Question about Sony SDM-HS73P 17" LCD Monitor
Will not retain screen image. Flashes the content when you push the on/off button and is clearly projecting data, but just in flashes.
  • jmccord_arch May 25, 2011
    Are the backlight tubes in my Sony SDM-HS74P monitor replacable or is the unit e-waste?
  • Sony Master
  • 1,583 Answers
It appears you may have a bad backlight. If you can see the picture content with a strong light shining at an angle to the screen while it is dark, then it is definitely the backlight. Most sets shut down shortly after getting a failure signal from the backlight inverter although you do not mention that happening.
The backlight uses two or more Cold Cathode Fluorescent Lamp (CCFL) tubes, and they'll have the same flickering as a failing standard fluorescent tube. If the light has a pinkish cast to it, this is a common sign that one or both of the tubes is bad. You may see the flashing on the top or the bottom and the other half of the screen will be dark; this means one tube is dead and the other is dying.
Posted on May 24, 2011
  • Paul Bade May 25, 2011
    The tubes are replaceable, but they aren't easy to get at. Typically, after you remove the back of the monitor, you look for the pink and white (sometimes blue and white wire pairs going from the inverter to one side of the top and bottom of the LCD panel. These go to the tubes. Sometimes, all you have to do is remove a screw next to where the wires go into the panel and you can slide the tubes out with their reflectors. Other times you have to remove the metal frame pieces on the top and bottom edge - the tubes are inside these. Be careful - this tubes are very thin glass and contain mercury vapor.
    Now for the really tricky part: the wires are soldered onto the tubes, and you cannot apply heat to the leads on the new tubes for more than three seconds at time because doing so will damage the seal around the leads and ruin the tube. That means you need a good soldering iron and 63-37 tin-lead solder (low melting point). If you are not sure your soldering skills are adequate to the task, at least one vendor (see below) will sell you tubes with new wiring attached for an extra fee.
    I usually buy CCFL tubes from LCDParts.net. They have a decent Tech Support page detailing the replacement process. You can find the replacement tube either by size (length and diameter in millimeters) or by the model of the LCD panel (look for the sticker on the back of the panel inside the monitor. The price for tubes for a 17" monitors is generally $12 or $13 each, and you may have four tubes in a high-brightness monitor. I recommend replacing all of them at the same time; if one is dead of old age, the others are just as old and will go soon.
When i push the power button on my nikon coolpix L5 the lens comes out and the screen flashes on then off
sounds like grit in the lens mechanism..... but is it worth enough to get it serviced?
Apr 17, 2014 | Nikon COOLPIX L5 Digital Camera
O dial tone and screen just flashes off. fully charged.
just tried neighbours phone in and that worked so when we put our phone back in it worked again.
Aug 23, 2009 | Philips Lands Phones
No picture/ power button flashes twice constantly. 2 flash code?
Sorry, but there is no simple answer to your problem.
Bottom line, it needs to be repaired by a qualified technician.
The blinking is a code for what circuit area of the set called for the shutdown.
No matter what it is, there is nothing more you can do.
www.mcveyelectronics.com
May 03, 2009 | Philips 50P8341 50" Rear Projection...
I turn the tv on the green light comes on then the tv shuts off. after that a red light starts flashing.
the red light that flashes is it in the screen or on the power button area. it sounds like your image circuit is out of specifications something is causing a surge in your voltages could be a bad resistor or bad I.C.
Mar 14, 2009 | Philips 43P8341 43" Rear Projection...
Data processing light keeps flashing in fax mode
Unplug your USB cable and the fax should start working. If this fixes the issue, it could be a problem with your USB cable or hardware.
Mar 06, 2009 | Canon imageCLASS MF4150 All-In-One Laser...
View timer only lights
TV WILL NOT NOT TURN ON RED VIEW TIMER LIGHT FLASHES AND THEN I CAN'T TURN OFF TV
Mar 29, 2008 | Sharp 61RWP4H 61" Rear Projection...
My big screen tv went off and reset it but you push the button and the power comes on and goes right back off
when we push power button the green light flashes as if thinking about turning on and nothing happens, any way to fix this?
Feb 18, 2008 | Televison & Video
Blue screen with Green Star-burst image in center?
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Jan 19, 2008 | Mitsubishi WD-52725 52". Rear Projection...
MRM 700 won't start; screen flashes white . . . help.
stonelinton, It's not your LCD, otherwise you would have heard the sound of buttons being pushed. If your units first screen is white and there is no logo screen or any legible images, then it's your NAND flash on your main board. The first image produced upon boot is the blue magellan screen. This is produced from the NAND flash and will show it no matter if a hard drive is present or not. After the Magellan screen it pulls images from the hard drive. So, it is the mainboard and the only way to fix it is to send it to Magellan repair and they will have to put in a new mainboard then reprogram your serial number, etc.
Jun 07, 2007 | Magellan RoadMate 700 GPS Receiver
Open Questions:
Sony SDM-HS73P 17" LCD Monitor Logo
156 people viewed this question
Top Sony Computers & Internet Experts
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
