Question about Toshiba Satellite L455DS5976 Notebook
How to install ram for a toshiba satelite l455d
  • Toshiba Master
  • 4,338 Answers
  • Power the L455D down and turn it over on a table. Locate the two battery latches near the top of the notebook. Push each latch away from the other one, then pull up on the back of the battery to remove it. Unplug any cables that are currently plugged into the machine.
  • 2
    Locate the memory module cover, which is just under the battery compartment, and remove the screw holding it in place with your small Philips screwdriver. You will see the current chip in the bottom slot in the memory module.
  • 3
    Hold the replacementRAM chip by the two corners that are away from the metal contacts.
  • 4
    Place the RAM over the second slot, which is located just in front of the slot where your current chip is resting. Align the replacement chip so that the notch along the metal contacts matches up with the key in the RAM slot.
  • 5
    Hold the replacement RAM chip at a 30-degree angle from the computer and slide it into the empty slot. Once the chip is all the way in, press down on it to lock it into place. You will hear a "snap" when the chip is locked in.
  • 6
    Replace the memory module cover and screw it back into place. Then replace the battery and the cables, turn the laptop over and power it up.
  • If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
    Thanks, Joe
    Posted on May 24, 2011
    Toshiba satelite pro laptop does not recognise hp deskjet2050A
    This should be the installation utility for your printer:
    http://ftp.hp.com/pub/softlib/software12/COL32609/al-109407-2/DJ2050_J510_1313.exe
    Just download and install the utility and your laptop should pick up the printer no problem.
    Feb 15, 2013 | Toshiba Satellite Pro C850-10N 15.6-Inch...
    What is my motherboard on a Toshiba satellite l455d-s5976?
    the only way to really know the model is too take out the motherboard . im currently going through the same thing i purchased a motherboard online made for this model once i recieved it it was different than the original so instead of just transferring cpu and ram ect. i had to get new stuff all around . also it was a different machine after that ie. stickers on laptop say AMD cpu now its intel basic stuff like that. the model means nothing basically you have to see the numbers on motherboard.
    Jul 20, 2012 | Toshiba Satellite L455D-S5976 Notebook
    Can i install 2 sticks of ram in my computer
    looks promising according to this spec sheet this satellite is configured with 2 gig now and can go to 8 gig(depends on some factors) take a look at this sheet and then you can decide
    May 22, 2012 | Toshiba Satellite L455D-S5976 Notebook
    Toshiba satelite l455d s5796 hinge problems
    If manufacturing problem they should repair it might if you try to repair or open the monitor you can't get warranty. Otherwise you can contact for warranty.
    Apr 14, 2012 | Toshiba Computers & Internet
    How do i unregister toshiba satelite hdd1/ssd1 password
    99% of the time if the hard drive has a password on it and the possessor does not know the password, it's a stolen laptop. The original owner put the password on to keep thieves from getting into sensitive data. Sometimes the original owner can set the password on the drive remotely after it was stolen. The drive is locked forever unless the person that put the password on unlocks it.
    Mar 23, 2012 | Toshiba Satellite L455D-S5976 Notebook
    Toshiba satellite L455D-S5976. Says loading windows, then black screen with cursor. How can I do a complete factory restore?
    you need the windows operating system installer of your laptop and first boot it then look for repair of option then follow the step in repairing.
    Jul 10, 2011 | Toshiba Satellite L455D-S5976 Notebook
    My Toshiba satellite L455D-S5976 gets static with playback on a USB headset. Could this be a codec issue?
    According to toshiba ,This computer came with Windows 7 installed. However,since the computer was manufactured,there's been a new audio driver released for Windows 7. This is most likely the solution to your problem.If there are CODEC problems, this (driver) is how manufacturers usually correct them.
    Click the link below to download the driver. The driver is self-installing.
    http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=SB&os=&category=&moid=2439385&rpn=PSLY5U&modelFilter=L455D-S5976&selCategory=2756709&selFamily=1073768663
    Mar 04, 2011 | Toshiba Satellite L455D-S5976 Notebook
    How do I install additional ram in a toshiba satelite
    There is place under laptop where you add additional Ram.Just remove the bolt and then cover. There are 2 places for Ram.
    Mar 19, 2010 | Toshiba Satellite M115-S3094 Notebook
    Toshiba Satellite L455DS5976 Notebook Logo
    Top Toshiba Computers & Internet Experts
    Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
