Question about Valor DV-169
How do I connect the dvd player to be able to listen trhough my car speakers
I have kia sedona 2005 and have a question the dvd(movie) the sound not listen outside only with headphone its posssible to do somehing to listen without headphonesand how ?
there is a connection that can be connected to your radio input if you have one, if not you can use the same phono output from the dvd player (its marked) and get a unit that fits in between your antenna lead and the radio that allows you to tune to a frequency and hear your dvd sound through your radio speaker system. (available from ebay)
Mar 03, 2017 | 2005 Kia Sedona
Sirius Sound only on front right speaker !!
is your satellite an external device? and if so what kind of adaptor or harness does it use to hook up with main radio?
Dec 27, 2007 | Kenwood DNX7100 Car Video Player
Samsung ps wx30 surround sound system. speakers are plugged in to dvd player. dvd player is connected to tv via hdmi cable. speakers only work when using dvd player and not tv/sky etc.. am i missing some...
Hi,here is my simple solution...
To listen your TV on your
samsung ps wx30 surround sound system ,
** you need to connect "Audio Output " RCA jacks or "Optic cable output" or "HDMI out " of your TV unit
** to "AUX input " or "TV" OR "Any input" of your
dvd player or "Optic Cable input" or "HDMI input"
** than just switch to respective mode on
dvd player corresponding your RCA or Optic connection or HDMI ..
There you go..Your TV sound is on the
dvd player By this means whatever you watch on the
TV (
tuner, satellite , Xbox , etc..) ,it's sound will come thru your
dvd player.
Hope this helps!..if more he?p requires pls let me know..
Take care and please
Remember to rate/vote and give me 4 Thumbs Up for me to continue f
or Helping out the Community :)
Jun 25, 2011 | Audio Players & Recorders
How can I unlock Sony DVP-SR200P DVD Player, in order to enable it to read any regions?
can sony sr200p-dvp be connected with external 40w speaker for listening music.
Mar 07, 2010 | Sony Televison & Video
My panasonic dvd player is not playing the sound of the main character's voices on two diff. dvd's. Background noise and music is fine. The disks work on another dvd player, and other disks have no problem...
You are listening to a Dolby Digital source and you either don't have a center speaker hooked up or, it's not enabled. If you only have 2 speakers connected to a surround receiver, switch your receiver from surround to surround off. If this doesn't work, or you need more help, specify your system and how it's all hooked up.
May 03, 2009 | Televison & Video
How do I connect a new dvd player to Sony DAVS500?
If DAV-S500 have Input then hook new dvd player there and you can listen surround sound too.
Jan 02, 2009 | Sony DAV-S300 System
Dvd player
If you have a factory DVD player, then while the DVD player is on, press your radio preset numbers' 2 and 4 simultaneously. Then to listen to the CD or radio just press whichever button you want to listen to. You should hear sound out of your front speakers only, and won't interrupt the headphones. Good luck.
Nov 02, 2008 | 2005 Ford Freestyle
Hi there, i have a Kenwood V7090D AV receiver. the problem is a) i cannot switch the DSP off without 5.1 switching off as well and b) DSP affests all channels when speakers B is swithched on. if u can...
If you have only Left and Right connected the receiver wont know what to send to the other speakers without some kind of DSP.
If you are using an optical or coaxial connection from a dvd player it may utilize the other speakers if the DVD player is providing that information.
If you dont like the DSP but still want to have all the speakers function while listening to non surround sound material try setting the DSP flat or to a reduced setting.
If you are listening to a DVD with surround sound information and the DSP off still provides no sound to the rear speakers check the manual for that receiver for a "auto surround detection" setting.
good luck.
May 02, 2008 | Televison & Video
Valor DV-169 Logo
Top Valor Car Audio & Video Experts
David Payne
David Payne
steve morris
steve morris
Tom Chichester
Are you a Valor Car Audio and Video Expert? Answer questions, earn points and help others
