Question about Invacare Health & Beauty
I need to replace my dead battery in my invacare storm tdx5. How do I get the battery out?
2 Suggested Answers
wcdoc1953
  • 280 Answers
SOURCE: I have an invacare ride
The battery charger for this scooter is available from:
http://www.monsterscooterparts.com/
I believe the original equipment charger from Invacare for this scooter was a 3 Amp off board or on-board charger. The charger is no longer available from Invacare. Monster scooter parts shows this as a 2 Amp charger for the Lynx.
It would be more expensive to repair this charger than to replace it since you indicate it failed after a storm power surge. You will be happier by replacing the off-board or on-board charger for a price between $50 and $150. The only cost effective charger repair is the cord or plugs.
If the charger was plugged in during the storm, I would check the power path on the scooter for burnt fuses and wiring. Hope this helps.
Posted on Dec 31, 2010
Motor stopped dead during slow turn on grass, neons light up,but it immediatly shuts down again lights ok motor stays dead.
Hi roybruce
Sounds exactly like a brake problem.
To check this run the scooter as far as it will go untill it shuts down or 10 minutes which ever occurs first.
Then being careful not to get burned touch very carefully with your finger the brake. Located at the end of your motor attached to the free wheel lever.
This could be very hot so be careful.
If the brake or motor is hot replace the brake. If the brake is cool to the touch you could have low voltage. Have your batteries load tested to make sure. Replace batteries if needed.
Good Luck
Tim
May 03, 2011 | Invacare Supply Group Invacare Scooter...
I HAVE STORM TDX5 CAN BE SITTING STILL AND THE CHAIR WILL TAKE OFF BY ITSELF AND GO WILD WHEN I SHUT IT OFF FINALLY IT COMES UP NEUTRAL TESTING AND WON'T GO ANYWHERE CAN YOU TELL ME IF IT IS THE JOYSTICK
Yes, it definitely sounds like a bad joystick control or a bad joystick wiring harness to the controller. Using a hand held programmer you can read the fault log to verify the number of fault codes attributed to the joystick and joystick out of neutral at start-up. Most dealers and certified technicians have the proper HHP to read the fault log and make this determination.
With the power wheelchair off you can feel a bad joystick gimbal by rotating it in circles and forward and back, feeling for rough and dead spots. If it does not come back to neutral when you release it i.e. it is off center, you have a bad gimbal. Because it sounds like a safety issue, I would recommend having this repair done before using the chair again. Hope this helps.
Jan 06, 2011 | Health & Beauty
I have an invacare ride on . The battery charger failed after the storm. Are they repairable or do I need a new one. If so, how much do they cost
Dec 30, 2010 | Invacare Supply Group Invacare Scooter...
INVACARE STORM TDX DROVE OFF OF CURB LOST POWER IMMEDIATELY
Sounds like your battery or batteries became disconnected. Remove the 3 screws holding the rear electronics cover on the chair. Check all the controller connections and specifically the 2 pin plug into the batteries in the battery box. Remove the screws and pull the front battery box cover off. Slide out the battery tray after removing the retaining screws on the bottom sides at the front. Check the batteries for loose or damaged connections and tighten.
If you cut or broke wires at the rear or bottom of the controller you can do a temporary repair and order new parts. You should be able to get the chair to power up if the power path connections are good. If it powers up after a check of the battery connections and power connection to the controller and you still have a fault code, I can help you further. Hope this helps you for now.
Dec 11, 2010 | Invacare Health & Beauty
Message on storm model tdx 3 joystick is ''E 15 M1 power stage faulty''
J I am not familiar enough with the TDX to give you an answer but you can contact Invacare Tech support @ 1-800-333-6900 ask for chair tech suport and explain your problem Hope this helps
Sep 27, 2010 | Invacare Health & Beauty
I have an invacare scooter that doesn't work. Can
mcdevito75 here, It could be the battery--ies need re-charge or replacement, online at Invacare.com they can help out, or almost any Medical Supply store in your area.
Jun 20, 2010 | Invacare Supply Group Invacare Scooter...
Power failure
The batteries may not be dead. When pulling a hill especialy for long periods, you may draw too much current and the circuit breaker will open. If you wait a few minutes you can reset it and resume. If the batteries are not fully charged or in good condition, the unit will shut down it total system voltage drops below 17 volts.
Jun 06, 2010 | Invacare Supply Group Invacare Pronto M91...
Invacare storm series arrow model 3gar-cq seriel 091E000044 the tilt in space function is not being recognized after changing the tilt mechanism. When the switch is turned on it indicates a need to...
Hello :
Check this website please : http://www.ehow.com/about_4826562_invacare-wheelchairs.html
or this : http://www.invacare.com/cgi-bin/imhqprd/index.jsp
or this : http://www.invacare.com/cgi-bin/imhqprd/inv_catalog/prod_cat.jsp?s=0&catOID=-536885218
or this : http://www.invacare.com/cgi-bin/imhqprd/inv_catalog/literature_search.jsp?s=0&doSearch=true&searchType=KeySearch&keywords=STORM%20SERIES%20ARROW%20MODEL%203GAR#SHOWRESULTS
I hope that will help .
or simply contact INVACARE
Feb 21, 2010 | Invacare Health & Beauty
Have an invacare patriot LX4. Unit takes full
Check to see if the scooter is in freewheel mode. To know if the batteries are bad you need to charge them for 10 - 12 hours and then have them tested with a load tester.
Jul 28, 2009 | Invacare Supply Group Invacare Scooter...
Health & Beauty Logo
180 people viewed this question
Top Invacare Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
gnshome
Level 1 Expert
Are you an Invacare Health and Beauty Expert? Answer questions, earn points and help others
