I have a 32LG20. It has been working great but all of a sudden the remote stopped working on the TV only. It still works on the cabel box but not the TV. I tried reprograming the remote as well as other remotes but still does not work.
3 Suggested Answers
mosthated357
  • 91 Answers
SOURCE: Philips TV HDMI CEC EasyLink tries to control Cable set top box
I have a phillips 42 lcd and i have fios they both work fine with fios remote ill give you the phone number to call they will give you the remote code (412)497-7911 Call tommorow before 6 they will give it to you its verizon pittsburgh number i worked for fios for a few years...Please rate me when you get a chance..
Thanks,
Steve
Posted on Jan 04, 2009
  • 4 Answers
SOURCE: tv remote controle codes for starchoice 5-in-1 remote (sharp aquos tv)
you might try unplugging the TV and then plugging in again. It worked for me
Posted on Nov 27, 2010
My comcast remote was working with my Motorola dct700/us box and now suddenly stopped working
Put in new batteries or check that the battery contact points inside the remote are free of rust or acid build-up from leaking batteries.
Dec 06, 2013 | Arris DCT700 DTV Receiver
My lg tv suddenly stopped working with the remote? Didn't change anything. Just woke up and the remote would not work. Changed batteries but no luck. Tv works but remote no longer works with it
Visit this site. Type in the site name "Electro-help" in yahoo search box. Pull up older posts there. You will get all details. Codes, setup proceedings etc:-
Jun 09, 2012 | LG 32LG30 32 in. LCD HDTV
I purchased a 32 inch flat screen coby tv on 11/2010. I am trying to advance the channels with the right up and down channel button on the remote, but it only goes to favorites. I only want to advance...
Are you using the cable box remote on the cable box or the coby remote on the cable box? or are you using the cable box remote on the TV or the coby remote on the TV? Try using the coby remote on the TV without the cable box connected first to see if the remote even works on the TV, replace the batteries and retry. then try the cable box remote on the TV to see if you have it set up correctly for that TV. Sometimes when you reprogram a remote to work other devices the buttons won't always end up working the commands that are labled on the remote, also there is more than 1 code that may work better than other codes or may match up with the labeled keys more closely. Low batteries will also make a remote act strangely.make sure the batteries also make good contact on the pins or metal pieces inside the remote. I guess I need more info on which remotes are being used for what purpose before I could give a more certain answer.
Dec 26, 2010 | LG Televison & Video
My ViewSonic TV suddenly stopped working. The
hi do you mean the colour flashing on the screen, if so it's gone in to screen burn mode try press menu on the remote, retune the tv, if this don't work get back to me with model number of the tv help you a bit more thanks
shaun
Jun 12, 2017 | Televison & Video
Remote not working on my LG 37LC2D
Try replacing batteries and reprogramming both remotes.
Jul 05, 2009 | LG 37LC2D Television
Loewe 30" tv turns on, message "no signal"
first thing I would do is to make sure your cable box is turned on. if not fixed, make sure you have the correct input. this can be done by viewing all the inputs that the tv has by pressing the input button on your remote until you find a picture. if it is still not working, make sure you have you cable run right. there should be one cable running to the cable box and into the port labeled antenna or input, then anouther labed cable running from the output port to the tv. there might also be a vcr or dvd play inbetween. if that is the case, the cabel running from the cable box should go to the input of the vcr or dvd play and the output line should go to the tv. any equipment inbetween the cable box and tv should be turned on when viewing you cabel tv. you will also have to make sure that any equipment inbetween is running off the cabel input.
Jul 04, 2009 | Loewe Aconda ACO9303 30" TV
Tv remote controle codes for starchoice 5-in-1 remote (sharp aquos tv)
Nov 17, 2008 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Code for toshiba remote#ct90251 towork motorola hdtv cable box
When you program the unit, have the TV off, it is probably interfering. If possible, have the front of the cable box behind the TV. I was also told by the cable company to take the lens out of a cheap pair of sunglasses and tape it over the reciever on the cable box. This will block the interference from the TV. Haven't tried it. I have a Toshiba LCD and having it off while programming the reomote to the Motorla cabel box worked.
Sep 11, 2008 | Televison & Video
Having a problem...
Have you try pressing the SAT button?
Feb 10, 2008 | DISH Network IR Remote Control
Televison & Video Logo
63 people viewed this question
Top Televison & Video Experts
Electro Med Services...
