Question about Acer Extensa 5620-4020 Notebook
I have an acer extensa doesnt matter which, it was working untill i tried swapping the gfx card with a replacement and now will not boot i get lights for power and it does turn on but no video and it wont stay on unless plugged in can someone please point me in the right direction ive tried everything?!?!?!
    Master:
  • 645 Answers
Seems like the new card is causing the problem. May be its a powerful card which needs more power or its faulty.
Posted on May 25, 2011
  • wazzup_512 May 25, 2011
    I know that this could be the case but when i put the origanal card back in still the same problem what should i do?
  • Mohammed Ebrahim M
    Mohammed Ebrahim M May 26, 2011
    Did you try loading the default settings in BIOS?
How i can boot from usb
if you want to boot a computer from the usb you will have to go into the bios and set the boot media ( HD, CD, USB) so that the computer knows where to search for the os.
Jul 19, 2015 | Acer Extensa Computers & Internet
Acer Extensa E210 totally death
Computer does not boot up The problem maybe the RAM, it is faulty or just needs reseating to make proper electrical contact.
Reseat the RAM and then boot up your laptop. If it still does not boot up then remove the RAM module/s and take them to your friendly computer repair shop and get them to test the RAM for you.
Aug 15, 2012 | Acer Computers & Internet
The probleme is password bios acer extensa 5620z i pull cmos battrey but no changed pleas help me .
typically there is a jumper on the cmos, swap the jumper to the opposite pins, boot, power down, then swap them back.
Oct 20, 2010 | Acer Extensa 5620-4020 Notebook
Acer Extensa 5210 blank screen
re seat the memory cards, clean them if necessary with pencil eraser (the metal connector on mem card), if it won't work, you might need to replace them with the new ones
May 04, 2010 | Acer Extensa EX4420-5239 Notebook
Hi I have an Acer Extensa 5230E-2177 and I installed the game Left 4 Dead 2 and its terrible laggy..? Can you help?
YES I CAN HOW MUCH RAM IS IN IT WHAT TYPE OF GFX CARD IS IN WHATS THE CPU SPEED? if you have low memory then you will need more i recomend 2 gb of ram min for gaming and a good 512 mb gfx card hope this helps
Mar 12, 2010 | Acer Computers & Internet
Acer extensa 5620 laptop will not boot uo
Then you can check 2 things to see if the machine will boot. If not, then you'll need to get it repaired. FYI, I repair Acers.
Step 1 - remove the battery and the A/C adapter from the back of the computer for about 2 minutes. Replace the battery and the adapter and try to start the machine. If that doesn't work, go to step 2.
Step 2 - Check that the A/C adapter is getting power and the LED for battery charging on the front of the computer lights. You can check the voltage from the power supply with a volt meter, if you have one -- it should read around 18-19 volts. If either of these steps don't work, you'll need to get it looked at.
Problems could be with the power supply, motherboard, power switch, CPU or something else that only time and expertise could properly track down.
Jan 08, 2010 | Acer Extensa 5620-4020 Notebook
Hi, on boot up from cold, computer hangs before post, only a long time of restarts finally kick it into action. please help!! alll volts are ok, have swapped mem around, checked bios.
Hi , Your bootup Relies alot on your RAM , swapping it around wont make a difference , Try running Memtest http://hcidesign.com/memtest/ .
see if your Ram is ok , and take it from there , if it shows your RAM is faulty you might need to Replace it , and if it isnt Faulty , Try Taking 1 Part out at a Time and try booting For example , only boot with 1 Ram Card , Boot with MB GFX , and so on.
I Hope This helped
Thanks
Dec 31, 2009 | Asrock K7VT4A-Pro Motherboard
I have an extensa 5420-5687. 1 day my laptop just
the power cord has shorted out you will need to buy a new one
If I have helped you please click the yes this was helpful button
Dec 03, 2009 | Acer Extensa 5420-5687 Notebook
Acer Aspire AM1640-U1401A has black screen-@ boot attempt.
Had this issue with two Acers of similar make. Replacing the Motherboard resolved the issue on both.
Sep 28, 2009 | Acer Aspire AM1640-U1401A Desktop PC
Dell monitor power down mode with Geforce GFX card install
I think maybe some how the main graphics for your pc has possibly switched to onboard. Try getting into bios F2 or DEl on boot up and highlight Advanced ChipsetFeatures and press Enter. In here make sure your AGP card is set as the Primary graphics controller. When done press ESC and 'Y' to save settings, then re-boot pc. Hope this gets you running again.
Nov 10, 2006 | Dell (M1325) (64 MB) Graphic Card
Acer Extensa 5620-4020 Notebook Logo
49 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
