Question about Craftsman 675 Series 190cc 22" Briggs Stratton Rear Bag Front Propelled Lawn Mower ()
My almost new Craftsman Lawnmower (190cc Honda engine) wont start. It just sprays gas thru the muffler.
  • 731 Answers
Take it back to Sears and let them repair it under warrenty
Posted on May 25, 2011
How to fix lawnmower
what wrong with it if it wont start check for spark at plug if works try squrting starter flood into carb if tries to start rebuild carberator tecuseh engines are bad about clogged up carb with dirt
Aug 16, 2014 | Craftsman 675 Torque 190cc 21" Briggs ...
I have a brand new Craftsman 190cc lawnmower, the pull coed will not pull out
Try turning the blade by hand and see if the engine will turn. Being a brand new machine a lot of new machines have a piece of steel fastened under neath for safety during transit. That has to be taken off.
Jun 30, 2014 | Craftsman Garden
Brand new craftsman 190cc lawnmower pull cord will not pull out
New mowers some times comes with a safety block on the blade and this has to be removed before you can turn the blades
How can i fix my slow running lawnmower
Sounds like the air/fuel mix is off.. there should be a adjustment screw on the side of the carburator use a screw driver and turn it slowly one way or the other till it starts running right
Jun 22, 2014 | Craftsman 675 Torque 190cc 21" Briggs ...
Lawnmower wont start after running then stopped for short period
It should be. The fuel line is under the tank and runs to the carburetor. Make sure you use the fuel shut off, if you have one, or drain gas before you play with the line. Once you find the line disconnect it from the carb and drain any remaining fuel. Then clean with a pipe cleaner and reattach. That should help.
Apr 17, 2013 | Craftsman 190cc 22" Rear Drive...
I have a gvc 160 honda motor on a troybuilt lawnmower. It is brand new. Went to start it for the first time and it shoots gas out of muffler and wont start,
Hi rick2624...
You have a stuck fuel inlet needle valve and it is allowing gas to flow thru the carburetor right into the cylinder and out your muffler.
You have a choice to make...
1. Remove the carburetor and clean it of the trash/debris around the needle.
2. Tap the carburetor with a small hammer around the bowl area and sometimes this will free a stuck needle valve.
3. Return the mower to the dealer you bought it from if still under warrenty.
Free answer...Please take time to rate me
Jun 20, 2011 | Honda Garden
I have a new 650 sears craftsman self propelled 22" lawnmower that will not start. I have gone through the prime bulb instructions, still no luck.\r\nAny ideas? Walter in Alberta Canada.
could be the priming bulb gasket between the air-filter assy. and the carb.
I have the same lawnmower and if I prime with gas from a can it will start but stop after a few seconds. When I push the bulb I can hear air leaking in this area. You can replace the gasket by removing the back half of the air-filter assembly. I am looking to buy a gasket today I let you know how it works out! Thanks Ron
Oct 24, 2010 | Craftsman 675 Series 190cc 22" Briggs ...
My 675 will fire up a start and will immediatly quit. i have cleaned the spark plug and put in new gas.
it's still getting bad gas. take off air filter, prime with fresh gas, use an old spray can, and keep spraying while running until all old gas is used up in the carb
Jun 26, 2010 | Craftsman 675 Series 190cc 22" Briggs ...
Engine runs for 20 seconds then stops.
I have no clue as to the actual solution, but what I would do is disassemble the carb and clean it out. Had a similar issue with a honda motor; ended up buying a new carb off an auction online for $45. Take lots of pics as you remove stuff or find an online parts catalog with a parts blowout diagram.
May 26, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
your carbeurator is gummed up. a common problem after the lack of use in the winter season. Since you havve a new plug you are partway home. Empty out any old fuel and put in new fuel which you buy now at the gas station. Then buy a can of carbeurator cleaner. Remove the air filter. Look and see if it is dirty, if it is replace it also. Spray two short ssquirts of carbeurator cleaner into the air intake opening exposed while the air filter is removed.
Pull the cord and try to start the engine. Even if it won't start you will be drawing the cleaner into the carb. so it can start to dissolve the problem gummy deposits. Wait half hour and repeat the spray and the attempt to start. If this fails after four attempts you will probably have to remove the carb. and soak it in carb. cleaner for three hours to dissolve the gum.
May 23, 2009 | Briggs & Stratton Lawn-Boy Insight Series...
Craftsman 675 Series 190cc 22" Briggs  Stratton Rear Bag Front Propelled Lawn Mower () Logo
448 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
