Question about Casio Exilim EX-V7 Digital Camera
Blank screen i dropped my exv7 camera today. when i opened it, there is no picture at all. the screen is completely blank. plzzzzzzzzzzzz help me
Same thing happened to me, i really dunno what to do... help? anyone?
Posted on Aug 18, 2008
Blank screen on Canon Powershot S2is camera
hi.if you are telling both viewfinder and lcd are blank or black the problem is in the shutter that you found inside of the lens are not open.sometimes the cuase of the is humidity or moist goin inside of the shutter thats why it will not work properly or stuck up.if you can open your camera and adjust the shuuter from lens unit its better .but if not its better you bring to service center and request for adjustment.
by the way try also to reset your camera to default setting maybe it will help you.
thank you
Jul 08, 2010 | Canon PowerShot S2 IS Digital Camera
Camera was dropped and now pictures take but are completely black
As has been explained many times, dropping a camera damages it. Damaged cameras do not work. They are what is technically known as 'broken'. You will have to get it repaired.
Sep 20, 2017 | Panasonic Lumix DMC-LZ7 Digital Camera
Viewing screen is completely blank and will not take pictures
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Dec 26, 2009 | Canon PowerShot A620 Digital Camera
Lines on screen and photos, too bright photos outside
Lines across your pictures or pictures too bright are due to the shutter not closing correctly or at all.
to check this- turn camera on, turn off flash, turn camera around and look into the lens. Adjust the zoom so that the shutter and internal lens comes up to the end of the lens and whatch as you take a picture. You should see the shutter close completely over the lens. If it doesn't move or does not close over completely then there is your problem.
If camera was dropped it could have jammed the shutter open or obstructed it in some way from closing completely.
camera will require repair/ service.
You may have some luck if you power up and down your camera numerous times before taking a picture. The action of the lens opening and closing may free the shutter.
Aug 07, 2009 | Fuji FinePix V10 Digital Camera
SONY DSC-T70 blank screen! touch screen camera T^T!
The same thing happened to my Sony DSC-T70 today after I dropped it. White screen with green vertical lines. Need help!
May 11, 2009 | Sony DSC-T70 Digital Camera
Blank
You probably damaged the lcd screen. Usually you can see a crack across the screen. However sometimes a drop can just unseat the connector for the lcd. To repair you will need to dissasemble and either replace the lcd or reseat the connector This is quite techinical if you don't have electronics experience I would advice against it.
Jun 10, 2008 | Fuji FinePix A303 Digital Camera
My lens is stuck open
goto http://www.digitalcamrepair.com/self_diagnosis_page.htm
for self diagnosis.please let me help you before leaving a bad feed back.
Try
Apr 20, 2008 | Kodak EasyShare V1003 Digital Camera
White screen, won't take pictures, battery door won't open!!
Sony customer support is the place to go but I suspect a new camera is likely to be a more economic option
Jul 28, 2007 | Sony Cyber-Shot DSC-S40 Digital Camera
Casio Exilim EX-V7 Digital Camera Logo
97 people viewed this question
Top Casio Cameras Experts
Greg Cann
Greg Cann
Are you a Casio Camera Expert? Answer questions, earn points and help others
