Question about Schwinn Original Airdyne
Replaced the battery and now the display stays on and shows some memory function. used energizer 357/303 battery. timer works but will not shut off. what's up with that?
  • 16 Answers
Display is supposed to turn off automatically after 5 minutes of inactivity.
Posted on Jun 06, 2011
Anyone have a problem with replacement battery for SS8 intermatic timer
Copy following link for all Intermatic timers, including new Ej600, and older SS series timers.
http://waterheatertimer.org/Intermatic-timers-and-manuals.html
Try resetting the timer. Hold down ON-OFF button and push and release reset button. Keep holding down ON-OFF until display starts flashing 12:00
Clean battery terminals.
My SS8 manual shows 1.5 volt alkaline battery but does not specify the shape or size of battery.
If the display is visible, then timer is getting power.
The low battery error might clear up after reset, but if it does not, then replace timer.
Intermatic has new EJ600 timer that has internal rechargeable battery, and does not need battery replacement. Or use ST01C or Ei600.
Remember also that timers cannot be exposed to extremes of hot or cold, or the battery can stop functioning.
May 01, 2012 | Intermatic Hardware & Accessories
Tork model dts200a/dzs200a shows no display and has stopped working. any Suggesqtions?
Tork DTS200a/DZS200a is 2-channel digital timer with 365 day programming and astronomic capability.
2-channel means that timer can control two different circuits with different program schedule applied to each circuit.
http://waterheatertimer.org/pdf/1TORK.DTS200A.DZS200A.INSTALL_OP.pdf
http://waterheatertimer.org/Tork-Digital-timers-and-manuals.html#DTS
1) Timer has 'snap-in non-rechargeable 9-volt lithium battery'
Replace with ordinary 9 volt battery
Battery location is not apparent from image of product, and I don't own this particular timer line.
Add a comment and say where battery is located.
2) Programming is stored indefinitely in memory chip even if battery goes dead.
Current time might have to be reset shown in manual page 3.
Memory can be cleared using procedure outlined in manual starting page 13.
3) If timer function is not restored, then timer might have gone bad.
Contact NSI:
http://www.nsiindustries.com/contact-us.aspx
Many timers and other electronics are not protected from power surge.
Lightning strikes, electrical storms, and simple power outage can knock out electronic timers, and water heaters, water softener, treadmill, etc.
1-event Surge protectors can be installed in main panel to help protect circuits and electronics.
Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Aug 30, 2011 | TORK Hardware & Accessories
I am wanting to energize a relay for 3 min. then off, whether the power stay's on to coil or not! what I want to do is when a door rises and hits a switch I want to energize a coil for 3 min. whether...
You want 3 minute 'off delay' timer.
When timer is energized with push button or momentary electrical signal, circuit remains ON for set amount of time, and then turns OFF.
http://waterheatertimer.org/How-to-wire-Dayton-Off-Delay-Timer.html
Aug 15, 2011 Dayton/ Grainger website is offline
Most delay timers have 1 amp capacity rating, so circuit needs fast acting 1 amp fuse, and timer controls separate relay or contactor unless Load is equal to 100 watt light bulb.
3-minute off delay pin timer
Omron shows 120Volt 8-pin M-series-(minute) 3 minute delay timer
Part number H3CR-H8L 120volt M
http://waterheatertimer.org/pdf/Omron-timers.pdf
Example 240Volt timer showing timer and base.
http://www.sourcingmap.com/ah33-220v-030-minutes-delay-timer-relay-socket-p-119441.html
Wiring diagram shows on side of timer.
Aug 15, 2011 | Amperite Dayton Solid State Timer On Delay...
My intermatic ej351c timer is not working properly. lights only stay on a few seconds - a few minutes before shutting off, even when button is pushed to override program. is there a battery that needs to...
Timer has non-replaceable capacitor battery for 15 minute carryover during power outage.
Timer can be affected by radio and TV receivers. Unplug those devices and check if function is restored.
Reset timer and program again.
If timer function is not restored after reset, then buy new timer.
Timer has 1-year limited warranty, and is rated for incandescent only, up to 150Watts.
http://waterheatertimer.org/pdf/Intermatic-ej351c.pdf
Aug 12, 2011 | Intermatic Programmable 24 Wall Switch...
The wall timer to my outside lights says "noop"
noop means no operation.
This usually shows on older timer.
You posted under Intermatic ST01C.
Other have written to fixya with same symptoms.
CR2 battery might be bad. Replace battery.
Replace battery quickly and current time remains in memory.
Battery out of timer longer than 30 seconds, then current time and day disappear.
Programming remains inside timer forever with or without battery until timer is reset.
Others report they changed battery and timer never came back to life afterward.
http://waterheatertimer.org/ST01C-program.html#battery
Manual troubleshoot section also suggests resetting timer, and then re-programming.
Manual:
http://waterheatertimer.org/Intermatic-st01c.pdf
To reset timer, hold down ON-OFF button and push small round reset button with paper clip.
Push reset for 3 seconds and release.
Keep holding down ON-OFF until INIT shows on display.
Release ON-OFF and wait for display to show.
If display never shows, then battery is dead or timer is bad.
ST01C comes with 1 year limited warranty.
Advantage of Intermatic battery operated timer is simple wiring, plus astronomic function (dawn-dusk).
All in-wall timers have advantages and disadvantages.
Nextag shows new ST01C sellers
http://www.nextag.com/intermatic-st01c/products-html?nxtg=90ff0a280507-C4F7FB4C58223A3F
Page also shows Intermatic EI600 astronomic timer that comes with 5 year limited warranty
Nov 29, 2010 | Intermatic Inc. ST01C Digital In-Wall...
On my intermatic HB88RC,I replaced the battery because it was dead and now it shows 44:44 on the display can this be reset?
http://www.intermatic.com/products/timers/consumer%20outdoor%20timers/digital%20timers/hb88rc.aspx
HB88RC is 7-day plug-in digital outdoor timer that uses AA battery installed on back of timer to power the display.
People write to fixya frequently report Intermatic timer stops working after replacing battery.
To check if your timer is still functional:
Press and hold clock button.
Press Day button until current day shows in display.
Press Hour until current hour shows in display
Press MIN until current minute show in display
Release clock button.
If current time shows in display, then timer is probably still good.
To set programs:
step 1) Press PROG button until 1 and ON show on display.
This is program1 ON.
Press day button until choice of days shows for program1 ON
Press hour until hour for program1 ON shows
Press MIN until minute for program1 ON shows.
step 2) Press PROG button until 1 and OFF show on display
This is program1 OFF.
Press day button until choice of days shows for program1 OFF
Press hour until hour for program1 OFF shows
Press MIN until minute for program1 OFF shows.
step 3) Press PROG button until 2 and ON show on display
Repeat steps above to set program2 thru program7
step 4) When programs are set, press CLOCK button to return to current time
step 5) add a comment for more help
Nov 18, 2010 | Intermatic HB88RC - 7-Day Programmable...
How to program a woods TD1000 indoor timer
Here's how to set Woods TD1000 timer
This is older timer with backup battery. Plug in timer to see if battery will work. Display shows when battery is charged. No display, then timer is no good.
TD-1000 timer has 8 on-off functions per 24-hour day ...newer timers each offer 7 day function with choices of each-day, week-day, or week-end programming. The wider choices with newer timers may explain why TD1000 instructions are hard to find
Timer has 5 buttons + reset:
TIME MODE PROG HOUR MIN
Set time
Press and hold TIME > use Hour to set hour, Min to set minute
Release Time button ... correct time should show
Program: Capacity for 8 on-off times per day
Press PROG to set first ON time
ON and number 1 are displayed on left
Use hour and minute button to set ON time
Press PROG to confirm
Now, OFF and number 1 are displayed
Use hour and min key to set OFF time
When 8 programs are set, Press MODE key.
Choose Manual OFF. Manual ON, Auto ON, Auto Off
To use programs, select Auto ON
DST daylight savings time has to be done manually.
Press HOUR MIN button simultaneously > timer set up one hour
Repeat again and timer goes back one hour
Do not plug timer into extension cord > must be plugged into wall
Oct 04, 2010 | Woods Indoor 24 Hour Digital Timer (59203)
This is older timer with backup battery. Plug in timer to see if battery will recharge. Display shows when battery is charged. No display, then timer is no good.
TD-1000 timer has 8 on-off functions per 24-hour day ...newer timers offer 7 day function with more programming choices... which may explain why TD1000 instructions are hard to find
Set time
Oct 04, 2010 | Woods INDUSTRIES 59112 INDOOR DIGITAL...
We have 3 Intermatic TB121C timers. 2 of them stopped working yesterday; the switch will no longer turn the lights on or off. We were not using the timer function at this time,just the switch. The display...
Yes, replacing the batery is each unit should get them working correctly again. The way these Intermatic timer switches work is that the battery actually operates the switching function to turn it OFF/ON. So once the battery goes dead, the switch won't operate properly.
You may have to reprogram your timer too, since some models lose their memory, once the battery goes dead. There are some new versions of Intermatic timers that use a semiconductor to hold the programming even in the event of a power loss or removal and replacement of the battery. (just an FYI for future reference).
Hope you find this Very Helpful and best regards!
Aug 12, 2009 | Intermatic Hardware & Accessories
Disney Pix Micro Digital - stopped working after 10 minutes
The type or memory in the camera requires a charge in order to store data. So if you have any pictures on the camera it will constantly be pulling a charge from the battery until the battery is completely drained. If you have this problem even with a brand new battery it's possible that the memory may be corrupt and needs to be cleared. To do this just remove the battery and press both buttons several times each to make sure that the camera is completely discharged, replace the battery with a brand new battery and try again. If that fails I'd get in touch with customer service for a replacement.
May 18, 2008 | Disney Pix Micro Digital Camera
Schwinn Original  Airdyne Logo
154 people viewed this question
Top Schwinn Cycling Experts
Tony
michael
michael
jasiel murphy
Are you a Schwinn Cycling Expert? Answer questions, earn points and help others
