Question about Sony XM-2200GTX Car Audio Amplifier
The amp dont come on but power protecter light is red.
  • 32 Answers
Sounds like something is shorting out and it is in protection mode. Check that the wiring is correct and there are no bad spots on the power wires. Unhook the power before starting your evaluation and leave disconnected until you think you've found the problem then rehook the power source. This will give the system time to reset if it needs to.
Posted on May 25, 2011
Kenwood amp red light
Red triangle is kenwood power light. Check rcas
Sep 24, 2017 | Car Audio & Video
My amp was working good and i didnt use like for two months and know it doesnt work the green light turns on but the red light too of over current and i cant hear nothing i dont know what is it..
if it turns red its a protection light you most likely got the ohms wired wrong on the speakers and the amp is going into protect mode so you dont fry it or the subs
Mar 04, 2011 | Sony XM-2150GSX Car Audio Amplifier
Hello, i have a nitro bmw 486 amp. i use it to power my 2 subwoofers in my trunk. its a very good amp and sure does its job, but randomly the light will turn red, which means protect, and my subs will shut...
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty D .A thumbs up would be greatly appreciated if this answer is helpful to you. nitro-lv2kkrmxrai4iihdvw4m3np2-1-0_0.jpg
Jul 31, 2010 | Nitro BMW-486 Car Audio Amplifier
Directed audio 800a amp the protection light keeps blinking
1. Check your grounds. (including grounds for your stereo)
2. Check to make sure the power cable you connected to your car battery is properly connected, and not coming into contact with anything metal.
3. Make sure you are using proper fuses.
4. Check your connection from your stereo to your amp, and your amp to your subs.
Jul 18, 2008 | Earthquake Sound XTREME 900W.5 Car Audio...
Both green and red ligt or on my jensen ka3 i dont know what it means i had it working b4 i swaped my subs for some new ones and the amp dosent work now.i dont know if is because of the red light but i...
Generally, the power light is green and the protect light is red. If the protect light is on there could be a short in the wiring or there could be an internal fault in the amp.
Disconnect all speaker wires from the speaker terminals of the amp and disconnect signal cables from the amp. If it powers up, the wiring needs to be checked. If it still shuts down (goes into protection), the amp likely has blown output transistors.
Dec 28, 2007 | Jensen KA3 Car Audio Amplifier
Mac-505 amp
Disconnect all speaker wires and signal cables from the amp. If it powers up normally (no protect light), the wiring needs to be checked. If it still goes into protect, the amp likely has blown output transistors.
Dec 19, 2007 | Car Audio & Video
Red light
It sounds like the output transistors have failed. Disconnect everything from the amp except for the B+, ground and remote and turn the amp on. If it goes into protect, the amp is in need of repair. If you want to repair it yourself, email power acoustic for the schematic.
Oct 02, 2007 | Power Acoustik LT-980/2 Car Audio...
Red LED "Protection Light is on" What is the problem
The red light means the amp is in protection mode. A few things can cause protection mode..... First disconnect the subs completely from the amp, and turn it on, if it powers up you have blown subs. Also try checking the main power wire at the battery...sometimes the current your meter is seeing is backfeeding from the remote wire, so your main power line could be blown at the fuse under the hood. hope this helps
Jul 17, 2007 | Crunch BlackMaxx BMX2250 2 Ch 1000W Amp...
My Power Protector Light wont turn Green
switch off the amp then take off all the wires off including the speaker wire and then reconnect the wires on like before the problem is that the amp is on protection and if that dont work then get it repaired another thing is make sure ur amp fuses havent blown.
Nov 04, 2006 | Sony Xplod XM-554ZR Car Audio Amplifier
Sony XM-2200GTX Car Audio Amplifier Logo
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
