Question about Retro Bicycle Horn And Bell, One Of Each,retro For Handlebars
My bugle horn is broken. It won't sound when I squeeze it and I can feel a ball revolving around the rubber container. Please help!
Game cube has no sound
Sounds like you checked everything but the cables. Is it cut or spliced anywhere? or it could just be old and broken.
Turn on your gamecube and squeeze your sound cables (red and white) if you hear any sound while squeezing the cables its broken. You could either splice it or replace it. Best of luck to you.
Jan 08, 2015 | Nintendo Video Game Consoles & Games
Horn keeps going off on it's own.
My horn is all set now. I took the steering wheel pad off and put electrical tape around the wires and put it back together. It has been fine sense. Thank God.
Jun 17, 2013 | Cars & Trucks
1995 gmc suburban leaking power steering fluid at end of I think is steering column that hooks to something else but there is rubber seal like that is breaking apart that connects the 2 parts together? I...
Sounds like the pitman arm. See #5 on diagram below. It has a ball joint with grease that is held in with a boot. It the boot is cracked open, you should replace the arm. You will need an alignment after replacing the arm. The arm does not contain any steering fluid, so if that is leaking, you have another seal broken somewhere...
Jul 06, 2017 | 1995 GMC Suburban
The brush bar isn't going round ?
your problem seems to be the belt has snapped. Underneath the the hover there is a rubber belt that connects around the brush bar and around the motor, this belt will be broken. They can purchased from any hoover shop for a couple of pounds.
Jan 06, 2013 | Dyson DC24 Ball All-Floors Upright Vacuum...
Revolving brush at front of machine has stopped spinning, what could be wrong
I'm sorry to hear you're having difficulties with your DC24. If the brush bar won't rotate, you may need to reset the machine - please follow the steps shown in the video below to do this. When pressing the red reset button, you may find it helps to use something like the eraser-end of a pencil - you should hear an audible 'click'.
Make sure you recline your DC24 into the vacuuming position before testing it, as the brush bar will not rotate when the machine is standing upright.
This should resolve the issue, but if you'd like any further assistance or advice, please give our customer Helpline a call on 0800 298 0298 (UK), or 1-866-693-9766 (US).
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
May 10, 2012 | Dyson Ball DC24 Bagless Upright Vacuum
Don't have engish manual, machine won't drain
A make and model would really help here. However, I'll take a blind guess at your problem.
This is simply a problem with your empty pump filter being clogged. The empty cycle is timed and if it can't get all the water out in time because the filter is blocked and slowing the empty down, then it will fail safe and won't step on to the final spin cycle with excess water in the drum. Your repeat of the rinse/spin cycle is giving it extra empty time and then the spin works OK.
You need to locate and clean the filter. Depending on the model (not sure which with the model you mention) there is either a round filter cap on the front of the machine at the bottom (It may be behind a small door or hidden behind a clip on panel on the bottom) or, you will need to access the debris trap from the back of the machine.
If there is no filter at the front, pull the machine out and you will see a roughly oval panel at the bottom of the rear of the machine. Unscrew the 3 or 4 screws and unclip. Directly below the drum, you will now see a rubber "Cup" like bulge in the black pipe, with a plastic tube connected to a plastic pipe. The cup is held in place by a large jubilee clip. Unscrew the clip, pull off the rubber boot to expose the debris trap (A conical plastic cage with a ping pong ball in it) Take out the ball and the plastic trap, clean out the debris and replace the trap and the ball (Note that the cage may have a slot in it that locates in the rubber boot, make sure it lines up, or it won't reassemble correctly). Now push the boot back onto the fitting at the bottom of the drum where it came from and tighten up the jubilee clip, making sure that it is fitted correctly (it too may have a small slot out of it that fits around a protrusion on the bottom of the housing).
Jul 06, 2011 | Washing Machines
1989 buick lesabre horn won't blow .check relay's on passenger and driver side under hood .push horn button hear quicking in fuse box under dash on passenger side.help....
possible horn itself is faulty and needs replacing. you will need to locate where the horn is and apply power to the horn from the battery. if the horn sounds then you know that it is a broken wire th=o the horn
May 30, 2011 | Buick LeSabre Cars & Trucks
I have a 1999 buick regal. front end noise
Most often the problem with front wheel drive models and this type of symptom ends up being a loose or broken motor/tranny mount. I'm sure there are a few shops around where you are at that might put it on a lift and check undernethe for free or a small fee. Also, if you have a floor jack and have the time you could check yourself, just look for anything that seems broken/cracked, and look at ALL the rubber componenets for wear and tear.
Mar 27, 2010 | 1999 Buick Regal
1996 Toyota Tacoma, 2WD, front driver side suspension creak. Cannot hear with window closed, but happens when engine is not running (if vehicle is pushed or rolled on uneven pavment). Have not noticed any...
Could be your upper and lower ball joints. squeeze the boots and see if you can feel any grease inside. With 160k miles it may be time to change them. Sway bar links and tie rod ends also have rubber boots protecting their ball joints.
Apr 15, 2009 | 1996 Toyota Tacoma
Retro Bicycle Horn And Bell, One Of Each,retro For Handlebars Logo
205 people viewed this question
Top Retro Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Retro Cycling Expert? Answer questions, earn points and help others
