I have a 32" Emerson LCD-TV and when I turn it on, it will only stay on for 2 seconds or so and then it goes back to sleep mode
  • 1 more comment
  • ylharris Aug 15, 2008
    How do I reset my 32" EMERSON LCD TV If it will only stay on for 2 seconds or so?
  • ylharris Aug 16, 2008
    And I paid $10.00 for that smart assed answer, I want my money back.
    The solution that was offered corresponds with what Emerson's custmer service tech suggested. With this information I can now speak with a little knowledge with the repairmen that I am taking the unit to.
    Thanks again
    Master:
  • 382 Answers
You must look for its sleep up timer that might have been changed by some one.. By restoring its setting you can get out of this problem..This will be a better choice for you or if you wanna reset it then leave it unplugged for 4 hrs and then plug it back but according to me this wont help you in this case..So try to change the timer value using the manual of the tv if your not sure how to do it and finally if all this fails then The fault might be the inverter that drives the backlight. There are 8 stages in it,if one of them was faulty, the screen will try to start up, but if the inverter chip sensed something was wrong and shut the TV down. In few case it might need a new inverter transformer which doesnt cost a lot, but you can sometimes get reconditioned inverters for a reasonable amount...Thank you..
Please post back how things turned on for further assistance...
Kind Regards!!...
Posted on Aug 15, 2008
    Master:
  • 623 Answers
Take it to a tech
    Master:
  • 521 Answers
Reset it.
  • tech expert12 Aug 15, 2008
    change the timer settings. it is set that way so it is happening.
    its definately the sleep timer.for sure.but probably you cannot adjust the timer in 2sec time.it would be set by mistake by someone.so if under warranty call the company person it will take not more then 10 minites for him to set the timer off.and if not under warranty you will be charged not more than service charge.
    he will have to set the timer manually.by opening the tv unit.
    the tv is absolutely perfect,.
    pls rate the solution if helped by it to know your problem. thanks.
Emerson LC320EMX stays in standyby mode
one of the transformers has an issue which is very common for that model. You can get a replacement inverter from www.tvrepairworld.com
Mar 31, 2012 | Emerson LC320EMX 32 in. LCD HDTV
Tv does not stay powered on.
it could be many things.. usually indicates a short somewhere on one of the boards.
Apr 10, 2010 | Emerson LC320EM8 32 in. LCD TV
Emerson lc32oem8 32
The flashing power light indicates a failure in the power supply board of your tv. We should be able to repair the board for our standard rate of $45 plus return shipping. If you are interested in setting up a repair please use the following link to our web site: http://www.ccl-la.com/blog/index.php/service-request-form/ Our normal repair turn around time is 2-3 days.
Buddy
Corporate Computer
www.ccl-la.com
Mar 08, 2010 | Emerson LC320EM8 32 in. LCD TV
I have a LCD Color TV, but when turn on, green
The most common problem is the Power/Backlight Inverter Board. There are 6 mini transformers on the board, one goes bad and the TV will turn itself OFF automatically for " Protection Mode". Replace the whole board or replace the bad mini transformer.
Part number#
Whole board, BA71F0F01042
Mini Transformer, LTZ2PC0MS008
Mar 02, 2010 | Emerson LC320EM8 32 in. LCD TV
Westinghouse model tx-47f430s lcd tv wil not turn on
This is known as SLEEP MODE problem.
Simple solutions:
1. Get a power surge protector / strip.
2. Plug your TV power cord to the power surge.
3.Then turn-on your TV using the remote control. Just in case it won't go all the way to normal state.
4. Turn-off the switch of your power surge like 5 times with an interval of 3-5 seconds.
5. Then repeat step 3 and 4.
6. These step is done to over-ride the sleep mode.
Roan
Feb 16, 2010 | Westinghouse TX-47F430S 47 in. LCD TV
TX-47F430S seems to be the common problem of going back into standby. Powers up shows the logs and then goes back to low power. The light never goes blue. The fiber optical laser turns on and stays on but...
This is known as SLEEP MODE / STANDY MODE problem.
Simple solutions:
3.Then turn-on your TV using the remote control2_bing.gif. Just in case it won't go all the way to normal state.
6. These steps are done to over-ride the sleep mode.
Roan
Jan 29, 2010 | Westinghouse TX-47F430S 47 in. LCD TV
Emerson LC320EM82 S LCD TV I purchased this TV a year and 3 weeks ago. It suddenly stopped powering on. When I turn it on the screen comes on for half a second with 3-4 inch white lines across middle of...
Your not alone with this problem.
I had to fix mine. The warranty is less than impressive.
The trouble is going to be the Power Supply/Backlight Inverter board.
This is the picture of yours:
11e1946.jpg This is board # BA71F0F01042. Replacement boards are hard to come by.
Fixing the board like I did seem to be the only option. If you need info on fixing it, let me know.
Jun 18, 2009 | Emerson LC320EM8 32 in. LCD TV
My emerson tv standby light is on the power light flashes twice
Mine stayed in stanby mode and all I had to do was to switch the plug to a different outlet. The power strip it was on wasn't providing enough power. It worked fine for a month before I had a problem.
Dec 04, 2008 | Emerson EWL3706 37 in. LCD Television
Monitor in sleep mode
I think it maybe time to buy a new monitor
Aug 09, 2017 | X2Gen MG15VT 15" LCD Monitor
Open Questions:
Televison & Video Logo
32 people viewed this question
Top Televison & Video Experts
