Question about Sharp CV10NH Air Conditioner
Leaking air conditioner, possible crack in drainage hole??
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 251 Answers
System Inspection
Although the A/C system should not be serviced by the do-it-yourselfer, preventive maintenance can be practiced and A/C system inspections can be performed to help maintain the efficiency of the vehicle's A/C system. For A/C system inspection, perform the following: The easiest and often most important check for the air conditioning system consists of a visual inspection of the system components. Visually inspect the air conditioning system for refrigerant leaks, damaged compressor clutch, abnormal compressor drive belt tension and/or condition, plugged evaporator drain tube, blocked condenser fins, disconnected or broken wires, blown fuses, corroded connections and poor insulation.
CHECKING FOR OIL LEAKS Refrigerant leaks show up as oily areas on the various components because the compressor oil is transported around the entire system along with the refrigerant. Look for oily spots on all the hoses and lines, and especially on the hose and tubing connections. If there are oily deposits, the system may have a leak, and you should have it checked by a certified air conditioning specialist.
Fig. 1: Run your hand along the underside of all hose connections and check for leaks. If you find a leak, have it fixed by a certified air conditioning specialist.
leaking air conditioner, possible crack - check%20ac%20leak.jpg KEEPING THE CONDENSER CLEAR Periodically inspect the front of the condenser for bent fins or foreign material (dirt, bugs, leaves, etc.). If any cooling fins are bent, straighten them carefully. You can remove any debris with a stiff bristle brush.
Fig. 1: The position of the condenser in front of the radiator makes it particularly susceptible to collecting debris. Periodically, remove the accumulated bugs, leaves and other trash from the condenser. ac%202.gif
CHECKING THE REFRIGERANT LEVEL There are two ways to check refrigerant level. On vehicles equipped with sight glasses, checking the refrigerant level is a simple matter. Many late model vehicles, however, do not have a sight glass, and you have to check the temperature of the lines to determine the refrigerant level.
With Sight Glass The sight glass is normally located in the head of the receiver/drier. The receiver/drier is not hard to locate. It's a large metal cylinder that looks something like a fire extinguisher. Sometimes the sight glass is located in one of the metal lines leading from the top of the receiver/drier. Once you've found it, wipe it clean and proceed as follows:
  1. With the engine and the air conditioning system running, look for the flow of refrigerant through the sight glass. If the air conditioner is working properly, you'll be able to see a continuous flow of clear refrigerant through the sight glass, with perhaps an occasional bubble at very high temperatures.
  2. Cycle the air conditioner on and off to make sure what you are seeing is clear refrigerant. Since the refrigerant is clear, it is possible to mistake a completely discharged system for one that is fully charged. Turn the system off and watch the sight glass. If there is refrigerant in the system, you'll see bubbles during the off cycle. If you observe no bubbles when the system is running, and the airflow from the unit in the vehicle is delivering cold air, everything is OK.
  3. If you observe bubbles in the sight glass while the system is operating, the system is low on refrigerant. Have it checked by a professional.
  4. Oil streaks in the sight glass are an indication of trouble. Most of the time, if you see oil in the sight glass, it will appear as a series of streaks, although occasionally it may be a solid stream of oil. In either case, it means that part of the charge has been lost.
  1. Fig. 1: Oils streaks (A), constant bubbles (B) or foam (C) indicate there is not enough refrigerant in the system. Occasional bubbles during the initial operation are normal. A clear sight glass indicates a proper charge of refrigerant or no refrigerant at all, which can be determined by the presence of cold air at the outlets in the vehicle. If the glass is clouded with a milky white substance, have the receiver/dryer checked by a certified air conditioning specialist. leaking air conditioner, possible crack - ac%203.jpg ac%203.jpg
Without Sight Glass On vehicles that are not equipped with sight glasses, it is necessary to feel the temperature difference in the inlet and outlet lines at the receiver/drier to gauge the refrigerant level. Use the following procedure:
  1. Locate the receiver/drier. It will generally be up front near the condenser. It is shaped like a small fire extinguisher and will always have two lines connected to it. One line goes to the expansion valve and the other goes to the condenser.
  2. With the engine and the air conditioner running, hold a line in each hand and gauge their relative temperatures. If they are the same approximate temperatures, the system is correctly charged.
  3. If the line from the expansion valve to the receiver/drier is a lot colder than the line from the receiver/drier to the condenser, then the system is overcharged. It should be noted that this is an extremely rare condition.
  4. If the line that leads from the receiver/drier to the condenser is a lot colder than the other line, the system is undercharged.
  5. If the system is undercharged or overcharged, have it checked by a professional air conditioning mechanic.
Fig. 3: Checking the refrigerant charge if the system has no sight glass.
Posted on Jun 07, 2011
Why is water leaking on the floor from my haier air conditioner
Window A/C units will dehumidify the rooms as they operate. The unit has drainage at the rear. It is important when installing the unit to ensure that the unit slopes slightly OUTWARD to allow the water to drain to the rear. Otherwise the drain pan fills and the water pours into the room. If the unit IS tilted outward, then check the drainage holes for obstructions.
Aug 01, 2014 | Haier HWR08XC7 Air Conditioner
How do I drain water from a toyotomi portable ac unit
1. put it on higher position near water drainage, window...etc
2. make hole in water tank
3. put tube in hole and lead tube in drainage or outside (hole in frame of window recommended for long term use). Fix tube with glue
4. take care that water tank is higher than end of the tube
5. done
Jul 06, 2014 | Toyotomi TAD-T40LW 14000 BTU Portable Air...
GE Air Conditioner AEH10ALG1 Leak
You may have to tilt your A/C downward toward the outside to get condensate to flow out
May 21, 2013 | Heating & Cooling
I have AEPF313716 leaking water from air handler
You need to check the drain and ensure that the drainage tray slopes in the correct direction, check the back of the machinefor the draiage tray and the drainage pipe
Jun 01, 2011 | Intertherm P3RA-024K Air Conditioner
Drainage occurs near the front of the unit, resulting in pools of water leaking onto my window sill. Unit is installed properly, there is no drain hole to direct water away from the insides of the walls...
The A/C unit should be tilted slightly to the rear and this will allow the water to leak to the outside of the window, you may have to drill a small hole in the case to drain if there is no pre-existing hole.
Aug 15, 2010 | Frigidaire FAC126P1 wall/window Air...
My Mitsubishi air conditioner has started to leak heaps of water from the side of the unit. It would appear to be something like a blocked drainage system, but I do not know how to open the unit to clean...
find the drain hole in the rear of the unit and take a piece of wire and rat the drain hole out, its got mold growing inside and plugging the drain
Oct 25, 2009 | Heating & Cooling
A.C. unit is draining on the inside of the house.
There is a drainage and it is stucked with dust, mold etc. Just open metal lid on the wall inside your house, where the coil is installed and where you're changing filters, remove air filter, there at bottom you will see the drainage hole (now under water probably). Rent an air compressor from Home Depot or Lowe's, stick the hose to that hole and turn compressor on. This shall blow the drainage through. After that slowly pour 1-2 cups of Chlorox or Tylex in there, let it stand for 15 minutes, then pour some more water and blow with compressed air again, then flush it with water and blow last time.
Do that at least once in two years, or you gonna have same problem again.
Sep 14, 2009 | Frigidaire FAC126P1 wall/window Air...
Leaking water
I had exactly the same issue after using it for a couple of months.
I fixed it by removing the left panel (the one with the grid) (6 screws and pull the panel down).
There is a small white tray in the mid section toward the back of the unit. the top drainage hole is right there and in my case was completly blocked with wet lint.
!!! the fins of the radiator are extremely sharp...
Jan 13, 2008 | DeLonghi PAC C100 Air Conditioner
Sharp CV10NH Air Conditioner Logo
212 people viewed this question
Top Sharp Heating & Cooling Experts
AJMAL KHAN
Tim Whalen
Are you a Sharp Heating and Cooling Expert? Answer questions, earn points and help others
