SOURCE: TRACTOR BLEW WHITE SMOKE, AND STARTS TO SPUTTER
Start with making sure your oil lever is not over full. If it is it may be getting into the crankcase breather hose that goes to the carburetor hence the white smoke. Sometimes also you can blow a gasket in the breather system and it will do the same. Check for oil leaks in the breather system. Hope this helps. donnyb60
SOURCE: Knocking in mower deck or belt clutch when engaging blades, motor bogs / slows down
YOU MAY HAVE A BENT BLADE OR EXESSEIVE BUILD UP UNDER THE DECK
SOURCE: Craftsman riding mower blades will not engage
maybe the safty switch under seat might be starting to go out if that switch doesn't work the blades wont come on at all for safety
SOURCE: mower made huge cloud of white smoek and shut off
Check for spark at the plug.
If the engine has points and condenser . check to see if the points are good.
If electronic ignition, then it is likely the ignition module is the cause
SOURCE: i have a bolens 38 inch riding mower. it cranked
did you try depressing the clutch to disengage everything regardless of being in neutral? and it sounds like a pulley bearing went bad.try to spin the pulley with your hand and see if it moves.take the belt off to the mower deck and that should keep them from turning when you go to start it.
Testimonial: "thanks. at least i can crank it and get it to a trailer instead of pushing it. i really appreciate it.......cb"
