I have a BOWIN SLE natural gas heater. When I pree the On button it tries to start up, green light comes on and gas lights for a few seconds then switches off. Filter is clean.
SOURCE: natural gas conversion
I have a similar problem. But, I want to convert it to propane. I have a 5 burner vent free modelMN300HPA. If your are handy. I would consider shipping you the parts inside mine to install in yours. These parts are very simple to remove after removing the access panels. I have taken mine out already. Called procom then to no less find out the propane parts needed are not sold by them. I think only the injectors (5) the main valve (regulator) and the pilot are the only things need to change. When taking out the pilot this is easly done, By removing the nut on the supply line. And then bending back the retaining tabs to then slide back the pilot then it comes out of the assembly bracket. Injectors are simply removed. Regulator located at the bottom is a simple remove. The only other item that might be questionable would be the valve that selects the amount of burners you would like to operate. And I would think this would be the same and not need removing. Let me know if I can help. I would like to get mine converted to propane. Thanks Tom
Posted on Nov 06, 2008
SOURCE: natural gas heater
I'm not a gas expert, however if I could offer an alternative possibility: I recently opened a gas heater to find a child (I assume) had inserted a CD and a pen into it. If the soot is more than a short term problem this is obviously not the cause but it may help some people.
Posted on Nov 24, 2008
  • 4 Answers
SOURCE: rinnai natural gas log fire heater
12 is a fault code, look in the book if you have if, i think 12 is no or low gas pressure, cheers
Posted on Feb 05, 2009
  • 188 Answers
SOURCE: blinking clean light
If the clean light flashes 7 times, pauses, then repeats...
When the dishwasher doesn't sense a water temperature increase, it will stop working and lock the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cycle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring). It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Posted on Mar 03, 2009
vortash
  • 431 Answers
SOURCE: Rinnai 560PTR Heater Converted Propane To Natural Gas No Ingition
I think you will find the thermocouple or thermostat has gone this allows the gas valve to open and is a saftey device to stop the escape of dangerous fumes .. it looks like a long piece of thin copper wire approx 4mm thick and it extends from the main valve into the pilot light flame .. When the ignition is pushed and you hold your finger on it for a while this tells the the valve that the pilot light is lit .. conduction of heat along this pipe then opperates the diaphram in the valve allowing the gas to the burners the pilot light then ignites them .. if the pilot light goes out the unit will nort run ..
My advice to you is that even though you may be conversant with the heater .. they do tend to have all manner of faults occur when left in storage or if shipped ( jostling and bumping ) is to get a trained gas engineer to check it out it may cost a bit .. but a gas escape and the following reprocussions are far more exspensive and costly .. Also You may not be aware that if you do have an incident your house ,insurance may be null and void if no service documents can be raised for the correct servicing of a fixed or mobile gas Convector .. I hope this helps Regards Vortash
Posted on May 22, 2009
My heater is brand new and it will not light.
first check that the heater is designed for natural gas and not for lpg
the jet sizes are different
call for a gas fitter to inspect the unit and make the necessary adjustments
Oct 14, 2015 | Heating & Cooling
New blue flame heater, everything is hooked up, gas is going to unit, I have a natural gas hookup, in the correct port, knob is turned and locked into the NG position but unit wont light. There is gas...
do you have the pilot light burning if not then you have to get in burning first
Put knob in pilot position push down and hold for at least 30 seconds or longer then if there is an igniter push and release it push and release till pilot light comes on .Continue to hold pilot light button down for another 10 seconds or so, release pilot button and turn button to on or up a number or set T stat
Main flame should come on and burn
Oct 13, 2013 | Procom Heating & Cooling
Heater turns on initially - green light comes on and it fires up, stays on for 5 seconds then switches off, followed by a continuous beeping sound.I have tried this several times and the same thing happens...
When you say it lights up is the green light changing to red to let us know the unit has sensed a flame? If you get a visible flame but no red light then this indicates either the flame sensor is fauly or the electronic board is faulty
Jul 26, 2010 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
I turned the heater on after being off all summer and it kicks on for about a minute and the green light comes on and then it just turns itself off, even though I have the thermo set high. I have cleaned...
I bet you have an error code stored in the unit. Try this to retrieve it: Turn the heater off. Hold down on the Economy button as well as the up and down arrows all at the same time for about 3 seconds. Let go and in about 2 seconds a number of lights will light up. I find it easier to have an assistant write down the lights as I call them out. If 60 and LO is displayed, you may have a spider web inside the burner not allowing the unit to light. You will need to remove the front cover and start disassembling the burner. Not an easy task. You can try and shoot high pressure air down the center exhaust tube but that is a gamble that it will blow the web out of the burner. Good Luck.
Nov 02, 2009 | Rinnai RHFE-431FAIII 16,700 BTU Direct...
Rinnai Energysaver 1004F on indicator light is red (usally green)
If its not producing heat, yep! If it is, it indicates that there is an error code stored in memory.
Feb 18, 2009 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Bosch 1600H NG
I hope this helps!
http://www.boschhotwater.com/HelpfulResources/TechnicalSupport/BoschAquaStarModels/1600HTechSupport/Troubleshoot/tabid/1094/Default.aspx
Copy and paste to google search engine!
Jan 29, 2009 | Bosch 1600H-NG Natural Gas AquaStar...
Burner on new Whirlpool gass water heater will not stay lit
One of the proper ways to light a gas water heater, is to turn the black knob to Pilot, put a match to the end of the pilot light, while holding the match there, push the red reset button down and hold the match & the reset button down for one full minute. Then, release the reset button and turn the black knob to On. This should keep the pilot light on.
Jan 21, 2009 | Water Heaters
Heating & Cooling Logo
136 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
