fridge. The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp control. Make sure it's opening and closing when you adjust the fridge temp.If the damper door motor is damaged or is just stuck open causing too much air to flow into fridge side. Damper door is located at the extreme top-back-left corner of the "fridge" side .If the temperature is too low and you can't make it warmer by adjusting the thermostat, you can also have a defective thermostat. If so, you need to replace it, because they cannot be repaired. Other possible problems are a leak in the sealed (refrigerant) system, cold air migration (in side-by-side models). In this case you need to replace the damper assembly.
You can order your part from repair clinic. However these problems can be verified and diagnosed by skilled professionals.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Kitchenaid side by side fridge is freezing food
you have a bad damper assy.when it gets cold enough in the fridge section the damper door closes so the cold air can't blow in from the freezer side,the door isn't closing allowing the cold air to keep coming into the fridge side 2220377 part number and this is electronic damper.if you order it from repair clinic you have 365 days to return it if it's damaged or it isn't your problem they will take it back,i'm 99 percent positive that this is your problem,when i would call the customer and get model number and ask a few questions i would take this with me when i go to the house from the discription you're giving.
Dec 05, 2013 | KitchenAid Superba Architect KSCS25INSS...
My KitchenAid Subra fridge. it seems like the freezer is always producing cold air. It keeps the freezer so cold that it freezes the drain plug were the condensation is suppose to drain out of the freezer...
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Mar 23, 2011 | KitchenAid Refrigerators
My SxS model 25 GE fridge is freezing food on the fridge side. I have turned it down to 1 and it still freezes the food.Also my water dispenser does not work. Can the 2 problems be related? How can these...
heatman101
Jan 05, 2011 | GE GSS25LGM Side by Side Refrigerator
Amana fridge (mod #sxd22s2) is freezing foods on bottom level- dial turned to lowest setting & temp. is 28 to 32 degs.at bottom of fridge.
seeing that 32 is freezing point of water,its not suprising that food is freezing.it should be 38f or +3c.when was the last time you did a FULL defrost(NO HAIRDRYERS PLEASE).ALSO CHECK DOOR SEALS ARE TIGHT ALL ROUND.
Nov 27, 2010 | Amana 22.6 cu. ft. Side-By-Side...
36" SxS not cooling
unplug it for five minutes... if it dosent come back on the pc board must be replace....
Apr 09, 2010 | GE Monogram® ZISS420DMSS Side by Side...
Food freezing in fridge compartment in my side by side
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Jan 26, 2010 | KitchenAid KSCS25FKSS Side by Side...
Kitchenaid side by side too cold. Freezes everything.
the damper motor on the refrigerator portion is not working properly
Apr 04, 2009 | KitchenAid Superba Architect KSCS25IN Side...
We have a bosch air flow fridge freezer
It's stopped completely
It's not cool
Cooling is poor
It's noisy
It leaks
The freezer compartment is icing up
The food in the refrigerator freezes
There's water dripping inside the refrigerator
The refrigerator never cycles off
The ice maker has a problem
There's an ice- or water-dispensing problem
  1. Checking/changing a common light switch
  2. Common frost free fridge parts learn "what" is called "what" before starting your repair
  3. Compressor won't run or it is "clicking' on and off
  4. Cleaning the condenser coils
  5. Can my fridge be moved on it's side?
  6. Defrost drain freezes and then overflows
  7. Freezer door pops open when I shut the fresh food door
  8. GE Arctica repair tips...frost free trouble, freezing food, ect new25.gif
  9. How refrigerators work
  10. How a common defrost cycle works
  11. How to change a common condenser fan motor
  12. How to reverse the refrigerator doors on your refrigerator
  13. Help for storing an appliance
  14. How to change a common Whirlpool evaporator fan motor
  15. How to install or remove common shelf supports
  16. How long can I store food in my frost free refrigerator freezer and how?
  17. I heard a sizzling noise inside my freezer section and it looked like something on fire when I opened the freezer door. What should I do?
  18. I feel heat or warmth around my refrigerator doors...help!
  19. Important Disclaimer
  20. My fridge is running but not cold enough  - with Frost free repair information as well
  21. My refrigerator is leaking water inside the fridge
  22. My fridge is leaking onto the floor
  23. My fridge is freezing things
  24. My fridge makes a bang noise when it shuts off
  25. My Frost free fridge will not run at all
  26. My fridge is making   screeching/squeak noises
  27. My GE SxS fridge door has dropped and/or won't open or close properly
  28. My water dispenser has white flecks in the water...what's up?
  29. Mending a crack in the refrigerator liner
  30. New adaptive defrost information
  31. Ohm meter testing a start capacitor
  32. Odor complaints with your fridge
  33. Replace a door gasket on a refrigerator
  34. Sample wiring diagrams
  35. Stainless Steel Cleaning
Mar 14, 2009 | Bosch Refrigerators
Freezer side works fridge side doesnt
  36. Some help for an Amana refrigerator fan motor that will not run
  37. Will my freezer or refrigerator work ok in my garage?
  38. Whirlpool built refrigerator defrost timer installation help
  39. Water line "Y" hose for icemaker broken helps
    click on the required option.
Feb 20, 2009 | Kenmore Refrigerators
Refrigerators Logo
53 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
