Question about Jenn-Air JMC8130DDS Microwave Oven
Screen says "locked" and nothing happens when you
  • Jenn-Air Master
  • 5,125 Answers
The child lock has been enabled on the microwave. To disable the lock, press and hold 0 until the Locked message disappears from the screen. To set the Lock, press Stop/Clear (to clear the display) and then press and hold the 0 pad until the phrase Lock appears and you hear two beeps.
The manual for the microwave is available here: http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=JMC8130DDS&siteCd=JA_EN_US&userType=Consumer . The direct link to the manual is http://www.kitchenaid.ca/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%208112P218-60.pdf .
I hope this helps.
Posted on May 25, 2011
  • Jenn-Air Master
  • 3,740 Answers
Hi and welcome to FixYa, I am Kelly
The child lock function has been turned on. Per the manual below to turn off the child lick press and hole the 0 buttin until the locked display disappears then it should work normally.
http://www.ajmadison.com/ajmadison/itemdocs/8112P218-60.pdf
See page 12 of the pdf file above.
Thanks for choosing FixYa,
Kelly
Ge microwave jvm1740 start and clear/off button not working
Sounds like a bad keypad. You will need the full model number off the microwave to look up the correct control panel part number. Sometimes these type of parts can be really expensive & it may make more sense to replace the microwave depending on the age and condition.
Sep 05, 2014 | GE Spacemaker JVM1740 Microwave Oven
Microwave jes1142
If the timer counts down and nothing else happens, the secondary interlock switch is bad. This switch completes the cook circuit and this is why it doesn't run. You need an ohm meter to diagnose and find the right switch. Switch failure is caused by opening the door when it is in cook mode. Push the stop button first before opening the door and this failure will cease to occur. BE CAREFUL !!
Oct 09, 2013 | GE JES1142SJ Microwave Oven
Maytag Microwave mmv4203ds00 SE Error code
Not always is in the keypad the problem,in my work the problem was in one of the connectors in the control board.Resolder the contacts and it'll be fine.
Nov 22, 2011 | Microwave Ovens
We have a Samsung MT1044WB/BB/CB. It is a Toast & Bake Microwave Oven. We have never used any function except the microwave oven over the 8-10 years since we bought it new. We have not used it in...
The computer died. Not much you can do with it. After ten years it doesn't owe you anything.
Of course you could bypass the whole timer with a toggle switch if you were MacGyver.
Apr 10, 2017 | Samsung MT1044 1000 Watts Convection /...
The cleaning lady cleaned the microwave inside and
It may be that the child lock has been operated accidentally, although if that were the case the POPCORN button should not work.
If the lock is on you should see an L in the display.
If the problem is the safely child lock you have to press and hold the
CLEAR/OFF button for about three seconds.
Apr 05, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
The microwave seems to be stuck on delay
thats what the express does its a one button start it
there s nothing wrong with the unit it is doing exactly what is programmed for what you are pushing
Oct 24, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
The touchpad on my microwave has quit working.
possibly a stuck button which would mean a replacement pad, do the buttons bleep when you push them do some work and others dont its quite common normally its the start button or the cancel which goes(due to constant pushing) and it causes the error alternatively its a possible logic board fault which is far more expensive to replace!
Nov 12, 2008 | Microwave Ovens
On the display screen it flashes clock and what ever buttons you push nothing happens
not exatly shure how it was done all I did was uppluged the unit cleaned it and replaced a burnt out bulb and it works
Sep 21, 2008 | Microwave Ovens
Jenn-Air JMC8130DDS Microwave Oven Logo
273 people viewed this question
Top Jenn-Air Microwave Ovens Experts
William Miller
William Miller
Dennis Boxerman
Are you a Jenn-Air Microwave Oven Expert? Answer questions, earn points and help others
