I have a a seeburg LPC1 1963 Jukebox was working fine,just stopped dead turntable doesant go round ,selection buttons have stopped working.The only working part are the lights nothing else, Turn it on & the lights work thats it .Can any one out there help me please.
    Problem Solver:
  • 17 Answers
Check all fuses..a recap of the machine would fix this issue if it was a suddon stop dead and nothing symptom racaping is a good idea just after you see it run no matter how poorly but it would be a mistake to recap the machine right now because you have a hard fault and recapping presents it's own problems..no.
check all fuses first if not the fuses check to see all of the plug in cables are plugged in wiggle all of the plugged in wires it's possible one of the wires (or more) have hardened and is causing a short or intermittant problem (wires tend to get more flexible when warm as oppossed to when they're cold and THIS may be the issue! if AFTER you've checked on those two things and neither of the items helped at all? then it's time to call a repair man.voltages in any electronic device can be lethal and unless you know your way around electronics I would NOT advise you to go ANY further than the two checks I've given you here. let us know how it turns out
Posted on Aug 23, 2012
3 Suggested Answers
MechMusicSF
  • 16 Answers
SOURCE: i have a 1963 seeburg jukebox. the motor runs and
Your Seeburg LPC1 or LPC480 is well overdue for an electrical overhaul.
It most likely can no longer write selections into the memory, or read them out if they're being written in. No way to tell from here. A jukebox that old probably needs to have the units underneath rebuilt with new capacitors. Their lifespan is usually about 25 years, so no surprises there. This is common for all old jukeboxes. Google Vern Tisdale or Bill Bickers for the rebuild kits. You need to solder and read a schematic to do the work, or find someone who can, but the actual parts are not all that expensive.
Posted on Feb 28, 2010
  • 195 Answers
SOURCE: trying to hook new amp to old jukebox??? 1963 Rockola
Hi Randy,
I take it that the output from the jukebox is mono (only a signal and screen cable) and the connection to the amplifier is a phono plug. You could make up a cable by using a phono inline socket and two phono plugs. I would think that you could purchase one from your local electronic store. If you make one up it should be made using a screened cable.
Regards
Alan Hood
ami-man
UK
Posted on Mar 03, 2009
Seeburg 1960 AQ 160 Jukebox. The mechanism very hard to turn even with finger. Turntable not turning with lube added.
Rotate by hand till shaft actually receives lubricant especially if you did not remove the turntable to apply the lube 1960 model all oil dried up contaminated with dust of 57 years
Apr 25, 2017 | The Audio Players & Recorders
Where can I hire a repairman to fix my Whirlitzer juke box?
go google and type in--- service agents for wurlitzer juke box ---
find and agent closest to you and call him on the phone
Dec 23, 2016 | Audio Players & Recorders
Jukebox problems
If you can't find a scan button to move the carriage then select a number at the other end of the rack so you can fill it
Dec 25, 2013 | Audio Players & Recorders
I have a 1971 SEEBURG MODEL USC2 "Bandshell"
Tormat has been energized by movement over the carpet, someone touching it with a high charge or natural static in the air of a dry house. There is a procedure to deenergize the tormat with a battery. I am searching for the battery size and procedure myself. I will come back if I find out
Jan 11, 2011 | Audio Players & Recorders
Can weak tube be cause of jukebox not picking up records
1> be sure the service switch is in the PLAY position.
2> It's impossible to determine if the selections are not being written in to memory, or read out from the memory. it could be either.
You most likely have to have the control center looked at, common with a machine this old. The capacitors in your control unit on the back door have probably gone bad, which they do after 25-40 years. Your jukebox is from 1960, so it's time to have both the amplifier and control unit rebuilt. Not what you wanted to hear, but it has to be done. If you're handy and can solder and read a schematic, you can buy the kits on eBay or do a Google search for Bill Bickers or Vern Tisdale. Both sell the rebuild kits.(Feb 27, 2010)
Jan 24, 2010 | Numark TTX Turntable
I have a 1963 seeburg jukebox. the motor runs and turntable goes around normally. but it wont pick up the record. i think its the cam. help thanks
Sep 29, 2009 | Car Audio & Video
I have a 1971 seeburg firestar jukebox - the zero (0) does not seem to work when you punch in the 3 numbers for the selection - so none of my selections that have zero in it do not play - also I do not...
Same key that operates the locks on the sides unlocks the top, but top might be sticky. Push down on it.
Order keys if you don't have them. It's key F291. GOOD locksmith can make it or order one off eBay.
Your jukebox is a USC2. Use that model number as a reference.
Keypad "0" contacts are probably dirty or broken, or the connectors to the keyboard or black and gray boxes might be loose or need cleaning. Circuit board might be dirty (YES! This is a common Seeburg issue). To clean it of check for broken contacts on the "0" key, you'll have to remove it and open it up. Putting it back together can be tricky. Be patient.
Worst case, you can install a replacement keyboard.
If you have someone come out, be SURE to have them give the jukebox a good lubrication. Seeburgs are complicated machines and need periodic lubrication.
Also, buy a manual. Jukebox repairmen don't usually have the manuals for your jukebox. Too many.
Mar 07, 2009 | Audio Players & Recorders
299 people viewed this question
 Grubhead
Grubhead
