OKI B6300 error message: Please reboot printer (010-349)
  • 2 more comments
  • Anonymous Sep 19, 2008
    Same problem. Don't know how to fix.
  • daysinnworth Oct 19, 2008
    Go to Print and blinking light with error message that states (Please Reboot Printer) (010-349)
  • Anonymous Nov 08, 2008
    I have the same problem, but no fix...
  • Anonymous Mar 18, 2014
    printer stopped printing and screen shows please reboot printer (103-374)
Replace the fuser.
Posted on Mar 24, 2009
Detect Fuser Trouble. Replace fuser if power off and on cannot recover the fail.
Posted on Feb 20, 2009
Your fuser has gone out and will need to be replaced to work. Rather simple to replace on your own.
Posted on Aug 20, 2008
  • Tim Kelly
    Tim Kelly Aug 12, 2011
    replaced fuser, same error.
2 Suggested Answers
KudesNIK
  • 22 Answers
SOURCE: How to solve "reboot printer
This is a fuser disconnection error. Try to remove the fuser and put it back securing properly in its place.
Posted on Sep 24, 2009
OKI B6300 Laser Printer stays in a "please wait"
An initialisation fault has occured
There is a component fault with the machine.
The infomation supplied is insufficient to diagnose the fault any further
Feb 14, 2011 | OKI B6300 Laser Printer
CHANGE PAPER TRAY DRAW
Do you often face technical problems for Okidata printers? Just contact our experts Okidata Customer Service at 1-866-877-0191 for best assistance. Free online tech services are available 24*7 at toll free number. For more info, visit: http://printertechnicalhelp.com/okidata-printer-technicalhelp.html
okidata printer 18668770191 customer service-aizo5avvrofwceza0ykjsgo4-1-0.jpg
May 03, 2010 | OKI B6300 Laser Printer
OKI B6300 DRUM/TONER
try this:
1.Press Menu = printer displays "Paper Menu"
2.Press Next 4x = printer displays "System Menu"
3.Press Select 1x = printer displays "Factory Defaults"
4.Press Next 7x = printer displays "Reset Toner Life"
5.Press Select 1x = printer displays "Resetting Toner Page Count"
6.Press Ready
Jul 28, 2009 | OKI B6300 Laser Printer
I GET ERROR CODE 010-349 WHEN TURN PRINTER ON
Hi!
The error issue your printer is facing means "Fuser STS Front Disconnection fail"
First try to reset the printer by powering off and then on. If the problem still persists then you need to detect fuser or fuser assembly which is required to be replaced.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Jun 25, 2009 | OKI B6300 Laser Printer
OKI B6300 Drum problem
Hello, com_jedi. I would suggest you contact the OKI Customer Support line in order to address this issue. The phone number is 1-800-654-3282 (800-OKIDATA). For your model unit you would hit options 1 then 4 to get to mono support.
It is possible that you purchased a defective consumable and OKI warranties them for 90 after the date of purchase. If this is a new drum/toner it may need to be replaced to determine if it was a bad chip in the cartridge or if there is some other issue with the unit that is causing the error.
It is also possible there is a misalignment with the sensor that is located under the drum unit. A support tech can walk you through the troublehshooting as it would be a bit difficult to do here.
I hope this helps!
Feb 12, 2009 | OKI B6300 Laser Printer
How to solve "reboot printer (010-349)error in OKI B6300 printer
Jan 20, 2009 | OKI B6300n Printer
Priter trouble
Please uninstall the printer driver and it's application completely after disconnecting the printer. Clean all the Temprorary files if any(Start>Run>"temp">Enter>Delet All. Then Start>Run>"%temp%">Enter>Delet All) Restrat the Computer and reinstall the driver. It should solve the Problem.
Oct 04, 2007 | Office Equipment & Supplies
6,374 people viewed this question
jasbo
jasbo
