Question about KitchenAid Architect Series KDRP467KSS 36" Pro-Style Dual Fuel Burner with 4-15,000 & 2-6,000 BTU Se... Range
Kitchenaid dual fuel range KDRP467KSS Oven preheats, but then stops maintaining temp. No error codes. I open and close door, turn it on and off, none of which seems to work and after 10 or 15 minutes it will start heating again. Very frustrating.
  • johnzam May 25, 2011
    what should the resistance on the sensor be? How can thermostat be tested? I have a multimeter.
  • johnzam May 26, 2011
    How is the thermostat and sensor accessed? Inside the oven? Or from the back? The schematic does not show where to access these parts. Thanks!
  • 5,370 Answers
The thermostat in the unit has to be checked.It must be faulty or causing the problem.Also check the temperature sensor.The temperature sensor triggers the sensor to turn on and turn off.If any of the one is not functioning the oven will not maintain the temperature. For parts diagram for disassembly.Please click the link below:--- http://www.searspartsdirect.com/partsdirect/part-model/Kitchenaid-Parts/Range-Parts/Model-KDRP467KSS09/0593/0122007?searchedModel=KDRP467KSS&blt= ---------
You can get required parts from from online sites like: --- www.repairclinic.com or from searspartsdirect online site. --------- This should help.Thanks.Helpmech.
Posted on May 25, 2011
Oven control board
Work out the difference,and cook to suit.!
Jan 07, 2014 | KitchenAid KDRP467KSS Dual Fuel (Electric...
Display has error code f2e1
Hi
F2-E1 Error indicates a loose/broken wire on the oven temp sensor or the oven temp. sensor itself is bad and should be replaced. To solve this issue test the oven temp. sensor, it should read between 1080-1120 ohms, if the rating is more then that and the door appears to be closing fine then it is the control board that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Sep 14, 2011 | KitchenAid KDRS807SSS Dual Fuel (Electric...
I have a PF erorr code on my oven screan
"POWER FAILURE" code, unplug the power from the range for 20 minutes or longer, plug back into the power outlet, set time and if the micro-processor didn't take a hit during the power failure you should be up and going once again.
GOOD LUCK !
Aug 26, 2010 | KitchenAid KDRP467KSS Dual Fuel (Electric...
I was using the self cleaning function on my kitchenaid dual fuel range when about half way through the cycle the digital display went blank (i.e. no lights were on at all) and now 2 hours after the cycle...
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Aug 19, 2010 | KitchenAid KDRP467KSS Dual Fuel (Electric...
Kitchenaid DF Range F04 error code
I have a dual fuel kitchenaid convection range and I put it in self cleaning mode last night. Afterwards it said F 04 on the display. The doors open again, but neither of the ovens work
Nov 17, 2009 | KitchenAid KDRP487MSS Dual Fuel (Electric...
Kitcheaid electrical Oven
If you go to repairclinic.com click on repair help at the top then "error codes" on the left side in a gray box. you can look up the error code. I found F2-E0 but not FE02 for a KitchenAid range.
What I found means shorted key pad. Some times just unplugging the unit or shutting down the circuit breaker that controls it for half an hour it will reset. not guarunteed but less expensive than replacing if it works. Good luck.
Jan 09, 2009 | KitchenAid KDRP467KSS Dual Fuel (Electric...
I have a hotpoint range where the oven and clock display suddenly stopped working, but the gas range top does... what do I do?
Sounds like you have a bad main oven control board (ERC).
Bad new is you will need to replace it or have it replaced. Good news is that it is not difficult to do
Dec 20, 2008 | KitchenAid KDRP467KSS Dual Fuel (Electric...
DOOR ON KDRP467 WO'NT OPEN
Replace the control panel thermal
fuse (Microtemp G4A01093C). Its in the wiring harness between
the control transformer and the control panel on a blue wire.
It looks like a resistor inside a clear plastic tube and is
mounted on a metal bracket with plastic clips. It has a spade
connection on each end. It can be accessed by removing
metal access panels from the back of the range and it
is in the area below the gas burner deck.
Dual fuel kithen aid F 02
Welded element relay on the control board.
Brian
Apr 18, 2008 | KitchenAid KDRP407HSS Dual Fuel (Electric...
KitchenAid Architect Series KDRP467KSS 36" Pro-Style Dual Fuel Burner with 4-15,000 & 2-6,000 BTU Se... Range Logo
103 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
