Question about Oster Fpstdh0101 4tray Electric Food Dehydrator
My dehydrator came on for ten minutes, then shuts off. Every 3 minutes, it turns on for three seconds, then shuts off. Then I wanted to chat with an online OSTER Rep....and they wanna charge me $20 to find out my problem???? Oster just lost a new customer.
3 Suggested Answers
SOURCE: I have a Oster dehydrator Md# FPSTDH0101. When i
I have a Oster dehydrator Md# FPSTDH0101. When i plug it in and switch on the Off/On switch to the on position the heater and fan do not come on. the switch lights up but it is not running. Help, does anyone have a wiring schematic?
Posted on Jan 14, 2011
SOURCE: How can I download a
i could scan mine and email you a copy
Posted on May 11, 2011
I have a buick century 2000 3.1 what causes car to start and shut down as if the fuel starts and stops
Security. Reset is turn the key on for ten minutes, off for thirty seconds. Try to start. Relearn is three times this. Try to start after the third. No start s usually wiring to the ignition chip. Wires break.
Jan 04, 2017 | Buick Century Cars & Trucks
Tip
Error codes
Samsung Washer Fault Codes
4E WATER SUPPLY ERROR Water Supply Error occurs when water level frequency does not show changes more than 100Hz or water is not supplied up to the preset water level after 10 Minutes or more at the time of initial water supply. The error status can be cleared by turning the POWER switch OFF and back ON.
5E WATER DRAIN ERROR 5E is displayed if the water level frequency detected is 25 KHz or less in the initial phase of the UNB -detecting cycle. The Water Drainerror can be cleared by turning POWER SW OFF and back ON.
oE OVER-FLOW ERROR Over-Flow error occurs when the water level is too high. It can be cleared by turning POWER switch OFF. Water is drained prior to POWER switch OFF. The tub is drained for 2 minutes if a frequency of more than 25 KHz is detected.
UE UNBALANCE ERROR Laundry load is unbalanced, manually loosen any tangled laundry.
If only one item of clothing needs washing, such as a bathrobe or jeans, the final spin result might be unsatisfactory and an UE error message will be shown in the display. Unbalance error is cleared by POWER switch OFF and back ON.
HE WATER HEATER ERROR HE, HE1 is displayed if the water temperature rises by 7 C or more in 1 Min or by 2 C or less 20 Min after heating process has started. The error can be cleared by turning POWER switch OFF.
1 E WATER PRESSURE SWITCH ERROR * Generated Frequency Signal of WATER LEVEL (WIL) SIW (KHz)
Normal Level = Abnormal W/L Frequency
Low Level = 30.00 Khz High Level = 15.00 Khz
If the same signal is detected for more than 5 seconds, it is aPRESSURE SWITCH Error. When this error occurs the drain pump will operate for 3 min. and the display will show 1 E indicating a pressure switch error.
cE ABNORMAL WATER TEMPERATURE ERROR e.g. If the water temperature is 50 C or more, during a Delicate or Wool cycle.
At the time of initial water supply, if the water temperature is not appropriate, the display will show cE. This error can be cleared by POWER SWITCH OFF.
11 E WATER LEAKAGE ERROR Water Leakage error occurs when the water drains naturally, (by leakage) after the washing program starts.
tE THERMISTOR ERROR This error occurs when the Thermistor circuit is abnormal or a voltage of O.2v or below or, 4.5v and over is detected. This error can be cleared by POWER switch OFF.
3E MOTOR RESTRICTION ERROR Hall Sensor is sensed every 5OOms. 1 second after motor starts to work.
If data of hall sensor is less than 2 (2RPM), the Washing motor will stop at once.
During Washing and Rinsing when a motor restriction is sensed, the motor stops and then proceeds to the next water -flow action. If the motor stops working and this happens in one direction ten times, "3E" Error is displayed.
During dehydrating. when a motor restriction is sensed. the motor stops working and then returns to the initial stage of the dehydration unbalance sensing cycle. After ten times, "3E" Error isdisplayed, When the motor Is told to stop because of an operating function. no error is shown.
Power 81W OFF can clear the motor restriction error.
8E OVER CURRENT ERROR IPM fault signal (this is caused by the overload of the MICOM INTO during motor action).
IPM: Integrated power module. The IPM controls the motor.
If the fault (low signal) happens to be sensed even once during the washing/rinsing stage, the motor stops immediately. However, during the dehydrating stage the signal is to be sensed, when the number of signals reads more than 6 per 500ms during the Washing or Rinsing cycle action.
If the motor stops working, in one direction ten times, "8E" Error is displayed.
During dehydrating, when the overload is sensed, the motor stops working at once and then feeds back to the initial stage of the dehydration unbalance sensing. When the feed back has occcurred twice, Error "8E" is displayed during the dehydrating unbalance sensing, No error happens by overload sensing. When it happens at more than 800rpm, the process is stopped compulsorily. Power Switch OFF can clear the overload error.
on Apr 14, 2015 | Washing Machines
How to disarm the anti theft system on an 05 CTS Cadilac
A reset is ten minutes on and 30 seconds off. One time. Relearn is three times this. Older vehicles used to be 5 to 10 seconds off. now is 30. There are minimal times on and off, but I haven't found the maximum time. I have left cars on for 30 minutes and off for 30 minutes and the reset/relearn has still worked. Just a note , the securit relearns in the off position.
Dec 13, 2014 | 2005 Cadillac CTS
Steps to reset a car alarm
If you have the original key.. Turn it on (don't try to start it) for ten minutes, turn it of for ten seconds. Try to start. If it doesn't start you have to do a relearn. Ten minutes on, ten seconds of, do this three times, then try to start it. You will have to have a charger on it. because if the battery gets to low, you'll have to do it all over agian.
May 12, 2014 | 1999 Chevrolet Blazer
No start after removing ignition switch and lock cylinder.
These vehicles have a built in antitheft system. When switching the ignition you interrupt this system. You will need to do a system relearn after the new ignition is installed. It will not start until the new ignition is installed and relearned. Step one. Put key in ignition, turn forward 2 clicks until right before it should start. Keep like that for ten minutes, NO LESS. Step two. After the ten minutes, turn key back to off position for 5 seconds. You need to do steps 1 & 2 a total of three times in a row without trying to start the car in between. The whole process should take roughly 30 minutes. After the last time waiting 5 seconds in off position, turn key forward and attempt to start the vehicle. Remember no less than ten minutes when forward, maybe do ten minutes and 15 seconds to be sure, some people even do 11 minutes.
Oct 28, 2011 | 2000 Buick Regal
Replaced ignition lock cylinder and new key has no chip so it will turn over but now wont start. what to do?
CHARGE BATTERY / TURN KEY TO RUN POSITION FOR TEN MINUTES
SECURITY LIGHT SHOULD GO OUT / TURN KEY OFF FOR 3-5 SECONDS
TURN BACK TO RUN FOR TEN MINUTES / REPETE / USALLY TAKES
3 TEN MINUTE CYCLES / THAN TURN OFF / TURN ON SECURITY LIGHT
SHOULD GO OUT AND ENGINE START AND RUN
Dec 08, 2010 | 1996 Oldsmobile Cutlass Supreme Coupe
Is there a gas pump shut off somewhere that can be turned back on? Battery ran low, when attemped to start jeep, securty light on dash flashed, head and tail lighs flashed. when jumped it started each time...
The security has been activated. you have to turn the ignition on, but don't try to start it, let it set for ten minutes turn it off without pulling the key out and try to startit. you may have to do this three times on ten off, on ten off, on ten off, then try to start it.
Good luck Randy
Nov 09, 2010 | 1993 Jeep Grand Cherokee
2006 Chevrolet Equinox won't start, security system is engaged, how do we restart it?
Make sure the doors and trunk,and hood are shut,open them,and shut them .activate the anti theft,wait about 1 minute,and disarm it,see if it will start,if not,the key fob may need to be relearned,try turning the key on,leave it ten minutes,then turn it off,and right back on,then wait ten minutes,and turn it off,and right back on,do this a total of three times,,30 minutes,then try and start.
Apr 21, 2010 | 2006 Chevrolet Equinox
My Salton Food dehydrator just stopped working. Turned it on for the first time today and it remained on for about 10 minutes and now wont turn back on.
If this is a Salton dehydrator that stopped working why are you referencing Gardenmaster dehydrators which is Nesco/American Harvest?
Feb 05, 2010 | Nesco Gardenmaster Digital Food Dehydrator
2002 Monte Carlo Security system has shut car down completely unable to start car
the process takes about thirty minutes. in three ten minute key cycles. here is how you do it . make sure that the battery is fully charged. step on parking brake pedal and leave it down this will keep the head lights off. turn the key and try to start it then leave it in the on position. you have to leave the key in the on position for ten minutes. you will see the security light on. after the ten minutes the light will go off then turn the key to the start position. turn the key all the way back to the off position and count to three. then try to start it and leave the key in the on position for another ten minutes till the security light goes out. you have to do this same process three times to reset the security system. sometimes you get lucky and it will start after the first ten minute cycle.
Oct 31, 2009 | 2002 Chevrolet Monte Carlo
Oster  Fpstdh0101 4tray Electric Food Dehydrator Logo
163 people viewed this question
Top Oster Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Ben Eng
Level 1 Expert
Are you an Oster Kitchen Appliances - Other Expert? Answer questions, earn points and help others
