We on planet earth do not run XP now.
end it;.
XP is virus magnet.
use W7 install. ok? nothing LESS now./
XP internet exploder is now dead on the web. banned.
ok>?
http://pcdied.com/XP-sux-sg.html
SOURCE: battery in a gateway gt5404
The battery on a desktop computer is on the mother board. It looks like a large watch battery. Very inexpensive and easy to change. But make sure all power is disconnected before touching *********** board and do not use and sharp object to try to pry the battery out.
SOURCE: Microsoft XP STOP OXOOOOOO7E OXCOOOOOO5 OXF78DA208
If you didn't yet then upgrade to SP2.
Update drivers for all hardware, in most cases this is a driver conflict.
If that didn't solve the problem then scan for viruses with AVG.
http://www.download.com/AVG-Anti-Virus-Free-Edition/3000-2239_4-10320142.html?cdlPid=11006019
Scan for malware with Anti Malware.
http://www.download.com/Malwarebytes-Anti-Malware/3000-8022_4-10804572.html?cdlPid=11004434
Scan for broken registry entires with Registry Mechanic.
http://www.download.com/Registry-Mechanic/3000-2094_4-10190447.html
Let all 3 software repair/remove the errs they find.
If the problem is still not solved then reseat the memory stick to another slot, since 7E with nt status code c0000005 (access violation) could be caused by
faulty RAM. Clean the dust
inside the PC.
If it still crashes, downclock the RAM.
If it does not
resolve the problem, replace the RAM.
SOURCE: blue screen when trying to install o/s from cd.
Not a lot of help here, other than to suggest it's caused by some hardware or driver conflict, but see this ms article. You could try then, this link to stop error codes, and these MS links here and here
I suggest you google "0X0000007E + pci.sys" and read the forums to see if someone out there has a solution...
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
SOURCE: My gateway gt5404 says no rgb signal what do I do
With 3 beeps, you are getting a Memory base read/write error, which means your RAM is having a problem.
You can try takng the RAM simm/dimm out and re-seating them back into the slots.
If the issue continues, you will need to replace the bad RAM
