Question about Dryers
What would cause the thermal fuse to keep blowing?
  • Dryers Master
  • 7,482 Answers
Hi kbdowe...
You are overheating and normally this is the first thing to check for.
Check for a major lint buildup in your vent and or inside of the dryer around the blower wheel or the air discharge pipe from the blower to the vent pipe...check your flow of air out of the vent to make sure it is clear.
Please take time to rate me
Posted on May 25, 2011
E28 error. Why does the thermal fuse keep blowing out?
If the thermostat is not functioning properly the heater will run "wide open" and overheat.
Feb 07, 2016 | Water Water Heaters
Lg dryer keeps blowing thermal fuses we have checked the thermostat and the element all have continuity
The thermostats (outlet and on element case) can still allow the heat to go to high, restricted airflow will also cause them to go.
Jan 31, 2015 | LG DLE3777 Electric Dryer
Thermal fuse in dryer keeps blowing out
Hi Janet Douglas
Check to make sure your vent is clear, this can cause the overheat problem and blow the thermal fuse.
Also check to make sure the blower is not full of lint also as this can cause the same problem you are having happen.
Another thought:
Right after replacing a dryer element, always run the dryer on air fluff/no heat, and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element and thermal can burn out very quickly.
Bud
Oct 14, 2012 | Whirlpool Dryers
Thermal fuse blown on kenmore dryer what is the cause
The thermal fuse blows when the vent gets restricted and builds up too much heat. After it gets to a certain point the thermal fuse blows. Clean out the vent, keep the lint trap clean, and hopefully your problems will go away.
Feb 04, 2012 | Dryers
My dryer keeps blowing the thermal limiter fuse or switch,what ever it is called.why?
Hi candwloc..
If the thermal fuse /thermostat overheats the dryer will not operate.
It's located on the blower housing and it cannot be reset.
A vent clogged with lint can cause the dryer to overheat and keep blowing the thermal fuse/thermostat.
You can test it with an Ohm meter or continuity checker, if no continuity, replace it.because it is faulty.
Jul 24, 2011 | Frigidaire FEQ332E Electric Dryer
Russel Hobbs RHNPC800P Slow cooker keeps blowing the thermal fuse. What would cause this???
two things, the thermostat allows the cooker to get too hot or the thermal fuse rated temperature is too low. Try get a thermal fuse with about a 10 deg higher rating.
Apr 18, 2011 | Russell Hobbs RHNPC800P 8-Quart Slow...
The thermal fuse in my Raypak 105B pool heater keeps blowing.
The thermal fuse react to rollout flames from the burner. Whatever caused your first one to fail caused the second and will continue to be a problem until fixed.
You could have a clogged up heat exchanger from soot and/or debris. You can also have problems with clogged burner tubes.
Finally, you could simply have wind issues that would require a high wind stack being installed on the heater to correct.
Jul 25, 2009 | Pentair Minimax NT Heater
Keep blowing fuses
hi, make sure you are using a time delay fuse and not a regular fuse. this may be the reason why the fuse keeps blowing out on your dryer.
Mar 09, 2009 | Whirlpool LGV4634JQ Gas Dryer
Thermal fuse keeps blowing
they will blow if the heat dont get out of the dryer and builds up inside / check and see if vent hose behind dryer is kinked or vent going outside is open / it will be one of those two.
Nov 25, 2008 | Amana ALE331RAW Gas Dryer
Dryers Logo
37 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
