Question about Garden
I bought a Craftsman Garden Tractor, model # 917.28947 a few months ago. It has less than 20 hours of operation. Each time we mow there is a squealing sound coming from the mower deck and one or both blades slow down. Is this a drive belt issue or a lubrication issue?
wadembly
  • 462 Answers
SOURCE: 42 inch Craftsman blades won't engage
is the belt spinning & smoking when blades are engaged or the belt won't spin if the belt spins but blades wont go then there is something stuck under the deck or the bearings are gone out do to not being greased
Posted on Jun 14, 2009
  • 246 Answers
SOURCE: Concerning a Craftsman 24hp garden tractor. The
Hello jejodaro:
>>You have to Hold the Shaft on the Blade Side with a Pipe or Strap Wrench or Depending on the Model, you can Block the Blade an Hold the Shaft so the Pulley Nut can be Loosened/Removed.
>>If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance. Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Happy. Thanks.
Respectfully
John
Posted on Apr 21, 2009
wadembly
  • 462 Answers
SOURCE: Craftsman riding mower blades will not engage
maybe the safty switch under seat might be starting to go out if that switch doesn't work the blades wont come on at all for safety
Posted on Jun 28, 2009
  • 27 Answers
SOURCE: disengaging blades when mowing completed
the cam plate that the tensioner pulley is mounted on that rotates back around to tighten the belt as the cable or rod is engaged is likely rusted and worn, there is a bushing in this pivot that can be removed and cleaned fairly easily with a abrasive wheel or pad and lubricated upon reassembly.
Posted on Jul 04, 2010
kel1guy2002
  • 3740 Answers
SOURCE: I have a Craftsman GT 5000 Garden Tractor, 25 HP,
Depending on your engine.. Briggs and Stratton or Kohler there are 2 different seat switches that are used to power the PTO clutch. The seat switch can cause the PTO clutch to disengage anytime there is not at least 70 lbs in the seat.
The PTO drive wiring has a 30 amp fuse in it. If by chance a stick went through the belt and tore off the wires at the PTO clutch (Common failure) even after you repair the broken wire you still need to replace the fuse.
Check the PTO clearance gap. It should be 0.012 dis-engaged. Any other value and the clutch will not work correctly. Adjust the clutch if necessary.
There is a 2 pin Pigtail just off of the PTO Clutch that you need to check for voltage at the connector. Probe the back of the wires if you can and your looking for 12V DC under the following conditions.
BRAKE ON or tied down
KEY ON
SEAT (Briggs and Stratton engine only) Someone needs to be sitting on the seat.
Then Pull the PTO Switch out. You should hear the PTO Clutch CLICK. If you hear the click there is no need to check voltage. The PTO switch is a multi function switch and it is quite possible the PTO switch failed. I doubt that the PTO Clutch has failed as they normally give you some kind of noisy indication that they are failing and don't fail straight away.
So.. In short
Check PTO Switch (Red wires) to usually red or brown thru the switch
Check 30 amp fuse
Check PTO clutch wires near PTO clutch (They get torn from something traveling through the pulley)
Check PTO clutch clearance at 0.012
Check Brake switch for an audible click as you depress it some distance No click.. possible bad switch
Listen for Seat switch Click as you slowly add weight to the seat. No Click or any click and it can still be suspect due to the Briggs and Stratton installed engine ones have more than one function.. Ignition and PTO clutch power.
The actual wiring diagram is on page 35 of the owners manal that can be found here:
http://www.managemylife.com/mmh/owner_manuals/27245/CRAFTSMAN-Lawn,-Tractor-L9910386?brand_name_search=917273023
Lastly... check each of the mower deck blade bearings. A seized bearing can cause PTO problems.
Hopefully you have enough information to solve the mystery. If not just respond here and I will help you.
Thanks for choosing FixYa.
Kelly
Posted on Oct 07, 2010
Testimonial: "Kelly - Your troubleshooting info helped me determine the PTO switch, mower belt and 30 Amp fuse were good. Solution: New battery fixed it. Thx! - Tom"
Craftsman tractor 917.273241 25hp Kohler, 48" cut. The clutch return spring will not hold tension more than a few hours of cutting. The temper in the spring end near the exhaust pipe from the engine to...
I'd be tempted to shield the spring from the heat of the exhaust - is there any way to pop rivet on a piece of aluminium sheet and bend it to not impede the operation of the clutch?
Aug 08, 2013 | Craftsman Garden
I have a Craftsman lawn tractor, model # 917.276180. After mowing for about an hour, the transmission starts to slow down and eventually stops. The tractor s/n is 03006D006025 and was purchased new from...
Hi, remove the battery and battery carrier and clean all grass and debris from the hydrostatic drive, cooling fins and fan. I'm not sure what transmission it runs but the solution applies to all. Hope this helps, regards Phil.
Aug 25, 2011 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
New Craftsman 20hp Briggs & Stratton 42" riding mower, Model 917.289104. Loses power, dies while mowing. Will not start unless sits 20-30 minutes. Problem began second time I owed with it. ...
first make sure the air intake screen on top of engine is not clogged with debris if thats not a concern you could have a faulty ignition coil etc your engine should have a two year warranty and can be serviced at no charge to you at your local briggs service dealer make sure and check your manual for the fine print though. Briggs makes a great engine and very rarely have I ever seen a problem allthough if you were to have an engine issue it will accur during the first few hours of opperation good luck
Jan 23, 2010 | Craftsman 20 hp 42 in. Deck Yard Tractor
Smokes when i crank it up and when i engage mowing lever. Smokes from exhaust. just bought mower. It is a lts 2000 09' model. Bought from sears, mower was shortly owned and used.
what moter do you have on let me know ok hey ck the oil it may be over full it wont hurt it you just need to get the level right let me know
Oct 04, 2009 | Craftsman 20 hp 42 in. Deck Yard Tractor
Loud bang, hole in motor
Sounds like you threw a rod. If your warranty just ran out you might be able to get sears to still honor it.
Jul 14, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Craftsman 19.5 riding mower starts runs quits no power
When you let it sit did you remove all the fuel or add a additive? If you did not then I would recommend that you remove all the fuel and add brand new fuel to your system. Gasoline only last for about 3 to 4 months before it will start to go bad and this sounds like your problem
May 22, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Garden Logo
135 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
