Question about Smeg SE399X/5 Stainless Steel Electric Single Oven
We have a Smeg Oven Model SA398X, It is a very good appliance makes great bread. It has now stopped working No display showing except a very small "A" I have turned the power off and on and pressed the extreme right hand button to no avail Please help, can't live without Smeg bread Mike
  • respini May 25, 2011
    Have bypassed the faulty clock relay and oven now working perfect.
    Will install replacement relay in time
    Thanks for advice
    Regards
    Mike
  • Kathryn Oct 03, 2011
    DId you find a solution to this problem. I have the same issue. The display has an A and the oven will not turn on. Appreciate your help.
  • 8,197 Answers
Hi welcome to fixYa. I see that you are having problems with your oven. Can you please explain the problem a little more so I may help you.
Posted on May 25, 2011
  • 5,370 Answers
Try to set oven in manual mode:--- Turn off at mains, turn on again. 0:00 will flash press the manual op key Don't use buttons with wavy lines as they are for setting auto cooking time.------- If its not setting to manual mode, then:-- Your oven is got set in automatic mode and got stuck-up there.It has ti be in manual mode to function.From your description of the fault it would suggest that the timer/clock has failed.--------- But still try this few times. Keep the oven ON, with A on the display.Now --- Press all the timer buttons together for 10 seconds then release.--- if that is not helping then unplug the oven from power outlet, wait for 1 minute then reconnect the power cord, turn the oven ON.And try the same procedure again.--------- Try this same procedure 3 -4 times.In some cases it gets reset and comes to manual mode.But if that is not helping then Timer /clock has failed and the timer control board has to be replaced. ----------------
To order parts click the link below:--
http://spares.bigwarehouse.com.au/index.php?cPath=69383_69384_81306&osCsid=1d71db61c0d5a2ee3d9f67f3fea171c2 -------------- Also click this link for parts:-- http://www.stokesap.com.au/downloads/Smeg_Final_Sep08_LR.pdf --------- this should help.thanks.Helpmech.
  • raj somaiya May 25, 2011
    Thanks for the update.Helpmech.
SMEG OVEN BRAND NEW WON'T HEAT
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  • Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  • If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  • When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Sep 08, 2012 | Smeg Ovens
Smeg oven stopped working
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
Jan 27, 2012 | Smeg Ovens
Best setting for baking cakes
good day,
hope this link below will solve your problem.
baking.
The best bread machine we've found for gluten-free bread baking. Programmable feature puts you in charge. Bakes a delicious 1.5 to 2 pound loaf every time. It has a viewing window, automatic settings for breads, cakes and jam, sourdough starter and programmable cycle that makes gluten-free bread in under two hours!
Aug 01, 2009 | Smeg SE250XUK Stainless Steel Electric...
Noisy fan in Smeg oven SA398X
Does the fan sound like a squeling or rumbling?Is the fan blade itself scraping on something?
Apr 18, 2009 | GE JGRP17 Gas Single Oven
SMEG DO4SS-5 double oven not heating up
If the fan is running, then it is safe to say that the oven element has gone.
Replace with a new one,(element that is).,
Plz rate this solution.
Thanks.
Dec 15, 2008 | Smeg Ovens
Oven will not switch on
If there is an A only on the clock(no other digits) your clock has failed. Either replace , or can be bypassed. Oven won't work without clock set.
Dec 14, 2008 | Smeg SE250XUK Stainless Steel Electric...
Smeg oven
  2. If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
If this helped like us on facebook please
How to Video Tutorials on Domestic Appliances
Dec 08, 2008 | Smeg SE399X/5 Stainless Steel Electric...
Smeg oven not working
You have a element and or a faulty thermostat
Nov 25, 2008 | Smeg F170 Pyrolytic Stainless Steel...
Oven smoking
I am pretty sure this is just the steam escaping. Smeg ovens seal so evenly that the steam stays in the oven.
Nov 12, 2007 | Smeg SE399X/5 Stainless Steel Electric...
Smeg oven diplaying an "A" in display
I have had the same problem today - trying to change to day light saving time - can you help me too if you find out.
Sep 25, 2007 | Smeg SE399X/5 Stainless Steel Electric...
Smeg SE399X/5 Stainless Steel Electric Single Oven Logo
342 people viewed this question
Top Smeg Ovens Experts
ashburton
Hjalmer Lamminen
Hjalmer Lamminen
Are you a Smeg Oven Expert? Answer questions, earn points and help others
