Question about Bosch Evolution 500 SHE45M06UC Built-in Dishwasher
Bosch she45mo6uc/52. came home today and is has a loud hum. looks like it never got water in. the dry soap is just laying inside.
  • 1,536 Answers
The humming noise is either from the pump motor or the water inlet solenoid. One of them is stuck. Take the mopboard plate off the front of the dishwasher and look for the solenoid. It will be a cylinder with two wires attached stuck onto a box in the water line. Start the dishwasher and touch the solenoid with a finger (naturally not the electrical terminals). If you feel it vibrating in time with the hum but do not hear the water running in, the valve is stuck closed. In this case the solenoid may rapidly get hot; that's why you just touch it with a fingertip.
If water comes in and the big motor in the middle starts humming as soon as the fill is complete, then the pump is jammed or the motor bearings are frozen. You'll have to disassemble the pump (from inside the tub) to see what's going on. You should be able to freely rotate the pump impeller and the motor shaft by hand (this is inside the pump; don't confuse it with spray arm, which is spun by reaction from the water spraying out rather than a mechanical connection to the pump motor).
Another possibility is that the water fill level switch is hung up and signaling a complete water fill when the unit is still dry. If this is the case, when you start the dishwasher you may hear the water solenoid briefly, then the pump will start running immediately. Since it has no water, it will just spin at full motor speed. A quick test for this is to pour about a gallon of water into the dishwasher, then close the door and let it run. If it runs normally until it gets to the rinse cycle, then it's either the level switch or the solenoid valve. (Be sure it isn't a pump problem first or you'll have to get the water out while you can work on it!)
Posted on May 24, 2011
My Bosch she45mo6uc/50 dishwasher will not advance to the wash cycle. It makes a series of clicks, but nothing happens. It just stops. Any ideas?
The most common problem that causes this with this particular unit is the water heater unit failing. It will clod rinse but then when it fills and tries to heat the water, it senses that the heater unit isn't functioning and errors out
Sep 21, 2015 | Bosch Evolution 500 SHE45M06UC Built-in...
Bosch dishwasher turns on but doesn't fill with water and start washing
There is a float in the dishwasher that sometimes gets stuck and when that happens, the washer will not fill. Look for a (mostly round) upright part that will be in the front of the washer either on the left or right side. That is the float and it could be stuck in the cutoff position (caused by the soap). The older models have it on the same side where the soap is placed. The newer models have it on the opposite side to stop that exact problem. MOve it up and down and clean out any dried caked soap that might be under it.
Good Luck
Nov 19, 2011 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
My Bosch dishwasher leaves soap on the dishes and glasses. I wind up rinsing and drying everything over again by hand.
It looks like rinsing is not proper inside the chamber.
Check your water inlet. Clean the strainer attched to it at the machine end.
Apr 11, 2010 | Bosch SHU9915UC Dishwasher
Softener won't empty in Bosch Classixx 1000
take out the soap drawer clean in hot water inside the machine where you took the soap drawer out at the top look for the hole where the water runs out it may be blocked with mildew dettox mildew spray is very good at breaking all that down spray in leave for a while put soap draw back in and do a wash without clothing as spray contains bleach
Mar 30, 2010 | Bosch Classixx WFL 2066 Front Load Washer
Cutlery is cloudy and dirty, some food is dried onto knives and forks. Cups and glasses are cloudy and not clean on inside. Coffee or tea stains are not removed. Plates and soup bowls seem OK , and water...
they must have changed the way they treat the water in your area. those spots are caused by hard water. www.dishwasherfilter.com has a product out for this problem. it filters the water going into your dishwasher leaving them spot free and crystal clear with every load. you will love the way your dishes look.
Mar 21, 2009 | Bosch Evolution 300 SHE43M05UC Stainless...
Bosch Nexxt 800 series - washer doesn't always spin dry enough
First inspect the water pump then the pressure switch. Soap buildup can cause this too.
Jan 27, 2009 | Bosch Nexxt Premium WFMC6400UC Front Load...
Ran the dishwasher and the water didn't drain completely. Checked the drain line for clog - it was clear. Scooped out the remaining water (barely covered the flat wire mesh filter in bottonm of the...
Hello Ramona Doug,
Try disconnecting power from your dishwasher for a few minutes to clear the memory and then reapply power again. Start a wash cycle without dishes on the hottest water setting and after a few minutes.. pause the wash and add a few cups of white vinegar to the wash water.,. that will help break up deposits in the system.. See if that gets you going properly.
Regards
Oct 13, 2008 | Bosch Dishwashers
Washing Machine (bosch)
It's caused by blockages the holes in the water divertor (or whatever it's called) in the roof of the soap dispenser. Not enough water flows through during the cycle to cause the siphoning action to happen which then flushes the softener through. I've noticed these holes regularly get blocked with mildew (black staining) since water lays on the plastic providing an ideal environment for mildew . A quick solution is to clear the holes using an old toothbrush or similar. Longer term is to carefully remove the water diverter panel by pulling down at the back and also sliding a thin metal blade (eg old knife) between sides of the panel to unclip it as you pull down. Rather fiddly and danger of splitting the plastic. However if you succeed you can then clean all the mildew away and replace. However it will return unless you manage to keep the soap dispenser dry - perhaps by leaving drawer open. I suspect this is a design problem since it never happened with an old Hotpoint machine I had.
Nov 11, 2007 | Bosch Classixx WFC 2465 Front Load Washer
Bosch dishwasher
Although I previously posted with the same problem of a film on the dishes after cleaning, I did find a section in the owner's manual which solved my problem. Lift up the rinse aid cap on the inside door - the factory setting is on "4". The rinse aid works in conjunction with your local water, which has variations in it's hardness or softness. When your dishes are streaky, lower the rinse aid setting to 1 or 2. If your dishes are spotted, raise the rinse aid setting higher.
Sep 23, 2007 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch Evolution 500 SHE45M06UC Built-in Dishwasher Logo
243 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
